Introduction: How to Make Easy-hook Pendant With Dangling Crystals
This is a wire pendant that you can easily hook, unhook and use on other styles of necklaces.
Materials:
7 Head pins
26 inches 14ga wire
7 x 8mm black crystals
Tools:
Wire cutter
Flat nose/bent pliers
Round nose pliers
Mandrel
Step 1:
Cut 26 inches 14ga wire. Find the middle of the wire and using your mandrel size 10mm create your 1st circle by coiling your wire onto the mandrel 2 times.
Step 2:
Then start forming 6 more circles, 3 on each side, adjusting the wire to form a diamond-like shape piece. Except for the 1st circle, the rest of the circles are created with only 1 coil.
Step 3:
After forming the circles you then twist the end wire to form a hook or bail.
Step 4:
This is how the bail should look like.
Step 5:
Then using head pins attach crystals on each of the circles.
Step 6:
When finished, simply hook it onto a necklace. In this picture I have hooked it onto a crocheted necklace. If you like a detailed PDF of this tutorial you can download it here for FREE.
Step 7:
This pendant is originally created for the Crocheted Necklace with Flower Toggle Lock Pendant
