How to Make a Carnation Bow
Intro: How to Make a Carnation Bow
These instructions will walk you step by step through the process of making a Carnation Bow using satin ribbon
STEP 1: Materials Needed
two yards of ribbon, scissors, one piece of narrow ribbon or floral wire.
STEP 2: Step 1
Form a loop of ribbon about 4 inches in length. Wind ribbon around initial loop about 12 times, each loop directly on top of previous loops.Start with Basic Pom-Pom Bow making 12 loops 4 in length.
STEP 3: Step 2
After youve wrapped your last loop, flatten and grip the center of all the loops tightly. Cut a triangle-shaped notch in the center of one side of the ribbon that goes slightly less than half way across the ribbons width. Repeat on the other side, being careful cut all the way across the ribbon. You should now have a pointed hourglass shape in the center of your loops.
STEP 4: Step 3
Tightly tie a ribbon or floral wire around the center of the notched areas. Leave enough excess of the narrow ribbon to attach the bow to your gift.Open the loops the same way as for the basic Pom-Pom Bow. Squeeze several loops together holding tightly and cut off the loops ends using a curving cut. Repeat until all the loops have been cut.
STEP 5: Step 4
Individually separate the loops to open up and form the bow. As you pull the loops apart, twist toward the center and alternate sides to form a pom-pom shape. Fluff the loops and arrange them around the center.
STEP 6: Step 5
At this point, you have made the basic Pom Pom Bow. To make the Carnation Bow, squeeze several loops together in one hand. Holding tightly, cut off the ends of the loops with a curved cut. Repeat until all the loops have been cut.
STEP 7: Step 6
Twist and fan out the individual ribbons until your bow reaches the desired shape.
Lori Ell 15 years ago
