How to Make a Lego Candy Machine
Intro: How to Make a Lego Candy Machine
This is a great afternoon project for Lego lovers such as myself. I like making things out of Legos and candy, so it seemed fit to create this project. I hope you enjoy reading this and making it, and would appreciate it if you would vote for me in the Toys Contest. The idea for it originates in the LEGO Crazy Contraptions book, but this model takes a different approach at the same device.
Materials needed:
- A whole lot of Legos, preferably single or double wide, flat pieces, and smooth pieces
- A medium rubberband
- 2 Connecter pins
- 1 long connecter pin
- 2 3x1 pieces with holes in them
- 2 2x1 pieces with holes in them
STEP 1: The Candy Holder
STEP 2: The "Floor" of the Candy Holder
First, you will need to make the "floor". This is to hold in the candy, but still leave an opening for the candy to fall through. You can see this in pictures 1-6. In picture 7 I showed how to attach it on the bottom.
Part 2 is the part that makes sure no candy gets let behind. It slants so the candy will fall toward the opening. I used slanted pieces stacked on top of each other to achieve this effect. You can see how I built it in pictures 8-13.
STEP 3: The Door and "Thingy"
Part 1: Use some of your longer smooth pieces to make the shaft back to the door. After, make sure you cover you door in smooth pieces, as to make it so it slides back and forth easily. Make sure every thing is stuck together tightly.
Part 2: This is where you need your rubber band, pieces with holes in them and connecter pins. Mount 2 1x2 pieces in a flat 6x2, to brace the pieces with the rubber band. Next mount the 1x2 pieces with holes in them and have the connecter pins in them. You will also have to put the rubber band in the middle of them, but depending on the size of your rubber band, you will need to double or triple fold it. Make sure it cannot come out before continuing. Attach the Pieces that are next to each other to brace them further. After this is done, attach the whole thing together on the top with another 6x2 flat piece. Stretch the rubber band over to your lang connecter pin and connect the connecter pin in the sides of the 2 4x1 pieces with holes in them. Put a 3x2 pice on top to secure it.
After you have completed Parts 1&2, set your main body upside down and put the door in upside down. Attach the "thingy" to the main body, with the smaller part facing in. pull you door all of the way up to the "thingy" and attach the smaller part of the "thingy" to the door. After you do this, test it and make sure there are no kinks.
19 Comments
MINDSTORMER 2.0 12 years ago
TheMaker888 12 years ago
i still got mine from Years back.. :P
susanrm 12 years ago
ncoleman2 12 years ago
kunfumaster 12 years ago
zigzagchris 12 years ago
Maxaxle 12 years ago
wolfking1016 12 years ago
Dashadower 12 years ago
lemonie 12 years ago
L
L
monsterlego 12 years ago
Emerald28 12 years ago
