Introduction: How to Make a Pac-Man Ghost Lamp
In this instructable, I will show you how to make a Pac-Man ghost lamp.
To be precise, we will create small ghost lamp shades to turn a boring spotlight system into a great looking Pac-Man themed lamp.
You will need:
- plastic bottles with the right shape
- a lamp, preferably a halogen spotlight system
- some white and black plastic
- spray paint in red, pink, cyan and orange
Once you found the right bottles and a nice lamp, this project will take about 2 x 2 hours.
Step 1: Finding the Right Bottle
At first, you have to find a plastic bottle with the right shape. Unless your supermarket has a section for ghost shaped bottles, this will be a bit of a treasure hunt.
You are looking for a bottle that has a cylindrical shape with a round top. If you happen to be in Germany, you can look for the brand "Kneipp".
Buy one bottle for each ghost you plan to make, plus one or two spares, just in case.
Step 2: Find the Right Lamp
The second part of the treasure hunt is the search for the right lamp. I went for a MAGNESIUM spotlight system from IKEA.
As the plastic bottles will act as lamp shades, the light bulb should not dissipate to much heat and the shades should not touch the light bulbs directly. You could also use bare halogen sockets if you make some kind of spacer. Or you could use LEDs to avoid the whole heat issue.
Step 3: Cut the Bottle
After you have emptied your water bottles, it's time to cut them.
To get an even shape, it's advisable to create a template on paper and use it to mark lines for cutting on the bottles.
Make the cut on the bottom first. You can use a sharp pair of scissors or a cutter knife.
The top of the bottle is the strongest part of the bottle and gives it its stability. You can use a cutter knife for the top too, but a rotary tool aka. Dremel is probably better suited for the job.
Step 4: Paint the Ghosts
Now it's time to paint the ghosts.
You can use a primer, but I got a good result without it. Cover both the inside and the outside of the shades with at least two layers of paint.
Make sure that your paint shop is really opaque, otherwise you will see every minor imperfection shine through.
Step 5: Add the Eyes
The only thing that is missing to complete your ghosts are the eyes.
You need a piece of white and black plastic. I recycled some yogurt cups and a black file cover.
In the game, the eyeballs are oval and the pupils are round, but I went for an oval shape for both. Don't put the pupil centrally on the eyeball, but on the side.
Step 6: Put on the Shades
Once you are happy with the looks of your ghost, you just have to put them on the lamp.
How this will work depends on the lamp you chose.
In my case, I mounted the Magnesium system a bit different than intended. Normally, the lamps are held by a little arm, but I let them hang on the cable instead.
Step 7: The Finished Pac-Man Lamp
Mount the lamp in its designated place and let it shine!
13 Comments
6 years ago
Will acrylic paint work on these?
Reply 6 years ago
To be honest, I know next to nothing about paint. I used some generic spray paint. I assume that is acrylic paint, but I'm not sure.
9 years ago on Introduction
It depends on the lamp you use. With lamp from IKEA is used, the halogen bulbs already have metal shades with a plastic housing. I never had problems with the bottles melting, but YMMV with bare halogen bulbs.
11 years ago on Introduction
Wow!! That's realy awesom! What a great idea! I'm olso going to make these!
Thanks for sharing !
Its SOOOOOO cute!
(And adorable!)
Nice idea!
Also cut a pie from a yellow plastic ball and make the protagonist!
So cute! This would look great in a kids' room!
Sweet!
Nice and easy!
Thanks for sharing.
Cool!
I agree. I like the idea and you present it very clearly. You did a great job.
Fantastic, I love it!
Reply 11 years ago on Introduction
Thanks! I'm glad you like it!
