How to Make a Tetrahedron Platonic Solid or a Four Sided D&D Die (dice)
Intro: How to Make a Tetrahedron Platonic Solid or a Four Sided D&D Die (dice)
How to make a Tetrahedron Platonic Solid or a Four Sided D&D die (dice)
This instructable will show you how to make a 4 sided tetrahedron out of paper or cardboard. A quick little project that you can do with the kids. This should take about 10-15 minutes and if you can do this one you can move up to making the more complicated solids.
STEP 1: Materials
Materials:
Superglue
Ruler
Pencil
Cardstock or thick paper
Scissors
Butter Knife
Nail Polish Remover: Just incase you accidentally glue your fingers.
Superglue
Ruler
Pencil
Scissors
Butter Knife
STEP 2: Make the Base Triangle
1. Turn the paper in a Landscape position.
2. Measure and mark 8mm and 4mm from the left side on the top and bottom of the paper.
3.Connect the marks at top and bottom lightly.
4.Using the ruler measure 8mm from the left hand corner on an angle until it touches the 4mm mark.
5.Repeat the process from the other side. The marks should come to a point and make a perfect 8mm isosceles triangle
6.Double check the measurements and make sure all 3 sides are exactly 8mm.
7.Carefully cut the triangle out.
STEP 3: Making the Body of the Solid
8.Flip the paper over.
9.Using the cut out triangle as a template draw three triangles next to one another. Two will point up one will point down.
10.Draw another triangle pointing up on top of the middle triangle. This should resemble a larger version of the triangle you have already made.
STEP 4: Score the Sides
11. Cut out the larger triangle.
12. Score the lines on the larger triangle.
13.Hold a ruler over the scored lines and gently lift the corner, this will allow a nice crisp bend in the paper.
STEP 5: Fasten the Sides
14.Cut a small rectangular scrap from the cardstock to make a tab to secure the sides together.
15.Bend the tab in the middle and apply a small bit of superglue to the tab.
16.Apply the tab wait a few seconds and then bend and glue the corresponding side up to the tab.
17.Apply at least one tab to each side and glue.
STEP 6: Finished
18. Paint, I used red for mine.
7 Comments
PhilipBradfield 3 years ago
(8mm too small for practical purposes)
see also "Mathematical Models": Cundy and Rollett
Philip Bradfield
REA 15 years ago
Eye Poker 16 years ago
citzar 16 years ago
lemonie 16 years ago
Tetrahedron always reminds me of a publication though...
http://www.elsevier.com/wps/find/journaldescription.cws_home/233/description
L
(I published something there once)
