How to Make a Bird Feeder Out of Ikea Plates
Intro: How to Make a Bird Feeder Out of Ikea Plates
Spring is here and with it comes the birds. Why not give them a little grub with this simple, cheap, and visually pleasing bird feeder.
STEP 1: What You'll Need to Get Started
1. Two 12" Ikea Hultet bamboo plates
2. A 3/8-16 Carrige Bolt 12" long
3. A drill
4. Any washers, nuts, fasteners your heart desires
(so long as they fit the bolt)
5.Some string or wire
6. A keychain clip
Note: These are merely the materials I had to work with, feel free to experiment with whatever materials you may have.
3. A drill
6. A keychain clip
STEP 2: Step 1. Drill Some Holes in Ikea Plates
Step 1. Drill a hole in the center of each of your Ikea plates.
Note: I used the largest bit I had which was slightly smaller than the bolt. Bamboo is a soft and easy material to work with so I lightly filed the hole until it fit the bolt.
STEP 3: Step 3. Thread the Bolt Through the Plates and Secure With Washers, Nuts, and Fasteners
Step 3. Thread the bolt through the two plates and use your washers, nuts, and fasteners to secure it in place.
I used a few different washers and fasteners to give the feeder the best support I could.
Note-The head of the bolt will be the bottom of your feeder
STEP 4: Step:4 Drill Two More Holes on the Top of the Feeder.
Step 4. Drill two more holes on the top half of the feeder, roughly 1/2" from the bolt, this is where you'll loop through your wire or string.
Note: Try to keep the holes evenly allingned with one another to help prevent the feeder from hanging lopsided.
STEP 5: Step 5: Loop the Wire or String Through the Holes on Top of the Feeder & Tie It Off on the Keychain.
Step 5. Take your wire or sting and loop it through the holes you drilled in the top half of the feeder. Tie it off being sure that you've worked the string through the hoop on your keychain before tying.
STEP 6: Step 6: Hang Your Feeder, Fill It With Birdseed, and Enjoy!
Step 6: Find the best spot to put up your feeder, hang it, fill it with birdseed, and enjoy!
Overall, the feeder cost $2.19 to make, I only had to buy the bolt, everything else I had on hand. The design is simple enough that it could be applied to most things you might have lying around your humble dwelling.
10 Comments
geessebeschleier 9 years ago
I drilled a third hole on the bottom part to allow water drainage and used a screw hook on the top part
Hillbillee 11 years ago
PaulEl 14 years ago
Mycophiles 14 years ago
Marcos 12 years ago
Just for pricing: so everyone knows. The Ikea plates pictured are in the "home and garden" area of Ikea and are 7$ for the small plates and 10$ for the larger plates ( about twice as large ). Unlike the instructor above I drilled through the rod ( already had one ) and put some metal twine through to tie a string through ( can use twist ties ) to keep the string from being cut by the metal plus I did the same ting to the other end and tied a weight to keep it from swinging. Also, on the nuts I used some epoxy to lock them in place as *if not torqued down .. which I wouldn't do on bamboo* the plates seem to loosen themselves if they are spun.
I used nylon string for elongevity but it's a bit ugly. If you can find black nylon it would work nice. Also, painting the rod might look nice also. The bamboo doesn't seem to be holding up however. Around the edges it seems to want to peel off. ( in just days now w/ 2 wet days ). I put two plates right side up unlike our intructor. The top is bigger and has food for larger birds and the bottom is fairly close to the top to allow only small birds to get to it. It seems to be working. ( plus I put drain holes in both plates.) Good luck intstrucables.
Here's a (bad) photo.
http://i257.photobucket.com/albums/hh206/1234Mycophiles4321/Misc/bird.jpg
PaulEl 14 years ago
ChrysN 14 years ago
lemonie 14 years ago
L
