How to Make a Chevron Friendship Bracelet
Intro: How to Make a Chevron Friendship Bracelet
This project takes a lot time! After a couple rows you will have the hang of it and be able to finish!
Materials:
String/embroidery thread (different colors)
Scissors
Tape/clipboard (something to hold down)
Ruler
Materials:
Scissors
Ruler
STEP 1:
1.After deciding at least 2 different colored string, cut to 50 inches. I am making mine with 3 colors. (If you pick 3 colors, cut 1 of each color 50 inches)
2. Fold the string in half and make a knot at the top so there is a loop at the very top.
STEP 2:
3.Tape the string above/at the knot to hold down in place. (this is just to keep it still and in place)
4. Spread the thread in a pattern like 1 2 3 3 2 1. The left should mirror the right side.
STEP 3:
5.Start at the left string. String #1 (BLUE) Make a knot by making a number “4” over the second string, go under and through the hole, and then pull tight. Do another knot—you should have 2 knots.
STEP 4:
6. Using the same string (#1 BLUE) you will knot the same way over the 3rd. Do not forget to do 2 knots. When you get to the center stop.
STEP 5:
7.Repeat from the right.
STEP 6:
8. Knot the 2 center strings (both blues) don’t forget to knot 2 times on each!
STEP 7:
9.You will continue to follow the pattern of colors, again starting at the left working to center, stop, start at the right working to center then knotting the 2 center threads.
10. When you get to your desired length (try wrapping around wrist to see) you can tie around wrist and cut off any excess thread!
7 Comments
marydevoie 3 years ago
18590 2 years ago
18590 2 years ago
Eva Lauwereyns 4 years ago
laurenlovesshopping8645 4 years ago
Danger is my middle name 9 years ago
Pretty! I love the color choices!
BMR_11_100 10 years ago
