How to Make a Duct Tape Battle Axe
Intro: How to Make a Duct Tape Battle Axe
This battle axe is perfect for a backyard battle or a game of LARP (Live action role play) in the nearby forests.
It is easy to make, and with adult supervision kids can make there own.
This is the first instructable in a series about how to make weapons and other equipment for LARP.
My main focus is that the weapons have to be safe, so kids can play with them without direct adult supervision, without getting hurt. And secondly so easy to make that big kids, with help, can make it them self.
Next edition to my duct tape weapons guide can be found here
www.instructables.com/id/How-to-make-a-duct-tape-sword/
STEP 1: Things You Needed
You will need
Sketch block
a pencil
A hobby knife, with interchangeable blades.
Extra blades
Used dull blade
a piece of cardboard
a black marker
a cutting pad
contact glue
duct tape
reinforcement Tape
foam pipe
a sleeping pad
65 cm of 3cm thick bamboo or broomstick
Sketch block
a pencil
Extra blades
Used dull blade
a black marker
a cutting pad
contact glue
duct tape
reinforcement Tape
foam pipe
a sleeping pad
STEP 2: The Design and Research Fase
Start by finding some pictures of "real" battle axes. Ex. do some google search.
http://images.google.com/images?hl=da&sa=1&q=battle+axe
http://images.google.com/images?hl=da&sa=1&q=dane+axe
Now you have enough inspiration to make you own design.
Just draw some quick sketches. They don't need to be beautiful, it is just so you will get the idea about how your axe will look like.
STEP 3: Cardbord Template
Now draw the design of your choice on the cardboard. This will be your template so be careful and take your time to make it perfect.
I start by making the drawing with a pencil, and when I'm satisfied with the drawing, I make the final drawing with the black marker.
STEP 4: Marking and Cutting the Foam
Now draw the axe 3 times. And the smaller pieces 2 times on the foam. Pay attention to the placing of the pieces so you don't waste to much of the sleeping pad.
If the stick for the handle is to long, now is the time to cut it into length.
To be sure the pieces ends the right places I put numbers on them.
In piece 2 cut a hole for the handle.
STEP 5: Reinforcing and Gluing
On piece 1 and 3 I put a cross of reinforcement tape. This will stabilize the axe to ensure that it will not break or be ripped apart at the thin part.
Now apply glue to one side of piece 1 and 3. And apply glue to both sides on piece 2. Also apply glue to the end of the handle. Let it dry for 10-15 minutes, and press the pieces hard together.
Now apply glue to the two small side pieces and the outer side of piece 1 and 3. Let it dry for 10-15 minutes, and press the pieces hard together.
Be careful the two pieces glue together very quickly, so be sure that they are aligned you will not be able to correct it. The only way to correct it, is by cutting away on the outer side.
Now cut the sitting pad into strips. I need two pieces for this axe. Normal I use pipe insulation but it was sold out the places I use to buy it. But they had this sitting pad, and that will do the job.
Cut a triangle grove that fits into the triangle of the axe. And slip the pipe onto the handle.
Safety note
If your using the same glue I use you need to have good ventilation. If it's not to cold it's best to glue outside.
It's possible to get waterbased contact glue if you make this with kids, I recommend using that.
Safety note
STEP 6: Cutting and Shaping the Edges
To make the foam look like a real battle axe you need to cut the edge. If the layers got unaligned when gluing, this is the right time to cut that edge also.
STEP 7: Taping
Put strips of duct tape on the axe. Be careful when applying the tape special around the corners. Take the hobby knife and cut the tape into strips so it will not get wrinkled. When applying a new strip of tape, don't make the overlay more than 1 cm. If you put on to much tape, the axe gets hard and heavy, making it dangerous to play with.
STEP 8: Decoration
I use the black marker to draw some decoration and to highlight the edge to give the axe more depth.
STEP 9: Happy Kids With There Battle Axe.
Now make you own axe and start battling!
48 Comments
Dovakin 9 years ago
Basically followed the sword template, used PVC piping, PVC pipe foam, and yoga mat for the blade.
Its actually surprisingly sturdy!
Thanks!
Pee-Ka-BooG 8 years ago
awesome!!!
sharfas 10 months ago
Veve Tech 13 years ago
Mechanical Undertow 13 years ago
morfmir 13 years ago
/Thomas
2h4d0wDK 12 years ago
/Tri
Veve Tech 12 years ago
2h4d0wDK 9 years ago
I was replying to morfmir though, and it was Danish xD
The Rambler 10 years ago
cbarnes10 11 years ago
billyjoeface 12 years ago
yourworstnightmare 14 years ago
jwhalen523 13 years ago
if you want a more complicated role playing game then i recommend you find one in your area. there are groups that have weekend long events a few times a year with a continuing plot. each one has its own rule unique rules system, most of them loosely based on D&D rules. there is most likely a group like this within a two hour drive from where you live. ask around check online for any in your area. they will have websites where you can register for an event and read their rules. its a lot of fun
oatcake man 14 years ago
Biohazard1194 14 years ago
morfmir 14 years ago
But you should consider padding the handle also, if your planing to fight with it. It can hurt a lot it you get hit with a unpadded wooden handle.
/Thomas
Pryo Chain 14 years ago
