Introduction: How to Make a Princess Castle Hair Clippie
This sweet castle clippie is so cute, and fairly easy to make!
Step 1:
First, take a 1" piece of 3/8" ribbon color of your choice, and fold it on itself, and glue it in a 'cone' shape.
Do this step twice.
Do this step twice.
Step 2:
Then, take a 1" piece of 7/8" ribbon color of your choice, glue it to the front of the 'cone', at the top.
Step 3:
then, take the sides, wrap them around the back, and glue down.
Remember to use just a small amount of glue for this! I used a bead of it down the edge.
You *may* need to trim off a small amount to keep it from looking 'bulky' in back.
Remember also, to do this step twice!!!!
Step 4:
next, take a 2" strip of 7/8" ribbon, and glue in the sides (just a little bit!)
Then, glue a small bit on the bottom up on itself.
Turn it over, and glue one of the 'towers' on the edge of the castle
Step 5:
After you have the towers glued on, make the windows.
I used 1/4" ribbon, and cut VERY SMALL squares. SEAL THEM!! I used Fray Check.
Then, make a drawbridge by cutting "U" shape into a piece of 7/8" white ribbon.
Step 6:
you now have a completed castle!
At this point, you can either turn it into a pin, or whatever you desire!
I put it on a lined clippie!
You can makes these in ALL SORTS of color combinations! use your imagination!
