How to Make a Working Mosaic Clock
Intro: How to Make a Working Mosaic Clock
This is a mosaic clock that works. The following steps will help you make one too. (This is my first instructable, so if you have anything to say just ask in the comments below. I would love to hear everyone`s opinion and want them to be happy.)
Lets get started!
Lets get started!
STEP 1: Materials
You will need the following items:
- Clock movement motor (it comes with clock hands)
- Plastic numbers
- Mosaic tiles (or any tiles of your choice)
- Mosaic tile grout
- Circular piece of wood
- Super glue
you can get all of these items at a craft store near you. (Unless they ran out of the products that you need, but that will be very unlikely)
- Plastic numbers
- Mosaic tile grout
- Super glue
STEP 2: Add a Center Hole
This step is pretty simple. Using a drill, add a hole to the center of the circle. This is where the clock motor will go.
STEP 3: Lay the Tiles
Place the mosaic tiles where you want them to be on the circular wood. I chose the colors dark blue,light blue, and green because those are my favorite, but you can use any colors of your choice. If you want your tiles to be spaced out, you should put the tiles about an inch and a half apart and if not, then put them about half an inch apart.
STEP 4: Glue the Tiles Into Place
Take the super glue and glue the mosaic tiles into place. Remember not to glue the tiles too close to the center hole.
STEP 5: Add Mosaic Grout
Take a blob of the mosaic grout and place it on the tiles. Use a paint brush to spread it out onto the tiles.Make sure that the grout gets into all the cracks and does not get too close to the center hole.
After 5-10 minutes, wipe off the excess grout from the top of tiles with a damp rag-- this way you can now see the design.
STEP 6: Optional Side Mosaic Tile
If you would like to add tiles to the side of the clock, glue them on to the sides, and then apply the grout as done in step 5. (I recommend doing this.)
STEP 7: Finished Grouting Product
Once you have wiped off the excess grout and it has dried completely, this is what it should look like.
STEP 8: Glue on Clock Numbers
First measure out where each number will go and simply place them on the clock
Glue the 12, 3, 6, and 9 numbers down first-- this will make it easier to place the other numbers in exact measurements.
STEP 9: Attach the Clock Motor
Take the clock motor and place it through the hole. Once this is in the hole, there should be a bolt (provided with clock motor) that will hold it down.
STEP 10: Attach Hands of Clock
From the top of the clock, place the hour hand down first, then the minute hand and finally the second hand.
STEP 11: TA-DA
You have just made a mosaic clock. Now put a battery in the motor to make it tick!
I hope you liked this instructable on how to make a mosaic working clock! It is a great present so hope you have fun making yours!
Thank you instructables for letting me show everyone how to make this! Good luck!
14 Comments
lucinda brooks 3 years ago
CreativeGeek 11 years ago
Bentspent 12 years ago
LEveritt 12 years ago
jdafpnsf 12 years ago
Bolted 12 years ago
iwoodinspire 12 years ago
Trilogy221 12 years ago
AlexAlexander 12 years ago
Filterbuilder 12 years ago
Spate28 12 years ago
bubblebuddy777 12 years ago
Medalsound 12 years ago
Prettypony222 12 years ago
