How to Make a Zombie
Intro: How to Make a Zombie
This was my first attempt at making a zombie. I took little things I saw on the web and my own creativity to make it. I hope you enjoy building this.
STEP 1: Material's and Tools
News paper
Toilet paper
Paper towel
Elmer's glue
Duck tape
20 gauge hanging picture wire
Scrap wood
Cheap foam head
Foam ball (pingpong size)
Hot glue
Nails
cardboard tube
old wig
plastic garbage bag
Acrylic paint
Spar urethane
Paint brushes
Outdoor paint
Tools:
Hammer
Screw driver
STEP 2: Start the Frame
Cut wire to the desired rib size and roll newspaper around it. Duct tape it to the cardboard tube. I created most of the body limbs this way using some wood for the arms and wire, newspaper and duct tape for the hands.
STEP 3: Build the Body and Mount It
I used scrap wood in my garage for stability. If you have any leaning body parts I suggest you use wood inside so it doesn't fall or brake with temperature changes or kids. I stuffed the inside of the the body with a bag and filled it with crunched up newspaper. This gave me a shape to later apply the paper mache to between and below the ribs.
STEP 4: The Head
I used a cheap foam skull and cut the bottom jaw off. I re-positioned it so the mouth is wide open and hot glued it. I then cut a foam ping pong size ball in half and glued it into the eye sockets. Then I used a scrap piece of wood and with a flat head screw driver with a hammer and chiseled gouges out of the wood for the teeth and nails. The gouges were 2 mm deep and 3/4 inch long that I then filled with hot glue and waited for it to dry (20 mins approx.). I then pried them out with a flat head. With the hot glue gun I melted holes in the skull where I wanted the teeth to sit then filled the cavity with hot glue then stuck in the teeth.
STEP 5: Put the Head on
I used a lot of hot glue when putting on the head making sure I filled in most of the gaps in the mouth. Then I made a femur the same way I made the ribs but added two rolled up ball shape to the end to make it look like a bone. i stuck it in the tube and taped it. It's not anatomically correct, but it gave it that extra look it needed for the lower half of the body.
STEP 6: Paper Mache
Cover the entire thing with paper mache, about 3 layers worth. Make sure to let it dry between each coat. Then add paper towel over top where there is skin. Dip the paper towel in a glue mix( 60% Elmer white glue 40% water) you can pinch the paper towel to make bites or veins. For finer detail use toilet paper. Toilet paper is great for making guts and bite marks look more realistic. After you let it dry for a couple days, paint the entire thing with outdoor paint (pick an unwanted color or mistake color as they are super cheap from the store). Wait another day for the paint to dry.
STEP 7: Paint Your Zombie
I used basic acrylic paint and started with a darker color first and then added the highlights. Last, was the blood which I created with dark red food dye mixed with clear Elmer's glue. It makes it look more natural if you just drip it on. After that, cover the entire zombie with 3 coats of spar urethane. Let it dry 24 hours after each coat. Make sure you coat the wood as well, especially if you live in a rainy area. For the hair, take an old wig and rough it up. I used a permanent marker to dull the hair little. Hot glue the head and place the wig on. Wait for it to dry to glue the edges of the hair down to the wood base.
23 Comments
nathantwan.toan 9 years ago
I've got a week to finish it before my New Years " z " party
hauntingmomma 9 years ago
I like this so far and see your got some great talent. What kind of paint are you using ? I built the entire skeleton first then built on that. i am not sure how your going to get the hand on there but so far your zombie is creepy :) When you add the urethane its going to give it a greenish look. My zombie looks better now then it did when i first did it because the urethane turned more greenish yellow with time. It held up to the rainy seattle weather and is ready for the next years scare :)
Looking goood so far :) I would make the eyes red and put veins in her eye.Please send me a pick when your done :) i love to see it :) I am going to start making my new zombie in may-june, I am going to try one of the zombies from the February episode of walking dead :)
acash1 9 years ago
Wow, thats awesome !! I love the guts !! how did you do it ?
acash1 9 years ago
monokuma.junko 9 years ago
Awesome!!! Very good job!
Thank you very much :D
PaperChaser 9 years ago
Very nice it reminds me of this zombie from the walking dead.
Haha :D this is the picture i used for my work :D Thank you very much !!!!
xasterbated 9 years ago
Thank you :)
NutzDad 9 years ago
Thank you very much :) I love the idea of adding lights !! i think i do that next year to one of my creations!!
Faizshaikh 9 years ago
Wow creeps me out in so many ways! nice work !
Thank you :)
MsSweetSatisfaction 9 years ago
She's so creepy looking! Reminds me of the first episode of the Walking Dead! Thanks for sharing!
