How to Make a Zombie Face Wound
Intro: How to Make a Zombie Face Wound
Making a zombie-like face wound using gelatin-skin.
Items you will need:
-Gelatin-skin (a great tutorial here --> http://www.zombiemaker.com/makeup/gelatine_skin_basics )
-Face and Nose Wax (or any sort of make-up wax will work)
-Spirit Gum
-Toilet paper (2-ply)
-Eyeshadow in bruise colors (yellow, blue, green)
-Cream make-up (red, yellow, blue)
-Brushes
-Face powder (or Neutral Set)
-Fake blood
-Liquid Latex (optional)
And some great music to listen to never hurts :3
-Spirit Gum
-Brushes
-Fake blood
STEP 1: Getting Started
You always want to have a clean face before starting! Using soap and water will work, but using actual facial cleanser works a lot better!
STEP 2: Wax Time
Using the face and nose wax, cover the area you're planning to make-upify. Spread the wax out thinly at the edges.
If it starts to stick to your fingers, wipe them off on a dry paper towel. Getting your fingers wet while they're covered in wax will only end in tears.
STEP 3: Toilet Paper Time
Now, take that 2-ply toilet paper and separate the sheets, so you have two very thin pieces. Take on and tear it into strips, roll said strips into a ball, then stick onto the wax. We're trying to accomplish the look that it's tissue (lawl, no pun intended) that's been ruptured when the wound occured!
After you have as much as you want (seriously, go crazy), take the red cream make-up and a brush and start splotching the red onto the toilet paper.
STEP 4: Still Coloring...
Once you've got the red on (and it's okay if it gets in the wax!), take your yellow cream make-up and make a few spots on the red.
Then, mix together a bit of blue and yellow to make a nice green, and add that as well.
STEP 5: Gelatin-skin Time!
Remember the gelatin-skin I mentioned in the intro? Now's the time to use it!
Make a slit through the middle of the skin, first off, elsewise how will you see the tissue beneath? Don't make the slit once it's attached to your face. That's not a good idea, and you'll probably end up not needing that fake blood after all.
Using your Spirit Gum, brush it on all around where the gelatin-skin will be. Wait for it to be a bit tacky feeling before you slap the skin on.
STEP 6: More Wax
Now, there are two things you can use at this step:
Liquid Latex or the wax.
Now, I used both, and that ended a bit badly, since the wax peeled up the latex. I recommend just using the wax.
What for, you ask? Well, using the wax near the edges of the skin will help you blend it into your skin better, so it doesn't look like you have fake skin on at all!
Take the wax and pull it outward, away from the gelatin-skin and onto your face, so it starts to look a bit like this.
STEP 7: Adding Color
Time to bust out your cream make-up again!
Using that ghastly green color you made earlier, sponge it on with a make-up wedge. Be VERY careful around the edges where the wax is, because you might end up pressing the wax down against your skin, and you'll be able to see the edge of the gelatin-skin. We don't want that.
If it happens, however, put a bit of the green on your fingers and tap the wax to make it stand back up.
Experimentation is the best way to get the look you want.
STEP 8: More Green
Make-up the rest of your face with the green, and add some nice red or brown underneath your eyes. I used some brown eyeshadow.
(If you're going for a less-long-since-dead and more recent zombie look, then use black, blue and yellow around the wound and a foundation of your skin tone to blend it.)
STEP 9: Fake Blood
The most fun step!
Get your fake blood (and make sure you're wearing clothes you can get dirty) and go wild.
I poured my blood from the cap of a water bottle straight into the wound, then used a brush for around the edges and such. You can do whatever you like!
STEP 10: You're Done!
It's time to go eat some brains!
(Remember to make the rest of your face more dead-looking, unlike me!)
18 Comments
marsha.glassburn 9 years ago
very cool idea but where do u get the items to do this
nmiller14 12 years ago
disturbia 12 years ago
HeyImInventingHere 13 years ago
mommyknows1 14 years ago
theseventhsage 14 years ago
evolx10 14 years ago
cryophile 14 years ago
Pull and Twist 14 years ago
gustavo.leal 14 years ago
=SMART= 14 years ago
arvindhimalayan 14 years ago
mg0930mg 14 years ago
andros1200 14 years ago
SinAmos 14 years ago
desolatedecember 14 years ago
