How to Make an AUG PVC Marshmallow Shooter
55,039
19
24
Introduction: How to Make an AUG PVC Marshmallow Shooter
Marshmallow shooters are one of the most fun things to build and use. This is an instructable on how to make a marshmallow shooter that looks like an AUG assault rifle. It's automatic rapid fire. Gravity fed magazine that holds up to about 9 marshmallows.
Step 1: What You Need...
Main Body:
You will need to go to a hardware store and get some PVC pipes (obviously). Get a few sticks of 1/2 inch piping and cut them (using either hacksaw or pvc cutter) into these quantities:
one 8.5* inch pipe (this will be your barrel)
two 2 inch pipes (this will be part of your scope)
four 1.5 inch pipes (these will connect your T pieces/intersection pieces)
one 4.5 inch pipe (for your handle)
one 5 inch pipe
three 3 inch pipe (part of your stock)
one 4 inch pipe (part of your stock)
*all these measurements are estimated so make adjustments if needed.
Then get some pipe connections:
six T pieces (7 recommended for a scope piece)
two 45 degree angle pieces
three couplers
one intersection piece/piece shaped like a + (this is used if you don't want to use your 7th T piece)
two slide on caps
Other things you need:
tape (any kind will work)
clear piece of thin plastic (or any thing you want to use for a scope sight)
Step 2: Your Stock + Magazine
What you will use:
four T pieces
both your 45 degree angle pieces
one slide on cap piece
two 1.5 inch pipes (one for connecting the two T pieces, the other for connecting the T and the 45 degree piece)
two 4 inch pipes (one for the magazine/clip, the other for the side of the stock)
three 3 inch pipes (for almost all the sides of the stock)
one 5.5 inch pipe
some tape
Procedure:
You can start in any way you want, but this picture pretty much shows all that you need to do. I will start at the top left corner of the stock. Your first 1.5 inch piece will connect two T pieces (one being upside down) as shown. The T piece on the left is where you will blow air through. The right T piece (upside down) will hold your magazine (make sure to don't tape the magazine). Connect that T piece with one of your 4 inch pipes and put the cap on. Then, connect the remaining hole of your upside down T piece with one of your 3 inch pieces. Connect that with a T piece (that should be the T piece at the top right of the stock in the picture). Then connect the 5.5 inch pipe to the right of the T piece. On the bottom of the T piece, add your last 1.5 inch pipe and connect it with one 45 degree angle piece (this will be your first handle). It should face left. After that, connect your second 3 inch pipe with another 45 degree angle piece. Connect the other end of that 45 degree angle piece with yet another 3 inch piece. Now we should be at the bottom left corner of the stock. Add the upside down T piece and connect the stock with the second 4 inch pipe.
Now, using the tape. You want to cover the holes of some parts of the stock to prevent the marshmallows from falling into there. I would suggest taping the top part of the 4 inch pipe and the top part of the 1.5 inch pipe that's in your first handle.
Hey, you completed step 1! Give yourself a high five, or high five a mirror if you want.
Step 3: Your Scope + Barrel/rest of the Gun
HOKAY, so onto the rest of the gun. Since it is complicated, I will divide it into two parts: the scope and the handle/barrel
The Scope
What you'll need:
one T piece
two couplings
one intersection (+ piece)
two 1.5 - 2 inch pipes
two 1.5 inch pipes
the piece of plastic (make sure it's see-through)
sharpies
tape (for preventing the air to escape; adding more pressure to the gun)
glue
scissors
Procedure:
Get any pipe (NOT THE COUPLING, T PIECE, OR INTERSECTION) and put it on the plastic. Use a sharpie to make a circle on the plastic. Cut out the circle and use different colored markers or sharpies to make a scope sight. I made just a regular cross with a red dot in the middle. Then glue this scope sight to one end of the coupling. It should fit right on top of it, then set it aside. We'll start from the bottom to the top and the other 1.5 inch pipe to the right (that will connect the scope part to the rest of the gun. Get a T piece and turn it upside down, then add a 1.5 inch pipe (tape the bottom of the pipe and insert it) onto the top. Then add the intersection piece (or the optional T piece) to that. Attach both the 1.5 - 2 inch pieces to both sides of the intersection piece. Then attach the non glued coupling to the left and the glued scopesight piece to the right. Then that's your scope. Just make sure you tilt it to the side a little like a real AUG
The Rest
What you'll need:
everything else that you have
Procedure:
Start with the T piece. We are going to make a second handle! Add the 4.5 inch pipe (tape on top) on the bottom of the T and a cap underneath that. Then add the 8.5 inch pipe to the right and finish it with the last coupling.
Congrats! Now just connect the two steps and don't forget the tape on the stock!
Step 4: Taping and the End
Ok, so what i meant by taping the top or bottom of the pipe was: getting a small piece of tape and cover the hole. Not only will this prevent the marshmallow from falling in, but it also increases the pressure so you'll need less breath to get the marshmallow out of the gun. It's hard to see in the picture but I used some clear tape and covered that hole.
A note: these steps aren't mandatory, be creative, modify my version if you must. I'll be glad to hear your versions of the shooter.
Using the gun:
For starters, to load the gun you need to put mini marshmallows into the magazine. Turn your gun upside down and put the magazine up. Then turn your gun back to its regular position and blow through the top right T piece of the stock. If you don't like this, modify the gun so you can blow elsewhere.
Note: the scope is for decoration purposes.
If I had made any errors, please tell me.
Be the First to Share
    • Jewelry Challenge
      Jewelry Challenge
    • Fix It Speed Challenge
    • New Year, New Skill Student Design Challenge
    24 Comments
    plumboy11
    plumboy11
    1/2" is what I used for mini marshmellows
    pyro4226
    pyro4226
    13 years ago on Introduction
    i made this and it was decent at best. to many fittings in the barrel?
    slimshady217
    slimshady217
    i know that im like 3 years late for the reply, but make sure you are using 40 or 80 schedule PVC pipe, rather than 20. The 40 and 80 have thicker walls, so air doesn't slip by the marshmallow.
    z12ent
    z12ent
    11 years ago on Introduction
    anyway anyone know how to make one with pump action instead of blowing down a tub?
    monkeyboychase
    monkeyboychase
    check mine out here, you don't pump but you don't blow and its extremely fast check it out please
    monkeyboychase
    nice pretty sweet and i like the scope, mine also has a clip thinking about adding a scope but like someone commented i was leaning towards a laser sight heres the link to mine/, click here but it isn't finished yet i might make it into a full instructable but let me know how you like it?
    ceaser47
    ceaser47
    12 years ago on Step 3
    were did u get the plastic for your scope because i got some from a jar and its all foggy and hard to look through, and also how did u glue your scope on, like what type of glue did u use
    chopstx
    chopstx
    12 years ago on Step 2
    i high fived the mirror and i missed. i was so scared i ran out of the room yelling "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!"
    Shut Up Now
    Shut Up Now
    12 years ago on Introduction
    i just inventive a bottom fed magazine for marshmallows. i used a roseart marker with some electrical tape on it so its a snug fit in the mag. then i took a 6 in long piece and dremeled a 5mm thick slit into the side almost to the two ends. i drilled a small hole through the top or bottom of the marker. you insert the marker into the bottom, and then put in some type of rod into the hole you made. the slit is so the marker can slide up and down without coming out. i used a rubberband to auto advance the whole thing.
    bigfootduck
    bigfootduck
    This is an awesome gun! you know what would make it even cooler? make it air compressed instead of you blowing into it. it would be able to shoot marbels 10 times the distance!
    An Villain
    An Villain
    Reply 12 years ago on Introduction
    i have an idea for a true trigger mag marble gun with a curved magazine
    DaLoveGlove
    DaLoveGlove
    is there a way you could safely make this a air compressed nerf gun?
