Introduction: How to Make an Outdoor Electric Candle Light
This instructable will show you step by step how to make a fancy outdoor candle light, but you can place it anywhere you like it.
It is cheaper to do this instructable than to buy a regular outdoor electric light.
Thanks for watching.
Step 1: Accesories You Need to Start This Instructable
Here it is the things that you need to start doing your fancy electric candle light.
-Candle Light Holder, or you can make one, using some wood, but it is really cheap.
-Some electric wire, the amount of wire depends on the position you will place the lamp.
-127V E12 Light Bulb.. The image says 12V but it is 127V, but you can use a 12V and light it with rechargeable batteries.
-Socket for the light bulb
-Switch
-Wire Terminal
-Switch
-Wire Terminal
Step 2: Tools You Need
Here are the tools you need
-Cross Screwdriver
-Scissors
-Electric Tape
-Wire Cutter to make easy the cutting
-Cross Screwdriver
-Scissors
-Electric Tape
Step 3: First Step. Disarming the Light Sockett
Disarm the light socket to make the wiring easier.
You will need the screwdriver for this step, because the socket has screws, and the only way taking them of is with the screwdriver.
Step 4: Placing the Light Bulb
Place the light bulb on the wired socket.
You can try the connection, to make sure it works.
Step 5: Final Step
Place the connection inside the candle light holder, very carefully.
Place it facing downwards, so it looks like a real deal.
Then connect the switch and the terminal to the connection and you are good to go.
Step 6: Final Result
And there you are, you have a fancy Electric Candle Light.
