How to Make Durable Plant Markers
Intro: How to Make Durable Plant Markers
Do you have some overcrowded clumps of spring blooming bulbs around your garden that you need to dig up and divide? Well now (spring) is not the time to divide them, so what you need is some inexpensive but durable markers to mark the spots. Spring blooming bulbs should be divided during the summer after all the foliage has died back and the bulbs have gone dormant but by then it's difficult to remember where the bulbs are and what type or color they are. So let's make some aluminum plant tags so we'll know where to dig.
STEP 1: Tools and Materials
To make these plant markers you will need:
- an aluminum can (A bit thicker metal is better, aluminum step flashing is about perfect.)
- heavy gauge wire. I used aluminum clothes line wire because I had some on hand and that worked great.
- needle-nose pliers
- wire cutters
- a hole punch
- scissors
- fine tipped ball point pen or other engraving stylus
- wire cutters
- a hole punch
- scissors
STEP 2: Cut Up the Can
Cut the aluminum can into small strips using the scissors. The metal is very thin and easy to cut though a little awkward because of the round shape of the can. You can make 18-20 labels from one can if you keep them fairly small. After cutting up all the pieces use the hole punch to make a hole near one edge.
STEP 3: Cut and Bend the Wire
Use the wire cutters to cut your wire into 6-8 inch lengths. Bend one end into a loop but leave a gap to slip the label on. Now use the ballpoint pen (or a nail) to engrave your label tab with the name of the plant. Don't worry if the pen doesn't leave much of any ink. You're just trying to engrave the soft aluminum not mark it with the ink. Slip the label onto the wire loop and finish closing the loop with the needle nose pliers.
STEP 4: Place the Marker
That's it! Now you just need to take the marker outside and stick it in the ground near your overcrowded clump of bulbs. You may not want to stick the marker right in the middle of the clump since you might damage a bulb by piercing it. That's not so much a concern with cheap crocus or daffodils but with my expensive lilies I'm much more careful to avoid poking into a bulb.
14 Comments
Shawn Harper 2 years ago
I just made the trommel - and have a ton of spokes. Do you have any specifics on how you'd adapt this for using them? The steel in spokes is much much harder to bend than the aluminum wire.
metqa 9 years ago
I like your instructable. I tried using cans to make strips I put directly in the dirt, but I like your stake idea better, plus it holds the label up higher where it can be seen easier. It's practical and can be art if you sketch an image, doodle, or some other art on the label with the plant name. I sketched the leaves of my thyme plant on my marker. Thanks again for the great instructions and idea.
aleciabane 9 years ago
Thanks for this wonderful ideas! I like markers but mostly made by me. I create my plant markers myself using designed and high quality stone. I like your ideas of creating markers.
https://www.idealgardenmarkers.com/ideal-stakes-and-nameplates/
alisonb 12 years ago
kenbob 12 years ago
Mrs Fixit 14 years ago
should save us a fortune, I always try to re-use whenever possible as part of Eco-schools.
I even have all the tools necessary so no cost outlay.
THYMETOCHAT 14 years ago
SteveGerber 14 years ago
megmaine 15 years ago
amanda86 15 years ago
SteveGerber 15 years ago
GorillazMiko 16 years ago
SteveGerber 16 years ago
wocket 16 years ago
