How to Make Organic Planting Pots Using Old Newspapers
Intro: How to Make Organic Planting Pots Using Old Newspapers
This is a great way of making your own organic planting pots. The final product (ie the pots) are great for your small plants, they can be put very tightly together and when the plant is ready to be put into the ground you can plant it with pot still on. The paper will gradually break down in the ground.
On the market there are a few different tools to make this pots, this is an easy way using things you probably already own.
STEP 1: What You Need
Newspaper
Bottle
Pair of scissors
Soil
(seed)
Bottle
Pair of scissors
Soil
(seed)
STEP 2: Basic Cutting
Use your bottle as a guide to see where you should cut the newspaper. I like to cut several pages each time.
STEP 3: Wrap the Paper Around the Bottle
As seen in the picture
STEP 4: Folding the Bottom of the Pot
Using finger of your choice, fold excess paper towards bottom of bottle. It is useful in this step if bottom of bottle is slightly concave.
STEP 5: Flatten the Bottom
Remove pot from bottle. If you look inside the pot the bottom will be raised. Use fingers or knuckles to press bottom flat.
STEP 6: Fill With Soil
This is what makes the pot steady. Without soil it will disintegrate in a few second.
STEP 7: Final Planting
Plant your seed, water and try to remember which kind of seed in which pot... Or make nice-looking tags.
It is useful to put the pots together as this will create a great climate for growing plants. When you water the plants the water will gradually diffuse into surroundning pots making the maintenance of pots easy.
95 Comments
lordgarion514 5 years ago
Most newspaper is bleached with hydrogen peroxide, which is quite literally listed as an INorganic peroxide.
It most definitely is not organic.
bettbee 2 years ago
Inorganic peroxide might actually be allowed in organic agriculture, as it is a relatively harmless molecule.
And actually, I'd worry much more about some of the inputs used prior to h2o2 in the papermaking process :D
Either way, while there are worse things to have next to your plants than a bit of paper with some ink (which in most newspapers is at this point based on soy, not petroleum, (although you'd have to call and ask the periodical in question to be sure) you can get cheap minimally processed unprinted newsprint paper at any art supply store or many places online sold for packing material.
joef164 6 years ago
thank you can you use news papers in a garden
SIRJAMES09 11 years ago
tosodoula14 7 years ago
how do you use newspapers as mulch?
jbaltrun 7 years ago
Such a good idea! I used another article online and made paper pots using PVC pieces, but this is even easier.
mike8899 9 years ago
I am not sure how the true organic gardeners would react to using newspaper to plant seeds in. If the ink in newspaper has soy in it, 90% of the soy grown in the United States is GMO.
sevenofone 9 years ago
You can get newspaper end rolls directly from the newspaper publisher with no ink on them.
lak780 9 years ago
Very usefulll... will try with my 4 year old today... a we plan to plant some vege seeds today... great job
vimzz 10 years ago
Thanks for sharing this creative, simple and environment friendly idea
walkwest 11 years ago
CharlieBoring 11 years ago
Regarding setting pot out into the garden without removing the plant, did your answer mean that if you use just the sheet that you used in the demonstration, that the pot would not harm the growth of the plant?
kahakura 11 years ago
If you have a tray with holes in it, place a rectanglar piece of heavy plastic inside the tray base before putting your pot plants in the tray. Make sure the water will overflow at about 20 mm so the plant does not get too much water.
We do this with native trees in New Zealand that require watering from underneath. They never dry out. Maybe you could try this.
chicks_with_sticks 13 years ago
Mrs.V 12 years ago
GregTraver 12 years ago
Luffchylde 12 years ago
ozi 15 years ago
ac-dc 13 years ago
