Introduction: How to Make Paper Water Balloons.
Instructions on making cheap, easy water balloons just out of a square of paper. If you don't have pre-cut squares, you can make them out of rectangular sheets by cutting them into squares.
Step 1: Folding
First fold your square in half diagonally. unfold and repeat on the other half.
Step 2: Folding
Now turn the paper over and fold in half whichever way you want. (unfold)
Step 3: Folding
push down in the center of the square and the paper should fold inward. Collapse so the paper forms a triangle
Step 4: Folding
Fold the two bottom corners of the triangle to the top. Repeat on the front and back.
Step 5: Folding
Now the paper should look like a diamond shape. fold the two outer corners in. Repeat on the front and back.
Step 6: Folding
Now the most complicated part, at the bottom of the balloon their are two corners that stick out. Fold these into the two triangle flaps. Repeat on the front and back.
Step 7: Inflating
Now to help form corners when inflating, fold the bottom and top corner to the middle and unfold. After you've done that, open up all four sides. At one end of the balloon there is a hole. Blow into it and it should puff out into a balloon.
Step 8: Using
Now you have a cube shaped balloon. you can fill with water or save it. Since it is paper it will absorb water and get mushy so throw fast.
20 Comments
8 years ago on Step 7
that was reallly cool!!!!!! it blew up so fast! this progect was really fun i'll have to teach it to all my friends! thanks!
8 years ago on Step 3
it is really hard, i think there is a certian way you have to fold it in the last step, not just any way you want to. but i am not that good at origami, so i couldnt tell you which way. :)
8 years ago on Introduction
uh....... well....... that was chllenging. i think this triangle thing is called some kind of base and you cant fold the paper in half any way you want to. i had to change the way i folded mine to make it work. the progect is working good so far though. :)
8 years ago on Step 6
it was ok. it was actually pretty easy!
oops! i wanted to post my last comment on the next step! oh well, now you know
10 years ago on Introduction
If you make it out of wax paper won't it last a bit longer before getting 'mushy'?
Just a thought
Toddjwood
10 years ago on Step 4
A detail missing here is to do four total folds up, not two. In other words, fold the top flap's left and right corners up, then flip paper over and repeat for the back flap's left and right.
11 years ago on Step 3
that is hard i did you that
12 years ago on Introduction
Wouldn't a better title for this be paper water bomb? It doesn't seem like much of a balloon to me.
Reply 12 years ago on Introduction
that works also
They just call it that because you have to blow it up.
Agreed. I make these all the time just to throw around and kick and play with when i'm bored to death in class.
Here's another use for it.
https://www.instructables.com/id/Pocket-sized-Explosion/
thats cool but mine just unfold when i do it
kool, ive seen it b4, but yours was more clearer than other ppls, but I made about 20 of em' :) and launched at my brother with my friends, HaHa :]
actually, mine dont get soggy on the outside, only on the inside, they last like 10 minutes before the turn to mush. what kind of paper are you using?
normal printer paper
hm,wierd, so am i
......this has already been posted......a couple times i think......
ok, good to know?
