How to Make Wrap Pants
Intro: How to Make Wrap Pants
These pants are great for any shape and at any length.
STEP 1: Supplies
Sewing machine
Thread and bobbin
Scissors
Marking chalk
Iron & ironing board
Tape measure
Long straight edge
Pins
Two D-rings
2” strip of sew of Velcro
Need
Hip and waist measurement
Desired pant length
STEP 2: Iron Fabric
Fabric should be pre-washed to avoid any shrinking.
With most cottons, use the steam setting to get out all wrinkles.
STEP 3: Lie Out Fabric
Lie out fabric two layers, right sides together:
You want to use the finished edges of the sheet to your advantage.
I use the bottom of the sheet for the hem, and the side of the sheet for the back because back will be on top with a finished edge.
If you use the top of the sheet for the hem the pattern might be upside down and the hem would be 3 or 4 inches wide.
STEP 4: Mark Hip Width
When using common fabric you can only get 45" wide.
I would finish all sides of the fabric first if you are not using a finished sheet.
STEP 5: Mark Center
If you prefer, on your second pair of pants you can move the center over towards the front. This will give you more of a wrap around the back. Or move it towards the back for more wrap around the front.
STEP 6: Place Pattern
Place pattern with back hip on the left side towards the finished edge of the fabric and crotch at center mark.
Place front pant leg so that the front crotch touches the back crotch.
Make sure bottom of pant legs are flush with bottom hem of fabric.
If you are making knee length pants mark a perpendicular line to the grain line on the pattern where you want the length to be.
STEP 7: Mark Top of Pattern
(this point may vary depending on pattern used).
STEP 8: Mark Crotch Curve
STEP 9: Cut Out Pattern
STEP 10: Sew Crotch Seam
Normally I use an over lock stitch then seam, but may people do not have a serger.
STEP 11: Press
Press seam open.
STEP 12: Make Waistbands
Cut two stripes for front and back waistbands 5” wide
For the front: take waist measurement and add 5”
For the back: take waist measurement and add 12”
STEP 13: Press
STEP 14: Sew
STEP 15: Turn and Press
Turn and press both waistbands.
STEP 16: Turn Under
Press front band under ½” on each long side
STEP 17: Turn Under Back
STEP 18: Insert Waistbands
Find and mark both bands in the center.
Sandwich the pant front and back into the waist bands, lining up centers. Pin.
STEP 19: Sew
STEP 20: Insert D-rings
On back waistband place both D-rings on one end and fold back 2” as shown and sew end towards the wrong side.
11 Comments
dhawktx 11 years ago
Also, if you reverse the overlap they don't 'flap in the breeze' when you walk, but it's also more secure if you use ties on both sides. It is easy to reach in at the front to untie them for those bathroom visits, then just bring them back under the front overlap and tie again at the front waist. Make sure your overlaps are straight and you're done!
organic frances 12 years ago
I actually have a pattern from Birch Street patterns that came without the ties in the pattern.
Apparently, it's possible to tie both front and back?
Just trying to remember how this works for the bathroom...
Long ago, again in the '70's, I had some kind of wrap around skirt/dress thing.
Lots of ideas here, and
Thanks.
phoebeh1 12 years ago
created-by-jen 12 years ago
blloyd4 12 years ago
Bonnie
sawyer1022 12 years ago
csprinkle 12 years ago
I say make them the way you prefer I like them tying in the front because it's easier to use the bathroom among other things!
branwren 12 years ago
