How to Make Your Goldfish Thrive @ Home
Intro: How to Make Your Goldfish Thrive @ Home
The goldfish bowl is an outdated fish torture device. Learn how to care for these fish properly.
STEP 1: Tank Size
For (long bodied) common/comet/shubunkin goldfish you will need 200 litres (50 gallons) for the first one and 80 litres (20 gallons) for each additional.
For fancy goldfish (fantails,pearlscale,celestial etc) you should have 80 litres (20 gallons) for the first one and 40 litres (10 gallons) for each additional.
Long bodied goldfish and celestials should be kept in a species only tank.
STEP 2: Filteration
Like all fish goldfish need filtration.
You should buy a filter capable of filtering the tank water 10 times an hour.
So buy the most powerful filter you can afford.
You will also need to cycle the aquarium
http://www.cichlid-forum.com/articles/fishless_cycling.php
This can take up to 4 weeks.
STEP 3: Feeding
A goldfish has a stomach about the size of its eye.
I would feed a small goldfish the amount it can consume in 2 minutes every day
and a large goldfish a larder amount daily.
Choose a goldfish food containing low amounts of flours and wheats and higher amounts of vegetation and meat such as worms and shrimp.
STEP 4: Maintenance
# Do 25% water changes weekly using a siphon.
# Always use water dechlorinator. This removes the chlorine and chloramines. from the water.
# Add a little aquarium salt to help fight infection about 1 tsp per 20 litres (5 gallons).
# Wash out the filter cartridge in old tank water monthly. Do not rinse the cartridge so much that all the bacteria comes out of it, or you will have a re-cycle and your fish will die. Just rinse the cartridge a little so water flow is normal.
STEP 5: Adding the Goldfish
Only add one fish a week so the filter can handle the bio load.
1. Float the bag the fish is in for 15 minutes.
2. Add 1 cup of your cycled aquarium water to the bag.
3. Wait 10 minutes.
4. Gently net the fish into the aquarium and discard the bag water.
3. Wait 10 minutes.
STEP 6: The End
Please comment, question and make suggestions so i can improve on my instructable.
37 Comments
profquatermass 15 years ago
The food simply passes along its intestinal tract and what is not absorbed falls out.
So if you over feed your goldfish, you get masses of solid looking poo strings.
And as this hasn't had all the protein removed, it really pollutes the tank!
Most commercial goldfish food is designed for small young goldfish which do need a little higher than normal amounts of protein.
But once the fish is over say 3" in length, switch to a very low protein food like peas, etc. with animal protein fed only occasionally.
chuckr44 15 years ago
http://thegab.org/Articles/GoldfishInternalAnatomy.html
"Fancy goldfish don't have a stomach like ours, it's more like an enlarged continuation of the intestine. "
or if you like a second opinion:
"food moves down through the esophagus to what would be the stomach if they had a stomach (which they don't). Muscles in the esophagus squeeze excess water out of the food. The goldfish intestional tract is a long tube."
http://thegab.org/Articles/GoldfishNutrition1.html
or
"Goldfish differ from most tropical fish in that they lack a stomach, so they will produce more feces and wastes when an excessive amount of food is offered. Thus it is essential to feed them the proper amount of food and to regularly"
http://www.petgoldfish.net/goldfish-care.html
again...
"Most unusual of all - even among fish - they have no stomach. "
http://www.happy-goldfish.com/blog/category/goldfish-biology/
I suppose some unknowing people call it a stomach because that's where the food goes first so surely it must be called the 'stomach'. :-)
Technically the first area after the esophagus (think throat) is called the "anterior intestinal bulb" in Goldfish. It's just gut. Not a stomach at all.
Koi are the same as are quite a few other fish.
With a goldfish, if you put in too much food, you get out food purée ;-)))
MakerBreaker 14 years ago
profquatermass 14 years ago
Yes it's a myth that they have stomachs the size of their eyes, just like it is a myth they have stomachs.
If you did a lot of research, then you'd be able to quote people, web sites and scientific papers that back you up like I did.
Sorry but saying you asked some staff in a fish shop doesn't cut it. It is well known that staff in local fish shops are usually non-qualified in any fish-based biology. But I'd be more than happy if you quote their name and cite their sources. :-)
Goldfish do not' 'have stomachs. Why do you persist in thinking they do?
All you have to do is walk up to a college or veterinary building and ask a Vet or fish biologist. They'll set you straight. :-)
maxiaxie 14 years ago
Now, goldfish DO NOT have stomachs. However, their intestines act like a stomach, filtering out nutrients. Just accept that.
And Profquatermass, stop acting like a baby and accept that some people believe urban legends. Do you believe that goldfish have 10-second memories? They don't. I've trained goldfish, koi carp and swordtails to respond to colours with different actions. My axolotls are now obsessed with the colour yellow that they attribute to feeding-time (though axolotls aren't fish, they're amphibians).
TheBestBud 2 years ago
fought piranhas 14 years ago
Grooby 14 years ago
I found these in a fish Shop in Lower Hutt, Wellington, New Zealand, it has been verry good cleaning the algae my tank. But dont know about other parts of the world.
www.thinkfish.co.uk/fish/Sucking_Loach/
Grooby 14 years ago
Grooby 14 years ago
I3uckwheat 13 years ago
goldfishandbetta 9 years ago
juicymoose 12 years ago
