How to Open a Locked Door the Macgyver Way.
Intro: How to Open a Locked Door the Macgyver Way.
I learned how to do this when i got locked out of my dorm at BYU-Idaho and it works great!! and all it takes is things you can find in your friends room or from the hall.
Supplies needed:
Paper
Floss
Vacuum Cleaner
(the pictures are from different doors because my camera is acting wack, but you should get the idea)
Supplies needed:
Paper
Floss
Vacuum Cleaner
STEP 1: Tie Floss to Paper
take your floss and tie it to your piece of paper
STEP 2: Slip Paper Over the Top of the Doorway
now take your piece of paper floss combo and slip it through the top of the door. this may take a little finesse, or another sheet of paper to shove it through.
STEP 3: Lower Paper
Now that you have the paper over on the other side of the door lower it down until you can see it under neath the doorway
STEP 4: Grab Paper
you should be able to see the paper. if you cannot grab it with your fingers then a captured hanger works great to fish it out.
STEP 5: Tie Floss to Vacuum Cable
now that you have the floss through both the top and bottom ends of the door tie the floss to the vacuums cable at least 4 or 5 feet away from the plug.
STEP 6: Push Cable Underneath Door and Pull on Floss
now what you want to do is push the cable underneath the door a little ways. and then gently pull on the floss. you'll want to go slowly so you don't break the floss. but pull on it till you think the cable is about where the doorknob is and try to hook it over the doorknob. this may take a few minutes but eventually you should be able to hook the doorknob.
STEP 7: Open the Door
once you've hooked the doorknob take hold of both ends of the cable and pull back and forth and try to turn the doorknob. this too can take a few minutes but just push on the door a little and be patient and you should be able to turn the door knob and be back in your room!!
STEP 8: Disclaimer
this may not work with all doorknobs/ doors
for example just looking at the door knobs around my house it won't work with a doorknob that doesn't turn when its locked and if you have stuff hanging on the back of the door it may block the floss and paper from going down or from the cable coming up. also some cables may be too smooth to grip the doorknob.
please don't use this to break into peoples rooms. your just going to get caught, it takes several minutes and is very obvious.
thanks for reading though, this is my first Instructable so please give constructive criticism. but i thought that the world needed to know how to open a door with floss, paper, and a vacuum. thanks for reading!!
68 Comments
MatthewP233 6 years ago
MuhdS16 7 years ago
AuraeB 7 years ago
It works! Just used this to unlock the door to our upstairs studio where the cat was locked in. After an hour of trying to pick the lock, this worked in less than 15 minutes! Thank you for the method. It will come in handy with a toddler.
AdrienneK3 7 years ago
MaddyS8 7 years ago
THIS ACTUALLY WORKS I JUST BROKE INTO MY OWN ROOM AFTER LOCKING MYSELF OUT AND IT WAS GREAT
susanrm 8 years ago
Thank you thank you thank you!! I had tried everything else, but this worked. Dental floss failed because it got caught in a seam in the wood and broke, but I have strong fishing line that worked. Also, the phone cam trick was a huge help.
DoctorEww 8 years ago
I tried this, and it worked. More interestingly, I found that having a smartphone with a forward-facing camera helps a ton. If you open your camera app, you can push the phone under the door just enough so that the camera is looking straight up at the handle, but you can still see the screen. It serves as an extra eyeball you can stick under the door. And if the room you're trying to access is dark, just turn on flash mode. The screen will brighten more than usual. If you push the phone under the door just barely, the light from the screen will largely bounce off the bottom of the door, and right back into the camera lens, making the image even easier to see.
laurelo 9 years ago
I stumbled on this method and IT WORKED! I got locked out of my closet and my brother got me in!! Ingenious!! The only thing he changed was he wound duct tape around part of the chord where he thought it would land in the knob.(so it would attach easier)..it took a while and then it popped open! Come to find out that I had 2 purses hanging on the knob which made it even more difficult, but he did it!!
rhino21 14 years ago
ste0 9 years ago
agreed, we have a twist button lock where the knob locks up, so the rubber cord is not able to turn the knob at all
ystockdale 10 years ago
bimmer31 10 years ago
asaphk 11 years ago
Took 3 minutes...
used a regular electric cable and fisherman's string...
bbuenaventura 11 years ago
kewrw28 11 years ago
the_hackers 12 years ago
ayantifovich 12 years ago
fullmoon2day 12 years ago
nosut 13 years ago
