How to Play More Than 10 Games With R5sdhc
Intro: How to Play More Than 10 Games With R5sdhc
Just as we knew,now r5sdhc cracked 10 game slot limited,which means we can use r5sdhc play more than ten games at one time and the official team has confirmed this news as well and following is a detailed guide on how to use r5sdhc to play more than 10 games on N3DS V4.5+.
STEP 1:
1.Download r5sdhc “DiskWrtier Tool ” from http://www.modchipfactory.com/r5sdhcanother-3ds-game-card-to-support-3ds-games-on-3ds-latest-system-firwmare-or-new-n3ds-p-28.html , unzip it,open the folder and you will get these files
STEP 2:
Download latest template file from official site and put it into the same directory with diskwriter.exe,then the new updated template file will cover the old one.
STEP 3:
play 10 games what you like them mostly by R5.(we called this "10 game" for short),Backup any one "10 game" as the first file in your micro sd card , then backup "10 game"(the game not in 10 list) as the second file in your micro sd ,then insert the micro sd card into your PC, right click on r5 “Disk Writer V100″ icon and Run it as an Administrator to make sure that it has all of the necessary privileges, then select the microSD reader you’ll be using.
Attention : even you can play 100 games so far ,but you still only can save 10 games . As the records are in kernel ,even us are unable to store more . Be sure that you have 10 favorites to play and save without problem at first .
STEP 4:
DiskWriter will then ask you to format your microSD card
STEP 5:
Click “Ok” to confirm, and once you’re done with that, ”DiskWriter V1.00″ tool is running normally ,then Choose “File”->”Format”
STEP 6:
Again, there is a important warning to inform you that ” Formatting the dirve will destoryALL information on it! Are you sure you wish to processed? ” click “Yes” to confirm, then another warning inform you once again, click “Yes”, after format finished , Choose “File”->”Write” and choose your favorite 3DS roms and then its will be written into your microSD card in a few minutes;
STEP 7:
With your games flashed and ready, put your microSD card into the flashcart and inserted it into your 3DS, the first game will automatically show up like a normal cartridge .Play "10 games " as normal then click switch button . When blue LED keeps flashing , eject your micro sd at once .Insert micro sd card again .Then screen will show "10+ game" .Press and hold the switch button for 2 seconds and let go .If you see the blue led is flashing , then you can go on to play "10+ game"
