Introduction: How to Put a Lightsaber on Anything
this instructable will teach you how to put a Lightsaber onto any image, just in case you were wondering. You`ll need to download a couple of stuff, so, if you don`t want to download GO BACK Now. For the rest of you, go to the next step.
Step 1: Downloads
Here are some links for you to download. If they don`t work, please contact me. Both of these downloads are for Windows 2000 and above.
The first download you will need is a Lightsaber Making Program (LS Maker) -http://lsmaker.uw.hu/page.php?main=lsmaker.html#lsmaker - Then click where it says "here". This download will only take a few seconds.
Now, you will need to download GIMP (optional) - http://sourceforge.net/project/downloading.php?groupname=gimp-win&filename=gimp-2.6.6-i686-setup.exe&use_mirror=softlayer
This one may take a while.Again if any of these downloads doesn`t work, contact me.
Step 2: Get a Good Image
Get a good image to put your lightsber on, and a good image of a lightsaber (or just its handle)
Step 3: If Using Gimp...
If your using GIMP, follow this procedure:
Cut out the handle of the lightsaber.
Select the part you cut out by clicking "select" then "floater". Copy that.
Now, open the image of the kangaroos (or whatever) and click paste.
Resize it using toolbox.
Flip as needed using toolbox.
Save that image (with preview)
Proceed to next step.
Step 4: LS Maker
-Continuation of "If Using GIMP..."-:
Unzip file
extract files
open LS Maker
click "File" then "New"
Select color
The same one will come up... select blade
Click "Add" and select image
Left click where you want it to begin and right click where you want it to end.
If you want two lightsabers, run through the process again,
If you skipped using GIMP...
Unzip file
extract files
open LS Maker
Select color
Again, if you want two lightsabers, run through it again/
Here are the differences..
Step 5: Export
Export your image as "JPEGs" , turn cuality down to 87, add name and your done! Wow, great job! Give yourself a round of applause. Please post comments. Please tell me how to make this instructable better.
