How to Remove Tune-o-Matic Bushings From Les Paul Style Guitar
Intro: How to Remove Tune-o-Matic Bushings From Les Paul Style Guitar
This is a quick and easy way to remove Tune-O-Matic bridge and tail piece bushings from a Les Paul style guitar.
This instructable will show how to make a cheap and easy to use
tool that can be used to remove the bushings for repair and
for repainting/refinishing.
STEP 1: Tools and Parts Needed
The tools that you will need.
Bolt that will fit the bushing (usually metric).
Piece of pipe about 25mm in diameter and about 10mm shorter than the bolt.
1 washer that will fit loosely around the bushing.
1 washer that will fit the bolt.
Note:both washers must be larger OD than the pipe.
A wrench that will fit the bolt (if the bolt is metric the wrench is too).
STEP 2: Assembly
First you have to put the washer that fits around the bushing
over the bushing like in picture.
Then take the washer that fits the bolt and put it on the bolt.
Then take the piece of pipe and put it on the bolt/washer assembly.
Now put the bolt assembly on to the washer around the bushing
and thread the bolt in to the bushing by hand.
STEP 3: Remove Bushings
Now just put the wrench on the bolt and turn like you were tightining.
STEP 4: Final Word
This tool can be really helpful in working on guitars
and here are some tips and tricks.
While sanding and painting put a pice of cotton or wadded up cloth in the holes to keep dust and paint from getting in them.
After painting there will be a lip of paint in the hole so clean the hole out before reinstalling the bushings.
Under the bushing closest to the volume knobs there is a
(or should be)a ground wire be careful with this one and make sure
when you install the bushing that it comes in contact with the wire.
When you take out the bushings brush some wood glue in the sides of the holes and let dry so when you install them again they will have a snug fit.
I think thats all.
If you have any questions or comments please post them
this is my first instructable I need feed back.
Matt, age 14
I think thats all.
Matt, age 14
23 Comments
oalanjones 4 years ago
RobertM724 6 years ago
I took this same concept to my Schecter Omen-6 with the same style bushings. I used two box wrenches stacked on top of each other and the original bolt. Use a cloth to prevent scratching.
davmac 7 years ago
Neat but there's an even easier way. Drop a ball bearing down the hole. Reinsert and tighten the screw and it pushes against the ball bearing and lifts the bushing. No risk of damage to the top either
BenjaminW83 7 years ago
Is there any way to take them out if the threads are messed up?
carranen 8 years ago
simple as efficient!
good job Matt!
cheers
jhodges15 9 years ago
This is awesome. Great job. Saved my life lol
tcm72003 9 years ago
Excellent, worked like a charm (Schecter Hellraiser uses the same stud configuration for the bridge; unfortunately, it has through body strings, so I need to figure out how to remove those). I of course overlooked the length of the spacer/pipe, so I ended up using an old lug nut from a truck wheel, but the spacing worked nicely.
Forgot to also ask, does it typically destroy the bushing when doing this? It looks like there was an "anti' pull-out washer around the top of it, so when the bushing came out, it split apart (not a concern since I am replacing them anyway).
jramey3 12 years ago
moogbeatz99 13 years ago
dr_delgado 14 years ago
Farewell88s 15 years ago
hick252x4 15 years ago
tomvv11 15 years ago
scafool 15 years ago
johnanderton 15 years ago
thomas_c 15 years ago
I guess I'll do it that way if I ever have to do it. (b_)b
xoxota 15 years ago
