How to Repair Windows 10 Recovery Loop Error Without a Reinstall
Introduction: How to Repair Windows 10 Recovery Loop Error Without a Reinstall
About: I had a long break in my online activity, bad things happened in my life and i'm still trying to recover, sorry folks that i was away for a long time and please be patient with me, i will be better in time, i …
Now for the problem, sometimes, Windows 10 like Windows 8 and Windows 7 too, try to fix a startup error that doesn't exist. I managed to replicate this error on my Asus EEE PC 1015P more that one time with Windows 10. I send the nice people from Redmond, the example and all the steps to do that and perhaps to release a hotfix, sometime in the far future :))))
Now this can happen to you in Windows 7, 8 and 10 and the fix is really easy. We gonna recover the registry hive from the registry backup folder that is automatically created by Windows.
This will help you avoid a reinstall (Windows 7) or a reset (Windows 8 and 10).
This is the fix for the ominous and ubiquitous recovery loop bug aka boot loop bug aka infinite loop bug.
NOTE:
- ALL COMMANDS THAT NEED TO BE TYPED ARE BETWEEN " " CHARACTERS (example "C:") when typing you WILL NOT INCLUDE the " " characters
- WHEN YOU NEED TO HIT A KEY IT IS SPECIFIED BETWEEN < > (example )
Step 1:
Hit and enter boot options see [image 2]
there choose Troubleshoot followed by Advanced options see [image 3]
there choose Command prompt see [image 4]
Step 2:
type "C:" then hit key followed by "DIR"
if you don't see Users and Windows folder then try "D:", "E:", "F:", and so on followed by "DIR" until you see the named folders.
Step 3:
Now that you found the correct drive, we go to fix the registry
type "CD \windows\system32\config" then hit
type "DIR" then hit and check that the following files are present in there:
SYSTEM, SAM, DEFAULT, SECURITY, SOFTWARE and the folder RegBack
Step 4:
All is present, now we gonna make a backup of the current registry hive before we are gonna fix it.
type "MD my_backup" then hit
type "COPY *.* my_backup" then hit
Step 5:
Now we gonna check if we can restore the registry,
type "CD RegBack" then hit
type "DIR" then hit
there need to be a DEFAULT, SAM, SECURITY, SOFTWARE and SYSTEM, and all of then need to have a size that is greater that 0. If not then you cant use this method.
Step 6:
Now that all is checked and all is OK, we gonna
type "COPY *.* .." then hit when prompted we gonna type "A"
after copy is done, we
type "EXIT" then hit
now we gonna restart the PC.
ADDENDUM:
C: -> change the current drive to drive C, D: -> change the current drive to drive D, you got the idea
CD \windows\ -> change directory to the path that follows, here is windows folder
DIR -> displays the content of files and folders of the current directory
MD my_backup -> make a directory with the name that follows, here the name is my_backup
COPY *.* my_backup -> copy all from current folder to the folder that follows, in our case my_backup (all is *.*)
COPY *.* .. -> copy all from current folder to the folder above in the folder structure (if current folder is C:\windows\system32\ then it will copy all to C:\windows)
EXIT -> exits command prompt session.
UPDATE : (2.10.2016)
To be more secure and to be sure you got a working copy of the registry hive files developed a method of backup for it that always keeps the last 30 days in a folder of your choice.
Lets gets started ...
#1 - Download Cobian Backup from (www.cobiansoft.com/cobianbackup.htm) get Cobian Backup 11 (Gravity) OR Direckt Link (http://files.cobiansoft.com/programz/cbSetup.exe) and install it, choose run as a service and choose current user as user account for the service (multi user enviroment works with system account but some network services for Cobian will not work).
#2 - Open Cobian Backup 11 Gravity and choose List from left up menu. There choose import then import the configuration file i provide here (the file with LST extension)
#3 - Now you have a task on your left part of the window called RegHiveBackup, right click it and choose Edit Task , then choose Files and change Destination in the right lower part, select H:\RegystryHiveBackup (yeah i have it written with Y, i got a backup of the backup folder that is named with I), click it and choose edit from bottom, now input the new folder and path to it (i use a external drive mapped as H on my system, do not choose C drive, its better to have stuff stored on another drive). DO NOT HIT OK BUTTON YET !!!
#4 - Now choose from left panel Schedule and go to time and change it according to a time where you are sure that your PC is up and running every day, then hit OK button from lower part.
ADDENDUM: if you want a bigger backup list , or a smaller one, right now it is 30 days. go in same place and chose Dynamics and there change the value of 30 from Full copies to keep to anything you need, the backup is taken daily and that means days = number of full copies to keep, if it is taken 2 x every day then 2 x the number you write there too.
Be the First to Share
    • Arduino Contest
      Arduino Contest
    • Barbecue Speed Challenge
    45 Comments
    neumanngregor
    neumanngregor
    4 years ago
    Hope my update will help you people, the recovery is the same as from the RegBack folder made by windows but this is made by you, and you got 30 chases more to fix it. BTW, the backups are zipped by Cobian Backup, unzip them before starting recovery. If needed i will add pictures to setup Cobian Backup.
    RonM152
    RonM152
    3 years ago
    THANK YOU!!! THIS SAVED MY COMPUTER!!!
    MichaelN296
    MichaelN296
    3 years ago
    this was a lifesaver. I was dreading reloading windows and starting over. Thank you very, very much.
    neumanngregor
    neumanngregor
    Reply 3 years ago
    Happy it helped you, use the Update of my instructable to keep your PC always safe with that method.
    AndrewJ152
    AndrewJ152
    4 years ago
    I have nearly the same problem. Only difference is, C:\ is my only drive and it's Directory says "File not found". What am I supposed to do now?
    neumanngregor
    neumanngregor
    Reply 4 years ago
    Have you flowed the tutorial's steps carefully? Even if you have a single drive C: when you are in recovery environment there are more that your C: and it can be that your C: has a different drive letter in this enviroment. Try find it this way.
    AndrewJ152
    AndrewJ152
    Reply 4 years ago
    I am also using a Win 10 image on a usb I used to install with (was Win 8 originally, but I have put Win 10 on it) to boot. cmd prompt starts on X:\sources>. X has all the windows stuff, and so does E. So why is it not C? That's what my pc showed was my drive before this boot loop. So which one of these do I use to follow the steps above, E or X? Alternatively, should I use diskpart to clean my drive and do a fresh install?It's been a long time since I've used commands, and things are a little fuzzy for me. I 'm not too concerned at this point about losing anything, as I've had to replace everything before, but it is a process that takes a while to remember exactly what programs I'm missing.
    neumanngregor
    neumanngregor
    Reply 4 years ago
    X: is the virtual drive that is created and exist only when you are in the repair environment (is NOT permanent ), I check in sequence all the drives starting from A until I find the right system drive, then I check the files if they are present and have a size, size is different from zero. Flowing the tutorial carefully you shud be able to do it.
    NatalieC48
    NatalieC48
    4 years ago
    I wish I could check if this would work. Unfortunately where you fix starts I can't get to. I'm not even sure what caused the BSOD. I was studying and doing an assessment and the desktop froze. I tried to re-boot but the keyboard did not respond. Eventually I had to do a switch off the desktop and when I tried turning it on the BSOD started. (1) It gets to the start up up screen and before I have a chance to select book optins etc I get the (2) BSOD. At this point all I get is bad stop code error and nothing else. No option for troubleshooting or boot options.(3) Windows defender attempts to fix offline and (4) I then go in to the loop. Any suggestions on how to fix this without getting troubleshooting or boot options I can get in to.
    neumanngregor
    neumanngregor
    Reply 4 years ago
    You can try to boot a Windows PE environment or a Linux from CD/DVD/USB and use the above mentioned method to restore your registry hive, this is the last possible option to fix those boot errors, it works on boot loop and it can possibly, if the error isin the registry, fix your BSOD too.
    EnriqueWilliam
    EnriqueWilliam
    4 years ago
    If someone need Windows 10 Product Key,you can go to www.Office2016Keys.com to got.. My Windows 10 Product Key bought here. It's cheap and genuine.
    don_luis
    don_luis
    4 years ago
    hi,
    i tried this and sadly it did not work for me, i still get the infinite loading screen. i tried everything i could think of - updated drivers in save mode, deactivated all the devices the system does not need, tried sfc and dism, tried to downgrade, applied this fix three times, ran multiple chkdsks, gave windows startup repair two tries, but nothing changed. i never had problems like this until yesterday when itunes updated and i needed to restart my computer. my laptop is up to date in terms of windows, there are no new microsoft updates. i have an hp pavilion with intel i7 and an nvidia graphics card. do you have any other ideas what i could do? reinstalling windows is not really an option, since i use my pc primarily for making music and setting everything up again would easily take me a week. thanks in advance!
    neumanngregor
    neumanngregor
    Reply 4 years ago
    This happens only if your backup files are corrupted too, sadly you can only try repairing with a install disk or install usb, if this does not work then you just need to reinstall windows and after you setup your programs use a partition backup software like Macrium Reflect Free to make a "image" of your c: drive, if your windows goes bad you just plug a usb or cd/dvd and start the Macrium Reflect recovery enviroment and from there you choose the "image" file and voila your windows is back like it was when you made the image. BE WARNED too keep your loop/sample and projects not on drive C:, they will be overwriten if stored on c and restore it from "image".
    Denver Jones
    Denver Jones
    Reply 4 years ago
    Then, after reinstalling windows all of my data will be wiped out. Can macrium reflect still backup or recover the wiped out data before reinstalling Windows?
    Sabzer0
    Sabzer0
    4 years ago
    Instead of listing the DEFAULT, SYSTEM, SAM etc, my RegBack folder is empty. What should I do?
    neumanngregor
    neumanngregor
    Reply 4 years ago
    Then you can't recover the registry hive and you will need to reinstall, after reinstall use the method i described in my update at the bottom of this instructable to backup the registry every day and always have the last 30 days snapshots recovable when you will need it.
    Cowboyfan
    Cowboyfan
    4 years ago
    thanks for posting these instructions.
    I followed them very diligently.
    Initially it seemed to work for me but I am back in the loop.
    As I have had this problem a couple of times before (and I cannot recall how I got past it before) I regularly backup my files and have created a repair disk. The repair disk does not help right now. I am now trying another reset to see if that works.
    I have been on the phone with both Windows and Lenovo all night. Since I bought my laptop in 2009/2010 with Windows 7 Pro preinstalled and used the free upgrade to Windows 10 I do not have a OS disk to reinstall. I do still have my Windows 7 Pro OEM product key. Any ideas on how I can get a Windows 7 Pro OEM OS (after using it for more than 6 months I think I give up on Windows 10)
    neumanngregor
    neumanngregor
    Reply 4 years ago
    Registry files get corrupted by not closing diwn correctly windows or by bad harddisk. Mostly from not closeing windows with schutdown or by not waiting for schutdown cimpletly and pulling the plug, powersurges, sometimes even viruses or bad made softwrare ..., backups are the best optiin or use somthing like macrium reflect (the freeware version is good enough for this) to backup your c partition tigheder with recovery and boot partition (win10).
    neumanngregor
    neumanngregor
    Reply 4 years ago
    Just download the iso from microsoft or from any torrent site that says oem or clean or untouched, input your own serial key and you are done, still the boot loop "curse" is from vista up, sometimes happens to 7 too, the problem is when the registry hive gets corrupted, i will make a script that makes a backup of the registry every dayand keeps a history of the last 30 days in a FILO list with a recovery script. This way even unexperienced users will usr this method easly.
    Cowboyfan
    Cowboyfan
    Reply 4 years ago
    Thanks. I had to get someone to help me with the Windows 7 reinstall. I could not find it on Microsoft's site. I guess there were also many drivers to reinstall after we started from scratch. Now I am sifting through multiple versions of my backup files (better than loosing everything I guess); but, it would help me to know what I need to know to make sure I do not get in the loop, again.
    Some of the details you provided, so far, are too complicated for me to understand (and I usually understand better that the average person but a computer person, I am not).
    The loop did reoccurr the other day, as well. A couple of reboots seemed to correct the issue. I have backed up to an external drive again with an image included. I am not sure I am capable of doing much more.
