How to Repair a Westinghouse L1975NW 19" LCD Monitor
Intro: How to Repair a Westinghouse L1975NW 19" LCD Monitor
The Westinghouse L1975NW monitors seem to have a common failure point and this Instructable will show you have to repair this problem. If your monitor has either a blinking power LED or no power at all then this should be the solution to get it back up and running. To complete this repair you will need the following:
Tools:Phillips screwdriver, flat blade screwdriver, soldering iron, de-solder braid and a pair of tweezers.
Parts: Qty 2 40T03GP MOSFET, Qty 2 220mf 25v capacitor, 1 4amp pico fuse (surface mount)
We have a kit of all parts needed on our web site http://www.ccl-la.com/catalog/product_info.php?cPath=21_35&products_id=28
If you don't have a monitor to repair check Ebay.com, you will find them for sale usually for less than $30 in as-is condition, just be sure the screen is not cracked.
This repair guide also works for the Acer AL1916 and the Gateway Gateway FPD-1830 as these are the same monitor on the inside.
STEP 1: Back Cover Removal
First we need to remove the back cover. You can start by removing the stand, pull the little cover off the screws and remove the 4 screws under the cover. Next remover the signal cable. Now remove the 4 screws one in each corner as shown in the photos. The next step is separating the two halves of the case. Start on the side of the screen and insert the flat blade screwdriver between the front and back halves. If you apply a little pressure with the case should separate a little bit, now just work your way around the monitor. When you get to the bottom you will need to unplug the two speakers from the control board before the case will separate.
STEP 2: Getting to the Electronics!
Now that the plastics have been removed we need to get to the power supply board. Turn the monitor over face down. Remove the ten screws and nuts as indicated by the yellow arrows, and unplug the backlight tubes - red arrows and remove the metal shield. You will see the power board on the left and the driver board on the right. Unscrew the power supply board and remove it from the reset of the unit.
STEP 3: Lets Do Some Soldering!
With the power board out we can see the blown capacitors that are the cause of the problem ( the 2 parts marked by yellow squares on the right side). When the capacitor go out the damage the MOSFET transistors and that causes the fuse F200 to blow. If you look at the top of the capacitors you should see s slight bulge, that is the easiest way to find damaged capacitors. You will need to replace the capacitors and MOSFETs and the fuse on the bottom of the board. When inserting the capacitors be sure to replace them with the polarity correct, you can see the negative stripe on the side of the capacitor. After the caps and MOSFETS are replaced you will need to turn the board over and replace the fuse marked F200 on the bottom. This where you will need the tweezers because this is a very small fuse, about half the size of a grain of rice.
STEP 4: It Works! ! !
After all of your bad parts have been replaced just re-assemble the monitor and test your work. If everything goes as it should then you now have a working monitor.
Be sure to check out our web site at :http://www.ccl-la.com/monitor_repair.htm for repair guides for other monitors. We are adding guides as soon as we get them laid out.
With luck your monitor should now last many more years.
If you have questions please contact me at:
Buddy Mcsparrin
Corporate Computer
WWW.CCL-LA.COM
Buddy Mcsparrin
Corporate Computer
WWW.CCL-LA.COM
34 Comments
Printerpenguin 1 year ago
K-MartFix 4 years ago
thnx,
KM
waderdog 4 years ago
With THIS monitor for a year or so when pushing the power button, the monitor would power up then off quickly several times and then usually stay on until the next session where I would have to do the same thing - keep pushing the power button on and off until it came on and stayed on. Today - no such luck. No power at all. Westinghouse LCD Monitor Model:
LCM-19V7. I was wondering if this "How To" is the same thing as the problem that I have. I would like to try this repair but I don't want to buy the parts if it's not the same problem. Any help will be appreciated!
mustwatchtv 10 years ago
many thanks
jodo901 11 years ago
Some tips for anyone giving this a go. The positive lead on the capacitors is the longer one. The negative is marked by the bar stripe on the capacitor and the shorter lead. The replacement MOSFETs are much smaller, but the proper orientation for them should be obvious. Make sure you have something that will hold on to that damnable fuse, and don't apply too much pressure holding it down or it may pop of the board like a tiddly wink and you may never find it again. Lastly be careful with the heat as the board traces are a bit cheap and will come up easily. It's better to take your time and have positive results. If you become frustrated or impatient at any point walk away for five minutes. Thanks Again!!!
Chu Guk 11 years ago
cptnKirk 12 years ago
Hello all,
I have followed the steps here and have looked at caps there are 6 side by side that are poped up is this bad news or just replace them all? and MOSFETS as well?
Ok with further looking i see no MOSFETS as in your picture my monitor is westing house lcm-22w3 also if im correct i see 12 small i would guess fuses which one is right 1 and is there any way to tell if ones bad?
cclla 12 years ago
http://www.ccl-la.com/blog/index.php/category/monitor-repair/westinghouse/
ok missed a read i found fuses still need to know what to do if there are not any
mofets? ty.
I would think Radio shack would have these parts?. thank you for your reply.
ybuba 12 years ago
L1975NW.
ybuba 12 years ago
desperate need for kit. what can i do. please reply asap. thanks
cclla 12 years ago
cclla 12 years ago
jtc10512 13 years ago
ninjastylemafia 13 years ago
I have almost the same issue as everyone, but I can see very very dim screen. I have tried to use several computers with the monitor but I only get dim screen and nothing.
I've used this method to repair it but I don't see nothing wrong with board or any fuse or caps blown up.
The only thing I can think is that the lights are gone. "(reader) need your thoughts on this"
can any one tell me where I can get the lights from? that is if you (reader) think that the lights are out.
its 19inch Westinghouse L1975nw Monitor.
I hope I've explained enough.
Please reply with feedback.
Thanks.
Ninja
cobaka 13 years ago
phoenix_up 14 years ago
jacfar 13 years ago
dualmule2 13 years ago
