Introduction: How to Replace Brake Pads and Discs on a Porsche 944
Here you will see how to replace worn brake pads and discs on a 1989 Porsche 944
Step 1: Jack the Car
First, jack the car for a save and secure stand.
Step 2: Clean the Caliper
Now clean the caliper so your hands don t get that dirty...
Step 3: Disconnect the Contacts for Brake Wear and ABS
Disconnect the cables. Upper ist for pad wear
Step 4: Remove the Pads
This kind of cross holds the brake pads in place. With a big screwdriver you can take it off the upper part of the caliper, but careful.
Fold it down and remove the pads by pulling with a pair of pliers or a screwdriver.
Step 5: Remove the Caliper
Unscrew the caliper. 2 Screws only and secure it with something so the caliper does not fall on the ground. Care is needed. Clean caliper again.
Step 6: Check the Pads
Take the new pads and make sure you do not touch the inner side with your fingers.
Keep them clean.
This is essential!
Here are some pics to see the difference of new and old
Step 7: Remove the Brake Disc
Remove the disc by unscrewing the only screw.
The you will need a screwdriver to take the disc off.
Look at the pics...
Step 8: Just a Picture
This is how it should look like now.
Clean and take off rust. Use a steelen brush.
Step 9: Place the Disc
Put the disc in place and plug in the screw. Keep clean!
Then plug in the pads and secure them w/ the cross.
Step 10: Secure
This is where the cross is pulled in (Watch finger tip)
Step 11: Check and Clean
make sure everything is tight and the disc will turn well.
Clean everything well.
Remember:
I am not responsible for anything you do on your car.
This is only for professional use!
5 Comments
11 years ago on Introduction
I was wondering the process of changing the brakes on the Cayenne's, and what is required. I have installed full brake kits on other cars in the past as well as brake pad changes. The dealer said my Porsche brake pads needed to be replaced soon, and want to charge me $900 to do it. I said f*ck that I can do it myself. Is it true when replacing the pads, that every brake pad sensor wire needs to be changed? Also, my buddy told me it requires a special tool. Is this true? If so were can I order the tool from? Do I have to reset any thing in the menu of the car after the swap? I found the brakes, and sensors on advanced for a little over $200 for everything. I did use the search button, and could find anything. Thanks in advanced
Reply 11 years ago on Introduction
Hi!
First, ask your official Porsche dealer if it´s possible to replace them without having a computer to tell the car...Most of the Porsche and VW need to be told via computer what is going to happen.
The new cars press the pads to the discs every now and then to keep the discs warm for NO FADING when it´s wet.
14 years ago on Introduction
step 2 clean the caliper
step 5 Remove the caliper
step 6 Check the pads
Keep them clean.
I don't know, those hands look pretty dirty to me after cleaning so much.
You have a Porsche and you're doing this yourself?!?
Reply 14 years ago on Introduction
Haha, yeah right. Next time I´ll wear some gloves... My brother helped me taking the pics. Yes, I do ALL by myself, I am a former car mechanic. ;-)
NICE, but you seem to have missed a few important steps 1 loosen wheel nuts/studs before jacking 2 wash coating from disc with brake cleaner before fitting 3 remove cap from brakefluid resivoir and press pistons back into caliper,being careful not to overflow resivoir 4 apply some copper grease/high temp antiseize compound to the back of the pads and caliper where the pads move on it 5 before refitting wheel,gently pump the brake pedal without pressing all the way to the floor until it goes hard,then check that the disc is running freely,refit the wheel,lower jack and tighten wheel studs
