How to Save Water With Your Humidifier.
Intro: How to Save Water With Your Humidifier.
A whole-house humidifier can make you more comfortable in winter, and it can help you be a bit greener by making your house feel warmer, which lets you turn down the heat. But most humidifiers waste an enormous amount of water. Here's how to reduce that waste.
STEP 1: Recycle Instead of Dump
I recently installed a whole-house humidifier on my home's heater. I bought a Honeywell because it was rated Energy Star. Apparently Energy Star doesn't apply to water use, though, because for every gallon it puts into the air, it dumps at least 5 gallons down the drain. It works by trickling water through a filter and blowing air over the filter. Any water that isn't picked up by the air blowing past just goes down the drain.
I decided to recirculate the water back into the humidifier instead of dumping it.
Start with two 5-gallon buckets. Tape the buckets together, bottom-to-bottom, and drill a pilot hole through the bottoms of both buckets. You might also want to remove the handle on the bottom bucket because it tends to get in the way.
Now pull the buckets apart and use the pilot hole to drill a 1" hole in the top bucket and a 2" hole in the bottom bucket. Also drill another 1" hole in the side of the bottom bucket about 5" from the bottom. Check out pictures in the next steps first and you will see why these holes go where they do.
STEP 2: Parts You Need
You will need a pump, a toilet fill valve and hose, and some plumbing parts. I used a $10 aquarium pump from Harbor Freight. The pump has a 1/2" outlet so I needed a few adapters to get it into the 3/16" hose on the humidifier. You will probably also need a copper tee and parts to extend a water line to near the bucket. I'm not very good at soldering copper so I went from the tee to a PVC union and used glued PVC the rest of the way. Put a toilet supply valve at the end and this will have the 3/8" compression fitting for your toilet supply hose.
You probably want the type of toilet fill valve that has the float riding on the valve itself, rather than the old-fashioned type with the stalk and balloon float. The old kind is what I have and you'll see what I had to do to make it fit.
The hard part for me was figuring out all the connections and going from pipe to hose to smaller hose. It took a few trips to the hardware store.
STEP 3: Putting It All Together
Remember those holes you drilled in the buckets? Use the 1" hole in the top bucket to install the toilet fill valve. It will stick out through the bottom of the bucket and into the bottom bucket, whose only purpose in life is to get the top bucket off the floor. Thread the supply line through the hole in the side of the bottom bucket and connect to the valve. Connect the other end to your water supply, just as if you were hooking up a new toilet. Try not to use this as a toilet, though.
Connect the pump to the humidifier (I pulled the hose off the humidifier's water supply solenoid and connected it to a barbed fitting on the pump hose).
Wire the pump to the heater. You probably want to use the heater's "EAC" connections, which provide 110VAC while the heater fan is running (presumably for an Electronic Air Cleaner?). It's best if you can wire through a switch so that you can turn off the pump in summer or when you're not running the humidifier.
Finally, drop a bleach toilet cleaning tablet into the bucket and put a cover on the bucket. This water is going to be going into your air supply so we don't want to be giving anybody Legionnaire's Disease.
Final note: if I hadn't already paid for and installed the humidifier, I would have searched for a water-saving humidifier instead of going to all this trouble. This only makes sense if you're trying to improve an old humidifier but better ones are available now.
15 Comments
RTurnock 9 years ago
I have thought of this but decided no to because of the risk of mold, fungus etc. building up in the recycles water. I also find it impossible to set a tap "just right" even with the little pin hole inserts they provide it's too much waste. My conclusion is to cycle the valve, i.e. when the humidity control is asking for water I plan to put a timer relay between it and valve so I can set what percentage of the time the valve is open.
Yard Sale Dale 9 years ago
Hello. Please tell, what was the result? Did you try the water valve on the main device, to curb water usage/wastage? Did you continue using the bucket collector?
chartle 12 years ago
Find the valve that feeds your humidifier. When the furnace is running and warmed up. Turn down the valve until just a trickle of water comes out the bottom and into whatever drains your system.
Double check every once and a while.
Much less chance of getting Legionnaire's Disease.
Kezz 15 years ago
nate121 15 years ago
quigs999 15 years ago
BigNateMI 15 years ago
steveharr 15 years ago
mowdish 15 years ago
PKM 15 years ago
lukeyj15 15 years ago
richms 15 years ago
lemonie 15 years ago
