How to Set Up a Fishing Rod for Lure Fishing
Intro: How to Set Up a Fishing Rod for Lure Fishing
This is an Instructable to help all the beginners of the great sport of fishing! It will show you how to spool(put line on) a reel and attach it to a fishing rod. PLEASE RATE MY INSTRUCTABLE..
STEP 1: What You Will Need
You will need:
-A Rod
-A Reel
-Fishing Line
-A Lure
-A Scissors
-A Rod
-A Reel
-Fishing Line
-A Lure
-A Scissors
STEP 2: Putting Line on a Reel.
Image 1: The reel.
Image 2: Open The Bail Arm.
Image 3: Tie on line. This is the knot you tie: http://www.animatedknots.com/arbor/index.php
Image 4: Close Bail Arm.
Image 5: If you are a young beginner get a parent or a friend to put a pencil through the line holder so it will come off easier. Remember to keep the line tight when you are loading the reel to prevent kinks and twists.
STEP 3: Mounting the Reel
Image 1: Cut the line when the reel is full but not over full.
Image 2: On most reels there is a line clip on the side. Clip the line in here for now.
image 3: On a rod, near the handle, there is a reel mount that looks like this.
Image 4: Slide the reel into the mount.
Image 5 Screw the mount tight.
STEP 4: Bring Line Through Line Guides
Image 1:Un-clip the line and open the bail arm.
Image 2:Put the line through the line guides.
Image 3:Close the bail arm when there is about a meter of line coming out of the top line guide.
STEP 5: Attach Your Lure
You are almost done!!!!!!!!
Image 1: Tie on the lure. This is the knot I use with my rapala (pictured): http://www.animatedknots.com/rapala/index.php
Image 2: Cut of the left over line.
Image 3: You are ready to start fishing!!!!!
11 Comments
Leg3nd 8 years ago
K-Dawg 8 years ago
A rod's casting weight is a recommend weight range that a rod is capable of casting to achieve maximum performance without damaging the rod. Casting a weight higher than this recommended casting weight could snap the rod. Casting below the weight range wont allow you to achieve maximum casting distance.
Telescopic rods are great for travel uses where you need to pack a rod into a suitcase. Telescopic rods are not your only option however. There are also multi piece rods that come in sections. You can get very good telescopic and multi-piece travel rods. Shimano makes some good value telescopic rods, namely the Shimano Catana spinning rod. As long as you stick to major fishing equipment brands you should get a good quality rod!
Hope this answers your questions!
Leg3nd 8 years ago
spinning rod with 10-30 grams casting weight,also 20$
My only problem is,is the first one srong enough,im a begginner...
I wanna fish for Chub,pike...European classics,i live in serbia,they can grow to 4-7 kg rarely so i think first rod is better for me,but i want a pro's thoughts... :)
K-Dawg 8 years ago
I would personally go with the telescopic rod purely because it's easier to transport. Then again you can also float fish for pike and chub. There are rods specifically designed for pike fishing. The rod you mentioned would be a good all rounder beginners rod that could be used for many applications. The best bet would be to get in touch with your local fishing tackle shop and ask them for recommendations. They will be the most knowledgeable about what gear you should be using in your area. They will also be able to recommend you tackle and hooks etc. that should be used.
Leg3nd 8 years ago
iainman 10 years ago
That's not the proper way to line a spinning reel. You should leave the spool on it's side facing up, then reel it in. (The way you show is for spincast reels) They are designed to reel in fresh line that way. And if it does get knotted or kinked just pull the knot out and flip the spool over. Later on it will be less hassle and less of a chance of your line getting all tangled up while trolling or reeling in.
bfrancis2 12 years ago
IRCTOPGUN 13 years ago
hammy10809 14 years ago
K-Dawg 14 years ago
K-Dawg 15 years ago
