How to Solve a 5x5 Rubik's Professor Cube
Intro: How to Solve a 5x5 Rubik's Professor Cube
I got a 5x5 cube recently, and learned how to do it by only learning a few algorithms.
In order for you to be able to finish the cube, you will need to be able to solve a 3x3 cube, but being able to solve a 4x4 cube would also enhance your abilities for it, since the algorithms can be used on both.
If anything is unclear, just ask and I can clarify it for you
Please note:
1. This is a LONG INSTRUCTABLE. It will take time and effort to get through this cube, and you need to have some free time to solve your cube.
2. I am Canadian, so deal with the u in colour.
3. I am assuming you have a 5x5 cube. If you do not, they cost up to $40 CAD, so be prepared to spend a little bit of money on it.
Please note:
STEP 1: My Collection/experience
I started cubing over the summer of 2007. I got a dollar store "magic" cube, which was a cheap Rubik's cube. It came with instructions, which I memorized, and have now fine tuned so I can solve my cube with a 12 cube average of 51 seconds.
I can solve all the puzzles you see here, no instructions.
I found out how to do this by watching a long youtube video tutorial about how to solve this, and read some text instructions. I have 2 5x5 cubes, a few 3x3 cubes, and the 4x4 cube.
STEP 2: My Solve
This is a video of me solving the cube using my solution. I have only been solving this since christmas, so a couple weeks and I dropped my time by about 20 minutes. I took a long time to solve it the first few times, because I was still learning algorithms. Now, my time is below 10 minutes.
By the way, that cube is not the one I am using in my instructions, its the Rubik's one.
STEP 3: Getting Started
Ok, so the first step is to get your cube mixed up (I assume you have already done so, which is why you are reading this in the first place)
STEP 4: Notation
In the image below, you will see the notation I will be using. It is standard 5x5 notation, as far as I know. If just the letter is there, turn the face denoted clockwise, if you are looking at that side
' means counter clockwise.
I always solve my cube white centers first, then yellow, and the rest vary. It might help to follow how I am solving it if you start on white, then go to yellow, and work with my sides.
STEP 5: Getting a 2x1 Block on the Side of Your Choice
This is a rather simple step, just rotate any of the lower case letters (l ,r ,f , b) until there is a 2x1 cube
STEP 6: Make a 2x2 Block
Now, make another 1x2 block, and make it match up with the other one, leaving you a 2x2 block on the face you chose (white for me).
STEP 7: Finishing the First Center
Create yet another 2x1 block, joining it to make a 2x3 block.
Make a 1x3 block with the remaining white pieces, but don't mess up the white 2x3 block in the process!
Try to use the side that has no white blocks on the 2x3 block, and form that 1x3, and insert it.
STEP 8: Working on the Opposite Center
Now, flip your cube over. Make a 2x1 section. If you needed to rotate any faces, make sure you turn the piece out of the way, so that when you turn it back, the piece stays there. Make the 2x3 center on the yellow side using this method, and you are ready to move on.
STEP 9: Finishing the Center.
Make a 1x3 block of yellow, keeping the 2x3 and white center intact.
If you have the sides like they are in the first picture, then do the following:
Dd' Uu L2 Dd Uu'
It should now be a 1x3 block
Now, align it as in the second picture, and do the following algorithm:
Ll' U2 Ll
This completes the second center.
Dd' Uu L2 Dd Uu'
Ll' U2 Ll
STEP 10: The Third Center!
Find a colour that has a 1x2 or 2x2 block already assembled. This will be the next center you solve. In my case, it is orange.
Create a 2x1 block on a different side, and join it to the other one, that should have the center connected to it. It's just like solving the first center, just it's a bit easier to find the pieces. I forgot to take pictures, but I have put in the photos from steps 5-7 in, so you know it's the same thing.
HINT:
You won't mess up the completed centers if you hold the cube so that the white center is in your right hand, and the yellow center is in your left.
HINT:
STEP 11: The Fourth Center!
Pick a center adjacent to the one you just solved. If one is more solved than the other, then choose it. Green happened to be mostly solved, as can be seen in the pictures, so I chose that side.
Now, solve it like the second center, and then you have completed 4 of the 6 centers!
If you have a stray piece on your cube like in the picture, then do the algorithm used for putting the 3x1 section into the center, but make sure no greens go in!
STEP 12: The Final Two Centers!
Now, there should be only two different colours on the unsolved sides.
Using the algorithm for moving those pieces around(Ll' U2 Ll), get as many of the colour on its respective side. In my case, I am getting as many blues on the blue side, and reds on the red side as humanly possible. The inverse also works, and on the right side. Possible algorithms are:
Ll U2 Ll'
Ll' U2 Ll
Rr U2 Rr'
Rr' U2 Rr
If you have a case like in the second photo, you need to get the red center on the red side, and the blue center on the blue side. Then, align them as shown in the picture, and perform this set of moves:
r U' M U r' U' M'
(M is the middle, rotate it in the same direction as R)
You may need to repeat this multiple times to solve both parts, but after they are solved, we move on the the most time consuming part of the cube: Pairing
Ll U2 Ll'
Ll' U2 Ll
Rr U2 Rr'
Rr' U2 Rr
r U' M U r' U' M'
STEP 13: Pairing
Yes, this is a painfully time consuming step. I know
Find 2 edges that have the same colours on them, and arrange them like in the picture. I turned the layer with the edge on it so that it is one photo instead of 2
Now, to pair these edges, we find an unmatched pair in the top face. Rotate the cube as much as you like, you barely have to worry about messing up the centers anymore. For the following case, you need to perform the following (It's all logic, I'm just giving you algorithms to make it easier.):
(Uu) L' U L (Uu)'
The U can be replaced with U2 or U' as well
The logic method:
Move the cubie into position, swap it with an unpaired edge, and return the centers to the completed state.
Moving on:
Make sure that all the center edges are facing the same way as the outer edge pieces
This will work until you have 2 edges that are not solved.
(Uu) L' U L (Uu)'
The logic method:
Moving on:
STEP 14: Parity Errors
Sometimes, the cube does not always finish to be like a 3x3. If you have your cube looking like a 3x3, then move on to the next step for now. Otherwise, look at the pictures and determine which parity error to solve. For the example in the first picture, hold the cube so that the 2 sdes you are switching are on the right hand side. Then, use this algorithm (This is one of the ones I had to learn to solve this):
(Ll)' U2 (Ll)' U2 F2 (Ll)' F2 (Rr) U2 (Rr)' U2 (Ll)2
This can also be used in solving the 4x4.
Just arrange the cubies so that they are in that manner, and you can get it to have sections like a 3x3, and solve it. You may need to repeat that algorithm a few times.
STEP 15: Done!
Now, solve the cube like a 3x3. I use the beginner method, but you can use whatever method you like.
If you have any questions, problems, comments, or critiques, post them as a comment below.
Also, if you need more photos, I will make some more. I don't know that they will be exactly the same, but the photos I took were very minimal. If you need help solving it like a 3x3, I am working on an instructable for that next. ( Don't worry, I have a newer cube than the one in the photos )
155 Comments
Ashchinala2004 7 years ago
Morris Wang 2 years ago
__icareforyou__ 7 years ago
GabrielG205 7 years ago
•(B)2
•(U)2
•(Ll)
•(U)2
•(Rr)'
•(U)2
•(Rr)
•(U)2
•(F)2
•(Rr)
•(F)2
•(Ll)'
•(B)2
•(Rr)2
The EverydayC 7 years ago
hey I'm having this problem to its an oll parity do this (RW2 B2 U2 F2 LW' U2 F2 LW' F2 RW U2 RW' U2 LW2) then t gives you another parity that's what I'm trying to find
masterbinck 5 years ago
It are only the last 4 corner pieces
4n0nym0us 3 years ago
Flain206 5 years ago
Once all four corners are right, chances are some of them will have colours facing the wrong side. Do R F' R' F either 2 or 4 times (doing it 6 times resets the corner, and stopping at an odd number messes up your cube.)
If you haven't mastered these algorithms yet, try them on a 3x3 first before doing them on your 5x5. Messing up a 5x5 is tedious work.
masterbinck 4 years ago
Once you have all corners in correct position, permute them to have each colour face the correct side with R F' R' F done either 2 or 4 times (6 resets it).
Try doing these algorithms on a smaller cube (preferably a regular 3x3) if you haven't mastered them yet before doing it on your 5x5.
2. Do Ll’ U/U2 Ll
AlexK328 5 years ago
Step 12: I have a problem because my two centers have all but one square in the top right solved. I don't see a way to fix that. :\
so random 4 years ago
so, make the "lonely"square adjacent to the corner edge, then make the cubie above the two other cubies to the "lonely" side then flip the "lonely" side then get the lonely cubie to the correct side
