How to Turn an X-Box 360 PSU Into a 12v Lab PSU
Intro: How to Turn an X-Box 360 PSU Into a 12v Lab PSU
In this instructable I will show you how to turn an X-Box 360 PSU into a high ampere 12v power supply. This is simple and it only requires a few parts. In the 2nd hand store, I found and X-Box 360 PSU for $10 and I looked at the back and thought this great for a 12v Supply because it could output a lot of amps, 12.2 to be exact.
So I tracked down the wire Identification and I made one into a 12v Power supply.
P.S(U) I was using an Iphone Because my camera was dead and I'm 13 so please no bad comments!
Lets Cut the X-Box connector!
STEP 1: You'll Need...
You will need a few basic things for this project...
1. An X-Box 360 PSU (power brick)
2. Heatshrink
3. A small length of Red and Black with able to withstand 12 to 16 amps.
4. Two 15A alligator clamps
5. Solder
The tools you will need...
1. Soldering iron or station
2. Wire cutters
3. Wire strippers
4. Something to shrink heatshrink (My mini blowtorch)
5. Crimp tool
STEP 2: First Step
Strip the main insulation taking care not to cut the cores' insulation. After that, You will come across 8 wires. 3 black, 3 yellow, a blue and a red.
Strip the red and blue wires and twist them together. After that, Solder them together. Then move on to the next step.
STEP 3: Second Step...
Strip all the yellow wires and twist them together. Tin the conductor after that with solder.
Now take on end of the thick red bit of the cable and put some heatshrink over it
After that, solder them together like in the picture and melt the heatshrink over the newly soldered joint
Next step...
STEP 4: The Highly Anticipated Third Step
Now repeat the procedure with the ground and black wire. Heatshrink it.
STEP 5: Almost Done... Well Sortof
Put the big bit of heatshrink over and shrink it. Make sure the red and blue wire are in there. I used a short piece because it was the only bit I had. You're almost done.
STEP 6: The Aligator Clamps
Now it's time to put on the aligator clamps. Strip the other ends of the thick wire and tin both negative and positive. Then put the clamps on making sure the clamps are the right colour for the polarity. It will save a lot of confusion
STEP 7: All Done!
All finished. Plug it in and try it out.
Now you have got your own high power 12v supply!
Have fun and enjoy!
Don't forget to rate and comment!
Have fun and enjoy!
52 Comments
CjC 1 year ago
BazaVamp 5 months ago
Just connect the white wire with the grounds. So treat it as a black. Now i dont know why, or have any know how on this, just trial and error for a diesel heater. But thats what got it for me. Yellows are live, Black is Nutral, Red and Blue tell the block its powered so join them together to trick it, and then the white that I joined to the black.
Props to this guy for helping me out.
JamesA41 1 year ago
https://electronics.stackexchange.com/questions/22...
donjuanjanow 6 months ago
cyberraxx 2 years ago
Project_Mayhem 4 years ago
SanaullahK5 4 years ago
my adpter promblem this
i Running A 12 volt Fan its working but its problem
when i run The Fan its working!
but i dont net fan In Cool weather i shut off a Fan Swith Then The Adpter Automatically Off and Red light indicatid
When I Turn on The Fan Then Now Fan Is not Working redlight indicating
How to solwe This problelm???
Plz Tell me
Jurycooldude 5 years ago
stulew 5 years ago
MustaphaM9 5 years ago
i want to convert the xbo 360 ps u into a ballast for a grow light for tomatoes how do I put a 3 pin kettle lead on the end of the ps u lead that goes in the back of the xbox please help email me Mustaphamcneidhe79@gmx.co.uk
Hi could it be possible to turn my xbo x power supply too put another 3 pin socket (English kettle plug on the end where it goes into xbo x is it possible anchor please many thanks indeed poses email me azap
nic.bryan.73 5 years ago
Thank you for this instructable. I personally used it to power up a peltier-module based mini-fridge unit.
kl5l.hamradio 5 years ago
Thanks man, very useful. I just wired up a 175watt version as a power supply for a 2-meter 100w mobile radio.
JayE44 6 years ago
Which wire is Plus and Which is Minus ? Thaks for your great contrebution
brickbreaker 6 years ago
ClintD10 7 years ago
could I wire 2 of these in series?
Noaha1 7 years ago
note: if you are making a 3d printer this is much easier to understand than some other instructions online
dang.artman 9 years ago
Nice tutorial. The only thing I'm going to change on mine, is to hook the red and blue wires to a button or a switch so I can turn it off and on without having to unplug it.
tvarhol 7 years ago
SimonK48 8 years ago
I have the 8 wire version, just bought it in a junk sale. Okay so I can put a switch between red and black to turn it on and off. If I want a 5v rail I tap the red wire and use the black as the ground for it?
