How to Unclog a Blocked Toilet Without a Plunger
Intro: How to Unclog a Blocked Toilet Without a Plunger
What would you do if your toilet got clogged on a Saturday evening when the shops are closed and you are about to host a curry and beer party?
This instructable will show you a simple method for unclogging a toilet using hot water and shampoo. While there are other methods of clearing a toilet drain, this is a great option for unclogging a toilet because you don’t have to touch the water.
You will need:
- 1 clogged toilet (works best when someone has been overzealous with the toilet paper)
- A generous amount of surfactant (i.e., Dawn Dishwashing liquid, shampoo, liquid soap, or any other cleaner that gets sudsy)
- Hot (but not boiling) water
- A bucket or a basin to transport water to toilet
This will only work with a toilet that is not overflowing and has some room to hold extra water.
(For squeamish people: The picture of the blocked toilet was not created with actual bodily excretions.)
STEP 1: Add Shampoo and Hot Water.
Get your bottle of shampoo/ soap and squirt a generous amount into the bowl.
Follow that with a bucket of very hot water from the hot tap (not boiling).
Fill the toilet full but not overflowing.
The reason you should not use boiling is because it has been said that boiling water can cause the toilet bowl to crack (I have not personally tested this assertion though as I do not have the money to buy a new toilet).
Then go have a cup of tea and let the blockage 'marinate'.
STEP 2: Return and See Your Handy Work.
Hopefully after a few minutes the water level will have lowered. (Hot water helps break up toilet paper quicker and the soap lubricates the passage of solid material).
If nothing has happened wait 10 minutes more. If still nothing has happened you will probably need to use a different method (or bail some of the water out and add more hot water/ soap).
If the water level is lower than before add more soap and more hot water (hot water does not need to be as hot as the first time as this time there is less water in the toilet to heat up).
Again wait for water to drain (this should be quicker).
Repeat the process until water flows freely.
STEP 3: Done
Done.
Remind your party goers to treat your toilet with respect and only put bodily excretions and small amounts of toilet paper in.
268 Comments
magicmagic 1 year ago
ohalrightm8 3 years ago
SpicyCheese 3 years ago
ruffles33 3 years ago
ani ka 4 years ago
Xyzxyzxyzxyz900009 4 years ago
Yes I also signed up only to say thank you and to tell others not to get discouraged if it doesn't work at first, it took me about two hours and a shitload of hot water, dishwasher soap and laundry detergand but then it finally worked !!
TraceyC59 4 years ago
NavdeepK12 5 years ago
randalosgood 5 years ago
TanyaM72 5 years ago
Wow. This worked. I had to do the steps 3 times but then the water went and toilet flushes as normal Using dishing washing soap worked better than shampoo. Thanks!
FionaO7 5 years ago
Yinka1 6 years ago
Yay it worked! I used boiling water though and a small cup of washing powder! It worked first time.Thank you!
OkhumoideK 6 years ago
First used boiling water with shampoo and detergent but that was taking abit long... so boiled more water...added liquid dishwasher, shampoo, detergent and fabric conditioner and poured it and it just flowed instantly! Thanks.
GuLp1PLH 6 years ago
AriëlleT2 6 years ago
AmalitaB 6 years ago
its gotta feel good that almost 5 years after OP people are signing up for an account just to say thank! thanks! it worked instantly.. you have saved our marriage...this time. lol.
RayC123 6 years ago
Holy cr@p Batman, put some cheap shampoo and hot water down and it worked, nearly called the homeserve people, would have cost me £50. Brilliant.
MOSES001 6 years ago
I tried it and it worked in minutes. I had a clogged toilet that I was trying to flush waiting for it to go down and the flushing with a bucket but it was not working. I saw your page, followed the instruction and unvelievably, in minutes I was clog free. Thank you, thank you, thank you!
devontaffy 6 years ago
WOW!!!!!! the bowl cleared almost immediately.thanks.
ElaineL55 6 years ago
Thank you! This simple process really does work - unclogged my bathroom in less than 5 minutes.
