How to Get Six Pack Abs
Intro: How to Get Six Pack Abs
Looking to impress some ladies this summer or just want to be able to open a can of beans with your gluts (buttocks)? Well... i can't promise anything (especially the can cracking) but I do have some earnest methods that can develop your abdomens, thighs, and of course, the gluteus maximus!
STEP 1: Warmup
First and foremost, DO A WARMUP! I see people all the time walk into the gym and just start lifting... if you are one of these people, you deserve a slap. Cold muscles don't stretch, cold rubber doesn't stretch, cold rubber snaps, muscles can snap too...
Even a 7 minute slow jog is better than nothing, but if you've got time then get a good 15 minute jog in. Your muscles will thank you in the morning and your heart will be pumping blood faster which makes every body part sing in harmony!
As far as stretching goes, I'm sure theres plenty intructables already out there on the subject. personally, I prefer stretching after my workout, but it's not too necessary as long as you stretch once every 2 or 3 workouts.
STEP 2: List of Drills
Now for the actual lesson...
It's called S(h)even and hell. No fancy contraptions, no balls, no weights. Just gravity and preserverance. Find a nice open area, lay on your back in classic crunch position, and set your watch for 7 minutes.
For every minute, switch to a different ab drill (below).
It's not about how many you can do. It's about being able to keep a steady speed and work through all 7 minutes.
In the next steps I will briefly explain each drill and rank them on difficulty/burn.
List of Drills (mix them up so that way you don't get too repetitive of any one list)
legs down (classic)
legs up (Don't cross legs)
plank upright
plank left
plank right
six inches
six inches to crunch
six to thirty six
swimmers
scissors
bicycles
penguins
toe toucher's
left to right
rockies
Are there more? Yes, many more, but this is more than enough for the average chimp.
legs down (classic)
plank upright
plank left
plank right
six inches
six to thirty six
swimmers
scissors
bicycles
penguins
toe toucher's
left to right
rockies
STEP 3: Classic Crunch
Burn Scale (5 being the highest) = 2, Anaheim pepper
Classic Crunch
Feet and back level with ground, knees bend upward and arms folded around Chest. Arms behind head cause the use of arm muscles so fold them at the chest. Starting slow and steady is best always, you want to be able to feel your abs actually pulling you through and up. To create a good burn usually you only have to go half way up to your knees, anything higher and you can assume your using other muscles, so keep it low.
Classic Crunch Feet up
Burn Scale = 2.5, Anaheim pepper
Same as Classic crunch but keep your feet level with your knee caps, perpendicular to the ground.
Classic Crunch
STEP 4: Planks
Planks require you to concentrate on remaining still, and they may seem easy but a minute will seem a lot longer during this exercise. Try to include one or two of these in every seven minutes.
Plank Upright
Burn scale = 3, jalapeño pepper
Switch position so to have stomach facing ground. Lift yourself with your toes and forearm, keep body as straight as possible and KEEP YOUR BUTT DOWN. Within 30 seconds most people start involuntarily shacking and thats how you know its working!
Plank Right
Burn Scale = 2.5 Anaheim pepper
Switch position so to have right side on body facing ground. Lift your self with your right forearm and keep left arm perpendicular with body. Again your body should form a straight line, or plank.
Plank Left
Burn Scale = 2.6...... I'm not so symmetrical....
Same as Plank Right but on your left side.
Plank Upright
Plank Right
Plank Left
STEP 5: Six Inches
All these drills are heavy on the legs, doing all six would be the ultimate glut work out
Six Inches
Burn Scale = 4 Thai Pepper
Position yourself with back facing ground and hands underneath your butt. raise your legs so that way your heels hover roughly 6 inches from the ground. Similar to the planks, withen 30 seconds your legs with start involuntary spasms.
Six inches to crunch
Burn Scale = 5 Red Habanero!
Same position as six inches to crunch, but fold your arms around your chest, and simultaneously raise your kneecaps to your chest while you crunch and as you go back down push your legs back out so that they hover 6 inches to the ground. Correctly done your feet should never touch the ground.
Six to thirty six
Same position as six inches. throughout the minute slowly raise your legs so to have your feet hover from six inches to 36 inches above the ground, and then slowly lower them back to six and repeat.
Swimmers
Start off in six inch position and raise each leg at a time upwards and as one leg comes down the other should be going up. This exercise should be done faster than the other leg raises. ( more kicks per minute)
Scissors
Same as Swimmers but instead of going verticle, your legs should be going horizontal and criss-crossing each other in a fluid motion. Also a fast pace exercise.
Bicycles
Start off in classical crunch position with feet up. Start pumping each leg mimicking the rotation of pedaling a bicycle. With opposite elbow to kneecap, side crunch so that they just barley touch. again a fast paced exercise but start off slow to get the grasp of the motion.
Six Inches
Six to thirty six
Swimmers
Scissors
Bicycles
STEP 6: Last Four Exercises
Ok, heres the last three for now.
Penguins, these are good for a good break in the middle of the 7 minutes
Burn Scale = 1 Bell Pepper
Start off in classic position and keep heels just far enough away from finger tips so as to stretch a little to touch them. Move from left heel to right heel, feel the slight burn in your sides.
Rockies
Start in classic position except put your hand behind your head so your elbows extend forward. Thrust your body upright and touch each kneecap with adjacent elbow before going back down. This drill is pretty tough so not too many reps can be accomplished in one minute.
Touch touchers
Once again start in classic position, but lift legs completely up, 90 degrees to body. Try to reach and touch each toe with adjacent hand without bending knees. This should be a relatively fast drill.
Ok, Thats it! Theres plenty of drills here to pick and choose which ones to load your seven minutes with. Within a month of doing seven minutes every day I had defined abs... not to gloat or anything. Well, I hoped you liked this instructable, especially my awesome pictures, and yes it is my first, but I do have more information i can share with you in more instructables to come.
Please leave me any comments or suggestions, and if you want to improve my pictures I would totally welcome them with a big embrace! Thanks!
Rockies
Touch touchers
105 Comments
C-R-E-8 9 years ago
caylen2528 10 years ago
DannytheGreat 12 years ago
robertjames 12 years ago
Cr4zy_Dud3_0n_F1r3 13 years ago
But to burn the fat to make the six pack visible, you need to do aerobic exercises. I learned about glycogen, its what the body uses for exercise, for energy. This usually lasts about 30-45 minutes, there are a lot of factors that affect this, but this is usually how much time it takes for the average person to use up all of their glycogen. After all of the glycogen is used up, then the body starts to use the fat supply. So you need to exercise for at least an hour.
This is why some people exercise in the morning, because its been 7-10 hours since the person last ate, the supply of glycogen is lower (since we burn calories in our sleep). You have less glycogen which means that you will turn to fat supplies sooner.
artlife1 13 years ago
steve_tupper2010 13 years ago
Only suggestion is that I tend to add something for a twist in the waist as well, but that's maybe because at my age (nearing 60) it is isn't just my abs I am fighting to preserve, but my general mobility and flexibility as well.
imapimp 15 years ago
Should I make a calendar listing body parts to exercise and list them randomly so I use muscle confusion? This way I don't tolerate the drills as fast and build muscle faster?
Thanks in advance, Cr42y Dud3.
KottonKandy 13 years ago
JohnJY 13 years ago
borges0105 13 years ago
SimonLearnsNewThings 13 years ago
riiod 14 years ago
I'm trying to get into shape, and this method does look pretty convicing, However, I was wondering - usually in strength training, the advice is not to work the same muscle group two days in a row; should I really do these every day?
[Yesterday, I felt the burn, today, doing the exercises, I feel the pain...]
AwesomeOpossum 13 years ago
TheBookie 15 years ago
RED^WINGED^PEGASUS 14 years ago
bg1987 14 years ago
If you find these exercises easy (your abs don't feel on fire after them), you could use weights, in the classic crunches, you can hold weights on your chest to increase the weight you are lifting with your stomach.
also, doing these crunches on a negative incline training bed (the kind where your head is lower than your legs) increases their effectiveness.
Remember that training with weights should be supervised, and its best to consult a professional trainer and create a training program suitable for you.
