How to Use 2.4 Inch TFT LCD SPFD5408 With Arduino Uno and Mega
Intro: How to Use 2.4 Inch TFT LCD SPFD5408 With Arduino Uno and Mega
This Instructable is to know how to work TFT 2.4 with the controller SPFD5408
with the libraries of Adafruit for TFT.
This library is the Adafruit TFT Libraries changed to works in TFT 2.4 shields with the SPFD5408 controller.
Now it is for Uno and Mega, Teensy is on the way...
It is based in the last version of Adafruit, inclusive with buttons features.
The TFT 2.4 is cheap TFT, that generally is from China, without documentation or libraries for it.
I tested some mcufriend shields.
When we try to use the TFT 2.4 with SPFD5408 controller in sketches with Adafruit TFT libraries, several things can happen :
- White Screen
- All screen with noise
- Touch not works or is inverted (coordinate Y)
- The colors are inverted
- And other things
After trying for several days trying the solutions I found on the web, and none works 100%. So I decided to do an library specific to this controller.
I changed the Adafruit libraries for TFT: GFX , TFTLCD and TouchScreen. I join all in this one library, the library SPFD5408, to avoid problems with duplicate libraries and enables also have the original library Adafruit ready for use in other projects with another TFT hardware.
STEP 1: Download the SPFD5408 Library
I made available it in my GitHub .
Please download it in: https://github.com/JoaoLopesF/SPFD5408
Attention: This library is ONLY for SPFD5408 TFT controller
If it not work, and you get a blank screen,
please access this site to help you identify the correct library:
STEP 2: Install
Please follow the details in README.
STEP 3: First Test - Graphicstest
I modified the Adafruit graphicstest to work.
Please open the folder in spfd5408_graphicstest sketch example.
Upload this to Arduino Uno
STEP 4: Test 2 - Tftpaint
TftPaint is a sketch from Adafruit_TFTLCD, is a one simple paint, but important for learning and test the TFT.
I modified this to work.
Please open the folder in spfd5408_tftpaint sketch example
STEP 5: Utility - Calibrate
This TFT is with a resistive touch, and need calibration for accurate the touch
I made one sketch to help this process.
Please open the folder in spfd5408_calibration sketch example.
After the run of this program , you have the parameters of calibration to put in your sketch code.
189 Comments
ben6servotech 9 months ago
cristikc 4 years ago
haroon naveed 4 years ago
bk2001050 4 years ago
ManuelC15 5 years ago
parindapathirana18 5 years ago
f8voa 5 years ago
Hello ,
I received one month my mcufriend 2.4" screen . I tried a lot of codes and the only one with some results is yours . But I have some issues . I tried the spfd...calibrate code on my UNO . I only get a red screen and then following problems :
avrdude: stk500_recv() : programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10 : not in sync : resp=0xc8
attempt 2 =0x00 , 3 = 0x00 , 4 = 0xe0 and so one ..
Can you help me ?
Thanks a lot
mandango 5 years ago
My board arrived today and it looks like the one on your pic except for the silk screen print which simply says 2.4'' TFT LCD SHIELD.
And the ID with LCD_ID test returns 000.
I also found that the touch panel is connected to pins A2, A3, D8, D9.
With this adjustment touch gets recognized but the orientation is still a mess and I haven't found yet how to correct it.
marik2500 5 years ago
How to adjust the backlight at this TFT? Thank you! I think it would be useful to know how to change font type in letters and numbers!
adekdinal 6 years ago
hey, can you help me with this tft display, i have an rotary encoder on pin 0 and pin a5, in serial monitor and tft display used the counter is error while imn't using tft display rotary encoder work fine, can u help me with that problem?
ShrutiS27 6 years ago
Thank you so much for the post. But I still can't fix the mirrored text and also it occupies only partial screen :/ Can someone help? The below comments din't help :/
MikeB648 6 years ago
did have someone solution?
HarshC23 6 years ago
hello everyone
i am using this screen for my project and the problem i am having is that once i touch on the screen and display the next one and try to touch again the screen doesnt recognize what it is basically doing is in the background the initial screen is still present and the touch point is sensing from the 1st screen
i tried using the function "screen.background(0, 0, 0);" but i am getting an error:- 'class TFT' has no member named 'background'
any help would be appreciated ASAP
chamalbandara 6 years ago
Everything works fine, thank u soo much ,except when i change the screen rotation (tft.setRotation(3);) touch is not aligned ,touch x and y coordinates are not with the display x,y coordinates ,
how ca i fix this.
i need the display in landscape mood , please help
Akshay KG 6 years ago
Thank you sir, finally i got a right library for it! while i run the "paint" example, i had noticed that the touch plate is not working properly, if i touch at the right corner it is selecting the left corner; how can i fix it?
PeterGB66 6 years ago
Thanks to slava_gll, I tried his tip for editing SPFD5408_TouchScreen.cpp, and for the first time after quite some nights of struggling the touchscreen is working in the correct x-y directions!
So, in SPFD5408_TouchScreen.cpp, change lines 157-164 to:
return TSPoint(y, x, z);
// *** SPFD5408 change -- Begin
// SPFD5408 change, because Y coordinate is inverted in this controller
//return TSPoint(x, 1023 - y, z);
// -- End
NOTE: y and x reversed!
AjayK217 6 years ago
Thanks a lot Broda
Now my screen work perfectly.
U r genius.
wiredcav 6 years ago
This instructable and your library have been extremely useful. Thanks so much. I've got it all working, but now when I write a new sketch I'm finding I'm having trouble with waitOneTouch(). It appears that several "touches" are being buffered. I notice in the Adafruit_STMPE610 there is a bufferEmpty() function that lets me check the buffer and keep reading until it's empty. But I can't find such a function in the SPFD5408 lib. Any tips would be greatly appreciated. Thanks!
