Introduction: How to Use OV7670 Camera Module With Arduino?
Here we introduced one OV7670 camera module just purchased online, including the communication of camera module and Arduino UNO, the using ways to take photo via camera module, and so on. This is an Arduino camera module, adopted the Surveillance cameras digital image processing chip-OV0706, specially designed for image acquisition and processing application, based on TTL communication interface, very convenient to connect with Arduino controller, able to read image and data via UART serial port, and then perform some image processing. This is a detailed DIY guide for the OV7670 TTL and UART camera, and you can also download the code from ElecFreaks.
Find source reading here: http://www.elecfreaks.com/7861.html
Step 1: General Description
This camera module can perform image processing such as AWB (auto white balance), AE (automatic exposure) and AGC (automatic gain control), for the video signal coming from CMOS sensor. What’s more, in fusion of other advanced technology such as image enhancement processing under low illumination, and image noise intelligent forecast and suppress, this module would output high quality digital video signals by standard CCIR656 interface. OV7670 built-in JPEG decoder supported reatime encoding for collected image, and external controller can easily read the M – JPEG video streams, achieving the camera design of double stream. OV7670 supported motion detection and OSD display function of screen characters and pattern overlay, capable of self-defining detection area and sensitivity.
Step 2: Test OV7670 Camera Module - Needed Tool for Testing
Hardware
SD Module
Digital key module
Jumper wire
USB cable
Software
Camera_VC0706_TEST
Arduino IDE(download it from official website)
Step 3: Hardware Connection
- Connect the hardware as the diagram shows.
- Physical diagram.
Step 4: Software Use and Code Programming
- Firstly download the two files of Camera_OV0706_lib and Camera_OV0706_TEST from the Camera Module Code written by ElecFreaks and then unzip it.
Put the unzipped file of Camera_OV0706_lib into the Arduino IDE folder of Libraries.
Open unzipped file of Camera_OV0706_TEST, and the program the code into UNO. The detailed steps are demonstrated in the pictures.
Click Tools,and then choose the board of Arduino UNO.
Click Tools / Serial Port,and then choose the corresponding COM number.
And then click the button of programming like below in red rectangle, program the code into the UNO board until done uploading appears.
Finally open the monitoring serial port as below in red rectangle.
When the serial port display the data like demonstrated below, you can press the digital keys to take a photo.
If photo was taken successfully, the serial port would be displayed.
Until now, the module testing has been completed. Thanks for reading.
70 Comments
Question 10 months ago
How does it actually send photos to a phone via wifi? Can somebody explain that for me?
Answer 9 months ago
actually im looking for this idea
4 years ago
if you want OV7670
I got new video about OV7670,, and it's work
https://www.youtube.com/watch?v=AH13reXFjNQ
Reply 10 months ago
your video is unavailable
Reply 10 months ago
sorry broken link
7 years ago
This camera is not the OV7670 model. It is actually the OV0706 model. It is very Confusing
Reply 1 year ago
Agreed. Utter waste of time !
Reply 5 years ago
Yeap. I think it's written for vc0706 not OV0706. OV has more pins not just 4 pins.
Reply 2 years ago
excelent i agree with you
Reply 2 years ago
maybe you are right, maybe the platform has both OV7670 and OV0706 driver;
if you need camera modules I can help : rd@taocamera.com
4 years ago
In my ov7670 cam there is no Rx & Tx pins.
Reply 4 years ago
How many pin do ou have?
22 or 18?
Reply 1 year ago
18
Question 1 year ago on Introduction
What if I want to use wemos esp8266 instead of arduino uno ( what would be circuit diagram then)
1 year ago
Reply 1 year ago
Check here :
https://github.com/adafruit/Adafruit-VC0706-Serial-Camera-Library
Question 1 year ago
Does it save the image to the micro sd card?
5 years ago
How can I use old mobile camera as a camera module I have a Nokia camera please anyone tell me about this 14 pin camera
Reply 2 years ago
I also have it let me know if anyone finds solution.
Even i will let you know if i find any.
Reply 2 years ago
solution is sell it to a phone repair shop and buy this ovo camera module
