HOW TO USE a JEWELRY SAW
Intro: HOW TO USE a JEWELRY SAW
This is how to use a jewelry saw. Off course you can just go ahead and use it randomly, but with just these few tips, everything will be way easier.
STEP 1: WHAT YOU NEED
You need:
-a jewelry saw blade,
-blades, wax,
-a piece of wood (cut as in the photo),
-a good clamp.
STEP 2: CHOOSE THE BLADE
There is many chart online for how to choose your blade depending on what you are cutting. But in general as hard as your material is, as thiner the teeth of the blade should be. For metal at list two to three teeth for as thick the sheet you need to cut is. Thiner blades can be more precise, but they also break way more easily.
STEP 3: BLADE DIRECTION
With your finger feel the blade direction. You have to place it in your saw, so that it will cut by pulling, not pushing.
STEP 4: PLACE THE BLADE
Place one end of the blade in the part more near the handle. Screw it tight.
STEP 5: THE OTHER EDGE OF THE BLADE
The other edge of the blade should not quite arrive to the other side of the saw. It should miss few millimeters.
STEP 6: PUSH AND PLACE BLADE
Push the saw against something, holding it from the handle, so that the blade will reach the other edge.
Close it really tight.
STEP 7: FEEL THE BLADE
The blade now should be really tight, and make a nice sharp sound.
STEP 8: WAX THE BLADE
Wax the behind side of the blade (not the front part with the teeth).
If you never did it before, you should give it a try: it really make a difference when cutting metal.
It make the blade get less stocked, and make it move easier and smoother.
STEP 9: CLAMP THE WOOD
Clamp the wood very firmly on a table. I did my piece with a scrap piece of wood and a jig saw.
STEP 10: CUT
Place yourself in front of the piece to cut. Don't push too much the saw, or the blade will easily break.
Keep the saw in the middle of the wood hole, moving the piece you have to cut with your other hand.
WEAR GLOVES ON THE HAND THAT HOLD THE PIECE TO CUT, THE BLADES ARE REALLY SHARP, AND EASILY CUT TROUGH YOUR FINGERS.
STEP 11: IF YOU NEED TO CUT AN INSIDE PART
If you need to cut something in the inside part of a piece of metal, just punch a little hole where you need to cut, insert the blade in the hole, and do the previous step of how to place the blade and cut.
16 Comments
sanjay117 2 years ago
Hopefully you have all read a great article in popular mechanics(very old) by Mr. W.E. Burton on juse of ewlery saw!
cjf 4 years ago
nik9801 8 years ago
TriacNT 6 years ago
With any kind of paper or card, you can use spray adhesive: It's easier to remove the paper than rubber cement, and won't get brittle and fall off if you have to put the project aside for a day or two. I discovered this while using a scroll saw, and found the adhesive's residue is much easier to remove.
marcellahella 8 years ago
I don't know about cutting tracing paper…sorry I can't help. Anyways, just about curiosity, what is the purpose?
cirious 7 years ago
You can draw your design on the tracing paper (or any paper, really) and then attach it to the metal with rubber cement or a glue stick to keep it in place while you saw through both it and the metal at the same time. That way, you don't have to draw on the metal -- which sometimes, can be problematic.
LaurenR43 7 years ago
glue the full piece of paper onto the metal. I have not tried rubber cement. We used a glue stick in the class I took, but I like the rubber cement idea.
davenbill 8 years ago
attach the paper [not necessarily tracing paper] to the metal sheet with rubber cement; you can then cut out your design without the paper moving.
nolose 8 years ago
Muy buena explicación no sabia poner bien la cera,gracias!
gracias!
DM5k 8 years ago
never forget to let the blade do the work, in high school jewelry class, i saw a girl cut through half of her finger because the blade wasn't tight enough, and i saw a boy pierce the blade straight through his finger, for the same reason. don't push it, guide it.
nik9801 8 years ago
Woodworker_17 8 years ago
debschlouch 8 years ago
Awesome, thanks for the detailed instructions. I will refer to when I use my saw again as I use it infrequently!
Mindmapper1 8 years ago
Yes, I have to correct that, I meant material, not metal. I also cut bones and really hard wood, so that was just a really general tips. I'll add your too.
Thanks.
