How to Use Use Gateway 3ds EmuNAND Function to Play Online Games,eshop Games.
Intro: How to Use Use Gateway 3ds EmuNAND Function to Play Online Games,eshop Games.
Just as we knew,as the best 3ds game card,gateway 3ds comes with so many amazing features. Thought currently it only supports running 3ds games on N3DS V4.1-4.5,yet with its EmuNAND function,we can play latest 3ds games on our lower system firmware as well and following is a detailed guide on how to use gateway 3ds EmuNAND to play eshop games,online games.
Things you need to prepared
1. gateway 3ds ( if you dont have,here is a usa official distributor for you : buy gateway 3ds )
2.N3DS/XL V4.1-4.5 console.
3.SD card, micro sd card.
Blog guide source :
STEP 1:
Download latest gateway 3ds omega firmware v2.7 from official gateway-3ds.com download page and unzip it,open the folder and Copy the Blue Card ( R4i ) root files into your micro sd card, it should be these files
STEP 2:
Format our SD card and put the latest launcher file into your SD card and then insert your SD card to SD Slot
STEP 3:
Insert your micro sd card into your gateway 3ds card and put them together to your console and power on it
STEP 4:
Click the icon and run GW INSTALLER
STEP 5:
after update finished,Click A to back home menu
STEP 6:
Then choose Setting—-other setting—-profile—-Nintendo DS Profile
STEP 7:
then you will enther gateway 3ds mode
STEP 8:
If you have updated your EmuNAND to v9.4.0-21,the latest 3ds sytem firmware,then you can go to play eshop games or online games directly,yet,if not,then you need update your EmuNAND to latest v9.4 firmware first.
Note : Assure do it under the GW3D firmware mode not N3DS/XL itself firmware mode and update your 3ds console from GW3D firmware to GW3D V9.4.0-21.
STEP 9:
If you in the GW3DS Mode, then Open your WIFI Network, go to the system settings, choose system update and click it to update. After update finished, you will find your system firmware now is on GW3D V9.4.0-21
