How You Make a Halo Magnum! (With Slide and Magazine)
Intro: How You Make a Halo Magnum! (With Slide and Magazine)
Music by Kevin Macleod (incompetech.com)
Link to the Pic:
http://www.mediafire.com/imageview.ph...
If you like here is the Halo Font!
http://www.dafont.com/halo.font
And some other Pics from the Halo Magnum:
Link to the Pic:
15 Comments
burrito_boy1995 7 years ago
Amazing, I am going to put in good word for the halloween competetion
AnthonyB184 7 years ago
I added a rubber band connecting from the base to the slide so it would bounce back and it was pretty boas
ChillinDylan 12 years ago
battle 13 years ago
SenaCat 14 years ago
Kindhamster 13 years ago
do you know where I could bet some foamcore?
and if so, how much is it?
SenaCat 13 years ago
Apologies if I step on toes, but this is some of what I did.
I took a blueprint found here: http://www.405th.com/showthread.php/9039-Wizard-Of-Flight%27s-Weapon-Blueprints
It's part way down the page.
http://halo.wikia.com/wiki/M6D
The wiki says the pistol is 10.51 in.
The Spartan scale model is 117% bigger at, unless I'm wrong 12.2967 in.
What I did was take the Spartan scale and resized the blueprints to that, then printed and cut out the number needed to get the right thickness. Other then that the building instructions are about the same as the video. My front enclosure was more parts, something like this:
__
This gives me more of a curve to work with when I smooth it, most likely with bondo. If you cut the angle joints at a 45o with the xacto it helps.
(Aware I'm running on, almost done, honest!)
Also, If you have a dremel, a grinding wheel is good for the vents on the slide, and a rounded tip can gently carve the depressions in the grip.
And last but not entirely least, I chose to only have I think two layers for the hand guard, if you look at references it's thinner then the rest of the pistol.
And reference images are http://halocostuming.wikia.com/wiki/References
P.S. Nice tut, Cathy. It was a big help!
spartan2000 13 years ago
lockdown1101 13 years ago
as for the gun, I was hoping it would be shinier
go dog 13 years ago
the tech head 13 years ago
Hellchild 13 years ago
ymliman901 13 years ago
tigy888 14 years ago
