Humanoid Robot Voiced Controlled With Arduino Mega, Raspberry Pi and 1Sheeld
Intro: Humanoid Robot Voiced Controlled With Arduino Mega, Raspberry Pi and 1Sheeld
Humanoid Robot is a robot shaped in the form of a human. A humanoid robot is used in many different fields such as education for young children, on field marketing for companies, research and development tool , entertainment and for tasks that are unsafe to be done with real people so humanoid robots are a tool for human luxury and safety.
STEP 1: Get the Components
Motors:
19 smart servo Herkulex motor.
For interacting:
- webcam.
- 2 speakers.
- microphone.
1Sheeld is used for a remote control through the mobile phone.
Micro-controllers:
- Arduino Mega: it's used to control the servo motors for the movements of the robot.
- Raspberry Pi : it's used for the image processing and voice interaction.
You can find all the component you need in Robot shop.
STEP 2: Design on Paper
To start you need to make your design on paper, calculate your dimensions and make torque analysis for each joint (motor) and how much load it'll be carrying.
STEP 3: Software Design
Now you take your design to a 3D software designer (solid-works / inventor...) and turn it to a 3D model ready top be printed.
STEP 4: 3D Printing
Choosing the printing material that is strong, cheap and light in the same time like plastic ABS.
STEP 5: Coding
This is the Arduino code for controlling the robot using 1Sheeld
The Forward and Inverse Kinematics of our Robot is not discussed here but As an Alternative Solution we controlled each Servo with his own angle to get him to the Required Position.
you'll need the following libraries installed in your computer: Herkulex & 1Sheeld
#include <Wire.h><br>#include <Herkulex.h> #include <OneSheeld.h> #include <SoftwareSerial.h> //Software Serial Port #define RxD 52 //8 lenardo 52 mega #define TxD 7 #define SLAVE_ADDRESS 0x04 #define DEBUG_ENABLED 1
int ReceivedData , Data; int number = 0; float y;
const int Pin1 = 22; const int Pin2 = 23;
void setup() { pinMode(Pin1, OUTPUT); pinMode(Pin2, OUTPUT); delay(1000); pinMode(RxD, INPUT); pinMode(TxD, OUTPUT); Serial.begin(115200); // Open serial communications Serial.println("Begin"); Herkulex.beginSerial3(115200); //open serial port 1 Reboot(); Herkulex.initialize(); //initialize motors // initialize i2c as slave Wire.begin(SLAVE_ADDRESS); // define callbacks for i2c communication Wire.onReceive(receiveData); Wire.onRequest(sendData); OneSheeld.begin(); Herkulex.writeRegistryEEP(254,0x13,0x8E); delay(200); Herkulex.setLed(254,LED_PINK); }
void loop() { //Switch the Humanoid On/OFF /if(PushButton.isPressed()) { Reboot(); Intial(); Herkulex.setLed(254,LED_PINK); } else if(!PushButton.isPressed()) { Herkulex.torqueOFF(254); Herkulex.setLed(254,LED_GREEN2); Herkulex.end(); } if(ReceivedData == 2) //Giving a feedback about the detected Juics { delay(10000); TextToSpeech.say("your Juics is ready"); delay(100); ReceivedData = 255; }
if(ReceivedData == 3) //taking a Selfi { Camera.setFlash(ON); Camera.rearCapture(); delay(10000); Facebook.postLastPicture("Posted by @Neo Maelo"); delay(100); ReceivedData = 255; } //sensing the alarm ringtone of the mobile if(Mic.getValue() > 80) { delay(10000); WakeUp(); delay(1000); digitalWrite(Pin1, HIGH); digitalWrite(Pin2, LOW); delay(300); digitalWrite(Pin1, LOW); digitalWrite(Pin2, LOW); } if(LightSensor.getValue() < 20 && LightSensor.getValue() > 0) { sleep(); delay(1000); digitalWrite(Pin1, LOW); digitalWrite(Pin2, HIGH); delay(300); digitalWrite(Pin1, LOW); digitalWrite(Pin2, LOW); }
//Accelometer Control if (GamePad.isRedPressed()) { y=AccelerometerSensor.getY(); if ( y < 0) //Right Arm { rightArm(); } else if (y > 0) { leftArm(); } } //Dance and music else if (GamePad.isGreenPressed()) { MusicPlayer.play(); SimpleDance(); MusicPlayer.pause(); } else if (GamePad.isBluePressed()) { Intial(); } }
void rightArm() { Herkulex.moveOneAngle(1, 130, 1000, LED_BLUE); Herkulex.moveOneAngle(4, -10, 1000, LED_BLUE); delay(1000); } void leftArm() { Herkulex.moveOneAngle(1, 10, 1000, LED_BLUE); Herkulex.moveOneAngle(4, -130, 1000, LED_BLUE); delay(1000); }
// callback for received data void receiveData(int byteCount){
while(Wire.available()) { Data = Wire.read(); Serial.print("data received: "); Serial.println(Data); ReceivedData = Data; } }
// callback for sending data void sendData(){ number = ReceivedData; Wire.write(number); }
void Reboot() { Herkulex.reboot(0); //reboot first motor Herkulex.reboot(1); //reboot first motor Herkulex.reboot(2); //reboot first motor Herkulex.reboot(3); //reboot first motor Herkulex.reboot(4); //reboot first motor Herkulex.reboot(5); //reboot first motor Herkulex.reboot(6); //reboot first motor Herkulex.reboot(7); //reboot first motor Herkulex.reboot(8); //reboot first motor Herkulex.reboot(9); //reboot first motor Herkulex.reboot(10); //reboot first motor Herkulex.reboot(11); //reboot first motor Herkulex.reboot(12); //reboot first motor Herkulex.reboot(13); //reboot first motor Herkulex.reboot(14); //reboot first motor Herkulex.reboot(15); //reboot first motor Herkulex.reboot(16); //reboot first motor Herkulex.reboot(17); //reboot first motor Herkulex.reboot(18); //reboot first motor Herkulex.reboot(19); //reboot first motor delay(500); Herkulex.initialize(); //initialize motors }
void Intial() { Herkulex.moveOneAngle(0, 98.00, 1000, LED_BLUE); Herkulex.moveOneAngle(1, 10.00, 1000, LED_BLUE); Herkulex.moveOneAngle(2, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(3, -98.00, 1000, LED_BLUE); Herkulex.moveOneAngle(4, -10.00, 1000, LED_BLUE); Herkulex.moveOneAngle(5, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(6, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(7, -5.00, 1000, LED_BLUE); Herkulex.moveOneAngle(8, 2.00, 1000, LED_BLUE); Herkulex.moveOneAngle(9, 4.00, 1000, LED_BLUE); Herkulex.moveOneAngle(10, -2.00, 1000, LED_BLUE); Herkulex.moveOneAngle(11, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(12, 8.00, 1000, LED_BLUE); Herkulex.moveOneAngle(13, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(14, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(15, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(16, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(17, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(18, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(19, 0.00, 1000, LED_BLUE); delay(1200); }
void Bye() { for(int i=0; i <3; i++) { Herkulex.moveOneAngle(0, 88, 700, LED_BLUE); Herkulex.moveOneAngle(1, 159, 700, LED_BLUE); Herkulex.moveOneAngle(2, 77, 700, LED_BLUE); Herkulex.moveOneAngle(3, -93, 700, LED_BLUE); Herkulex.moveOneAngle(4, -120, 700, LED_BLUE); Herkulex.moveOneAngle(5, -2, 700, LED_BLUE); delay(900); Herkulex.moveOneAngle(0, 76, 700, LED_GREEN); Herkulex.moveOneAngle(1, 92, 700, LED_GREEN); Herkulex.moveOneAngle(2, 3, 700, LED_GREEN); Herkulex.moveOneAngle(3, -76, 700, LED_GREEN); Herkulex.moveOneAngle(4, -140, 700, LED_GREEN); Herkulex.moveOneAngle(5, -83, 700, LED_GREEN); delay(900); } }
void SimpleDance() { Herkulex.moveOneAngle(3, -150, 1000, LED_BLUE); delay(950); Herkulex.moveOneAngle(3, -100, 1000, LED_BLUE); Herkulex.moveOneAngle(4, -60, 1000, LED_BLUE); Herkulex.moveOneAngle(1, 60, 1000, LED_BLUE); delay(950); Herkulex.moveOneAngle(0, 110, 1000, LED_PINK); Herkulex.moveOneAngle(1, 25, 1000, LED_PINK); Herkulex.moveOneAngle(3, -150, 1000, LED_PINK); Herkulex.moveOneAngle(4, -25, 1000, LED_PINK); delay(1000); Herkulex.moveOneAngle(7, -0.97, 1000, LED_BLUE); Herkulex.moveOneAngle(8, 2.60, 1000, LED_BLUE); Herkulex.moveOneAngle(9, 4.88, 1000, LED_BLUE); Herkulex.moveOneAngle(12, 1.63, 1000, LED_BLUE); Herkulex.moveOneAngle(13, 0.00, 1000, LED_BLUE); Herkulex.moveOneAngle(14, -1.63, 1000, LED_BLUE); Herkulex.moveOneAngle(0, 150, 1000, LED_GREEN); Herkulex.moveOneAngle(3, -110, 1000, LED_BLUE); delay(1000); Herkulex.moveOneAngle(0, 110, 1000, LED_BLUE); Herkulex.moveOneAngle(3, -150, 1000, LED_GREEN); delay(1000); Herkulex.moveOneAngle(0, 150, 1000, LED_GREEN); Herkulex.moveOneAngle(3, -110, 1000, LED_BLUE); delay(1000); Herkulex.moveOneAngle(0, 110, 1000, LED_BLUE); Herkulex.moveOneAngle(3, -150, 1000, LED_GREEN); delay(1000); Herkulex.moveOneAngle(0, 160, 1000, LED_GREEN); Herkulex.moveOneAngle(3, -160, 1000, LED_GREEN); Herkulex.moveOneAngle(4, -70, 1000, LED_BLUE); Herkulex.moveOneAngle(1, 0, 1000, LED_BLUE); delay(1000); Herkulex.moveOneAngle(4, 0, 1000, LED_BLUE); Herkulex.moveOneAngle(1, 60, 1000, LED_BLUE); delay(1000); Herkulex.moveOneAngle(0, 98.70, 900, LED_BLUE); Herkulex.moveOneAngle(1, 10.00, 900, LED_BLUE); Herkulex.moveOneAngle(3, -98.70, 900, LED_BLUE); Herkulex.moveOneAngle(4, -10.00, 900, LED_BLUE); delay(800); Herkulex.moveOneAngle(0, 160, 900, LED_GREEN); Herkulex.moveOneAngle(3, -160, 900, LED_GREEN); Herkulex.moveOneAngle(4, -70, 900, LED_BLUE); Herkulex.moveOneAngle(1, 0, 900, LED_BLUE); delay(900); Herkulex.moveOneAngle(0, 89.05, 1500, LED_BLUE); Herkulex.moveOneAngle(1, 116.67, 1500, LED_BLUE); Herkulex.moveOneAngle(3, -92.30, 1500, LED_BLUE); Herkulex.moveOneAngle(4, -149.83, 1500, LED_BLUE); Herkulex.moveOneAngle(6, 12.02, 1500, LED_BLUE); Herkulex.moveOneAngle(10, 1.63, 1500, LED_BLUE); Herkulex.moveOneAngle(11, 30.55, 1500, LED_BLUE); Herkulex.moveOneAngle(15, 20.47, 1500, LED_BLUE); delay(1500); Herkulex.moveOneAngle(6, -7.00, 1000, LED_BLUE); Herkulex.moveOneAngle(10, -8.60, 1000, LED_BLUE); Herkulex.moveOneAngle(11, 8.00, 1000, LED_BLUE); Herkulex.moveOneAngle(15, 8, 1000, LED_BLUE); delay(900); Herkulex.moveOneAngle(1, 144.95, 1500, LED_BLUE); Herkulex.moveOneAngle(4, -123.17, 1500, LED_BLUE); Herkulex.moveOneAngle(6, -22.42, 1500, LED_BLUE); Herkulex.moveOneAngle(10, -19.17, 1500, LED_BLUE); Herkulex.moveOneAngle(11, -5.85, 1500, LED_BLUE); Herkulex.moveOneAngle(15, -1.63, 1500, LED_BLUE); delay(1500); Herkulex.moveOneAngle(6, -7.00, 1000, LED_BLUE); Herkulex.moveOneAngle(10, -8.60, 1000, LED_BLUE); Herkulex.moveOneAngle(11, 8.00, 1000, LED_BLUE); Herkulex.moveOneAngle(15, 8, 1000, LED_BLUE); delay(1500); Herkulex.moveOneAngle(0, 89.05, 1500, LED_BLUE); Herkulex.moveOneAngle(1, 116.67, 1500, LED_BLUE); Herkulex.moveOneAngle(3, -92.30, 1500, LED_BLUE); Herkulex.moveOneAngle(4, -149.83, 1500, LED_BLUE); Herkulex.moveOneAngle(6, 12.02, 1500, LED_BLUE); Herkulex.moveOneAngle(10, 1.63, 1500, LED_BLUE); Herkulex.moveOneAngle(11, 30.55, 1500, LED_BLUE); Herkulex.moveOneAngle(15, 20.47, 1500, LED_BLUE); delay(1500); Herkulex.moveOneAngle(6, -7.00, 1000, LED_BLUE); Herkulex.moveOneAngle(10, -8.60, 1000, LED_BLUE); Herkulex.moveOneAngle(11, 8.00, 1000, LED_BLUE); Herkulex.moveOneAngle(15, 8, 1000, LED_BLUE); delay(900); Herkulex.moveOneAngle(1, 144.95, 1500, LED_BLUE); Herkulex.moveOneAngle(4, -123.17, 1500, LED_BLUE); Herkulex.moveOneAngle(6, -22.42, 1500, LED_BLUE); Herkulex.moveOneAngle(10, -19.17, 1500, LED_BLUE); Herkulex.moveOneAngle(11, -5.85, 1500, LED_BLUE); Herkulex.moveOneAngle(15, -1.63, 1500, LED_BLUE); delay(1500); Herkulex.moveOneAngle(6, -7.00, 1000, LED_BLUE); Herkulex.moveOneAngle(10, -8.60, 1000, LED_BLUE); Herkulex.moveOneAngle(11, 8.00, 1000, LED_BLUE); Herkulex.moveOneAngle(15, 8, 1000, LED_BLUE); delay(1500); Intial(); }
void sleep() { Herkulex.moveOneAngle(0, 97.00, 2000, LED_BLUE); Herkulex.moveOneAngle(1, 9.00, 2000, LED_BLUE); Herkulex.moveOneAngle(2, -1.00, 2000, LED_BLUE); Herkulex.moveOneAngle(3, -97.00, 2000, LED_BLUE); Herkulex.moveOneAngle(4, -9.00, 2000, LED_BLUE); Herkulex.moveOneAngle(5, -1.00, 2000, LED_BLUE); Herkulex.moveOneAngle(6, 1.00, 2000, LED_BLUE); Herkulex.moveOneAngle(7, -37.00, 2000, LED_BLUE); Herkulex.moveOneAngle(8, -69.00, 2000, LED_BLUE); Herkulex.moveOneAngle(9, 43.00, 2000, LED_BLUE); Herkulex.moveOneAngle(10, 1.00, 2000, LED_BLUE); Herkulex.moveOneAngle(11, 1.00, 2000, LED_BLUE); Herkulex.moveOneAngle(12, 43.00, 2000, LED_BLUE); Herkulex.moveOneAngle(13, 69.00, 2000, LED_BLUE); Herkulex.moveOneAngle(14, -37.00, 2000, LED_BLUE); Herkulex.moveOneAngle(15, 1.00, 2000, LED_BLUE); }
void WakeUp() { Herkulex.moveOneAngle(6, 0.00, 1200, LED_BLUE); Herkulex.moveOneAngle(7, 0.00, 1200, LED_BLUE); Herkulex.moveOneAngle(8, 2.00, 1200, LED_BLUE); Herkulex.moveOneAngle(9, 4.00, 1200, LED_BLUE); Herkulex.moveOneAngle(10, -2.00, 1200, LED_BLUE); Herkulex.moveOneAngle(11, 0.00, 1200, LED_BLUE); Herkulex.moveOneAngle(12, 0.00, 1200, LED_BLUE); Herkulex.moveOneAngle(13, 0.00, 1200, LED_BLUE); Herkulex.moveOneAngle(14, 0.00, 1200, LED_BLUE); Herkulex.moveOneAngle(15, 0.00, 1200, LED_BLUE); delay(1000); Herkulex.moveOneAngle(0, 160.00, 1000, LED_BLUE); Herkulex.moveOneAngle(1, 30.00, 1200, LED_BLUE); Herkulex.moveOneAngle(2, -1.00, 1200, LED_BLUE); Herkulex.moveOneAngle(3, -143.00, 1200, LED_BLUE); Herkulex.moveOneAngle(4, -26.00, 1200, LED_BLUE); delay(1200); Herkulex.moveOneAngle(0, 160.00, 1000, LED_BLUE); Herkulex.moveOneAngle(1, 90.00, 1000, LED_BLUE); Herkulex.moveOneAngle(2, -1.00, 1000, LED_BLUE); Herkulex.moveOneAngle(3, -159.00, 1000, LED_BLUE); Herkulex.moveOneAngle(4, -64.00, 1000, LED_BLUE); delay(1200); Intial(); }
9 Comments
JR Tyner 9 years ago
Great job, I love how detailed this instructable is. You really did a good job explaining all the steps from beginning to the end. After I get some projects crossed off my list, I'll give this a try too. If I am successful, I'll post a "I Make It!" comment to let you know. Thanks again for being so detailed.
KayathiriS1 3 years ago
vaibhavsri9170763 6 years ago
thanks instructables for giving a fantastic robot with all its coding. i made it.it's mine 55th robo that i have made
AjayA69 3 years ago
DEVIDK 7 years ago
KayJ12 8 years ago
Is it possible to program it with python?
sshah54 9 years ago
dear sir amazing i am from india i am pursing my graduation bachelor degree in electronic engineering how can i contact you
can we have a talk on skype ? whats is your email id
shahsoumil519@gmail.com
Statjack 9 years ago
Man That's Really Awesome
with some improvements I could be a really Nice robot
I really Liked the dancing part :D
