Hydraulic Arm
Intro: Hydraulic Arm
This hydraulic arm was a homework for my daughter's school. The idea was to create a toy from recycled materials. Hope you enjoy.
Video:
Video:
STEP 1: Materials
- Pieces of cardboard
- 8 syringes
- 1,5 meter hose (aquarium pump)
- 15 Plastic clamps
- 2 screws with 3 washers and 4 nuts
- 1 piece of wire (clothespin)
- 1 wooden stick
- Water, paint, glue, knife, ruler, etc..
- 8 syringes
- 15 Plastic clamps
- 1 wooden stick
STEP 2: Planning and Cutting
We made two drawings of what would be the arm and joints. This allowed us to readily quantify the material being used.
After choosing the model that we would use, cut the pieces (not much criterion measurements) as shown in picture.
STEP 3: Cutting and Mounting Arm
STEP 4: Cutting and Mounting Claw
The gripper is designed to move just one piece. It was more simple.
The "finger" was pasted fixed and mobile was seated on a shaft made with a piece of wooden stick that had a piece of cardboard cut in a circle glued on top so as not to leave the place.
STEP 5: Cutting and Mounting Base
The base was made from two pieces of cardboard in order to support arm and accommodate syringes in the same set.
The movable part has two holes:
- One in the center (to be able to rotate the base)
- The other end (to link the syringe and allow movement)
The syringe was attached to another piece of cardboard to keep the same level of mobile base.
After verifying the limits of movement, we fix the syringe with the clamps.
STEP 6: Putting It All Together
Aftercreatedthearm,clawand basepiecestogetherto testoutthe movements andcheck if everything isworking properly.Onceassembled, we found thatthe syringeclampwas notwell positioned.We cuta piece of cardboardto attach thesyringeto another position,as shown in figure.
STEP 7: Painting
After completing the check and corrected minor errors, disassembled the arm as far as giving and paint. After the paint dries, put together definitely.
STEP 8: Filling the Syringe
We chose four colors to color the water and fill the syringes.
Fill the hose and then put a syringe (without air inside - close) on one end. Fill another syringe (not filling all) and put the other end. Check the operation.
STEP 9: Final Result
I hope you enjoyed.
66 Comments
ToggleSwitch 9 years ago
I favorited this as soon as I saw it. I really love the idea, and the vibrant colors! Thank you for the time you spent making this instructable, I really enjoyed it and was educated in hydraulics through it.
PeckLauros 9 years ago
Thanks!
mr_robotics_ 1471 8 years ago
dexterjimmy56 20 days ago
Can you make a smoke precipitator
JiggleW 7 years ago
cool is it okay if I use this for my science fair project
PeckLauros 7 years ago
No problem! No problem. I suggest reinforcing the claw arms with popsicle sticks, for example.
spiritclaw102 8 years ago
Cool, mine turned out perfect! Thanks for showing me and some others a good step-by step process into making this. I plan to take a picture of it and post it on here as well.
PeckLauros 8 years ago
Thank you for enjoying the work . Here at Instructables have many good works . As soon as I can, I come back to post more .
Wow, that's a lot of work you put into this project! It really fascinated me, so I will be looking at more of your projects!! Thanks for publishing it :D
ramdasshirke 8 years ago
IT WAS NICE !!!!
jOker58 8 years ago
I made something just like this there really awsome
Show us yours!
jOker58 8 years ago
this is mine yours is more advanced
Nice idea!
jOker58 8 years ago
Nice! :)
GraydonT 8 years ago
i had something like this before. then i broke it with over pressurizing it.
so i might build this. becuses it doesnt need to be pumped up.
moosaahmed 9 years ago
Hello . Unfortunately this is an old project and I missed the measures . Will depend on the size of syringes you buy.
