I2C Keypad
Intro: I2C Keypad
This instructable explains how to interface with a 4x4 keypad over an I2C bus.
I started this project because I wanted some plug and play input and output modules for easy and fast prototyping of my electronics projects (mostly with PIC microcontrollers). Of course you can use leds and dip switches but they require lots of pins on your microcontroller and you only have binary I/O.
To solve this problem I decided to use I2C.
I2C is a 2 wire bidirectional bus to which addressable devices can be connected.
I had some I2C remote I/O expander chips laying around that I could use for this purpose.
You give them an address and then you can read or write to their 8 I/O pins.
I also recovered a 4x4 keypad from a broken telephone to be used as input device.
And I connected a 7 segment display to the I2C bus as an output device.
In a next iteration of the project I'll move the components to PCB.
STEP 1: Components
Required components:
-1x PCF8574 I2C chip (remote 8-bit I/O expander for I2C-bus)
-1x 4x4 Keypad
-2x 2,2 kOhm pull-up resistors
-1x PIC18F4550 (or other programmable I2C master device)
Optional components (depends on output):
-1x 7 segment display
-7x 330 Ohm resistor
-1x serial to usb dongle
-1x 4x4 Keypad
STEP 2: Circuit
Because the I2C bus only uses 4 wires (power, ground, clock and data) the circuit is very simple.
The microcontroller (MCU) and the I2C chip are both connected to the 5V from the power source. In my case the circuit is powered by my MCU programmer which gets it power from the USB port of my computer.
The 8 I/O pins of the I2C chip are connected to the 8 pins of the keypad. It's easier for writing the code if we make the connections in a logical order. I connected the column pins on one side of the chip and the row pins on the other side of the chip.
Data (SDA) and clock (SCL) from the I2C chip are connected to the data and clock pin of the MCU.
Both SCL and SDA lines are "open drain" drivers. What this means is that the chip can drive its output low, but it cannot drive it high. For the line to be able to go high you must provide pull-up resistors to the 5v supply. There should be a 2,2 kOhm resistor from the SCL line to the 5v line and another from the SDA line to the 5v line. You only need one set of pull-up resistors for the whole I2C bus.
3 bits of the 8bit address of the device are set by connecting the address pins to 5V or to ground.
Output:
The serial output (UART/rs232) goes to my serial to usb dongle that is connected to my pc.
The second PCF8574 chip is connected to the I2C bus by connecting the data and clock line to the data and clock line from the first chip.
For the second chip we need a different address so I connected the first address pin to 5V instead of the ground.
The common anode of the 7 segment display is connected to the 5V from the power source. The other pins are connected with the I/O pins of the I2C chip (using 330 Ohm current limiting resistors).
Output:
STEP 3: Code
The code implements the standard keyboard scanning routine by reading and writing to the I2C chip. The keypad is scanned by selecting a column and then reading the rows to see wich one of the buttons is pressed.
First the I2C chip is put in write mode and all the output pins (rows and colums) are set high, except the column we are going to scan, this one is set low. After that we set the I2C chip in read mode and read the pins. If one of the buttons on the selected column is pressed, the row pin it's connected to is pulled low because pressing the button connects the row and column pin. We can now determine the button value because we have the row and column value. If none of the rows is low, we select the next column and read again.
The button value is then sent over I2C and UART to the output, in this case the 7 segment display (I2C) and a serial terminal (UART) running on my computer.
17 Comments
didiersee 5 years ago
hello very good project but where is downloading library?
p18cxxx.h
i2c.h
usart.h
stdlib.h
Synck 5 years ago
You should be able to find them on the Microchip website.
They are part of the libraries for the PIC18.
Ok. I would like to adapt this project on an arduino mega could you tell me what I need to change because I do not know the Microchip PIC.
Tank you very mutch.
Synck 5 years ago
I'm not familiar with Arduino, so I can't help you.
it's nothing I'm looking for thank you for answering
bk-paradox 10 years ago
exactly what im after
http://www.esawdust.com/blog/eagle/partsearch.html
I used this to search for keypad and it pointed me to get keypad4x4_ece.lbr
Eagle search is not intuitive :p
Cheers
Synck 10 years ago
hasanhadi 10 years ago
please i needed this project
Thanks
tinker234 13 years ago
Ender2007 13 years ago
Thanks.
hobbyman 13 years ago
I just wondered why you didn't use the hardware I2C port of pic 18f4550?
Synck 13 years ago
RB0 is the data line and RB1 is the clock line as stated in the datasheet page 14.
janw 13 years ago
djmachet 13 years ago
janw 13 years ago
