Introduction: ICStation Rechargeable LED Dimming Table Lamp DIY Kit
Short Description:
The icstation LED Table Lamp uses 24 pure white LED and adjusts the brightness of the lamp through a potentiometer.
It’s a DIY kit which comes with various components. User need to install each component by hand. It not only can exercise and improve soldering skills, but also increase the interest in electronic technology. Great for electronics hobbyists, beginners, school and home education.
About the lamp function:
- PWM Adjustable Brightness. It uses PWM technology to achieve 0% - 100% seamless and smooth adjustment of brightness by adjusting the pulse width of PWM signal to 0% - 100%. It also can turn OFF lamp by potentiometer.
- Flexible Lamppost. It adopts a 28cm flexible lamp post , we can adjust the light angle and height according to needs.
- Rechargeable circuit, with a 18650 lithium battery charging module.It is convenient for table lamp to realize wire-free application and charging.
Step 1: Install 2pcs DO-35 IN4148 Diode at D1,D2
Please ay attention to the installation direction.
Step 2: Install 2pcs 200ohm Metal Film Resistor
Step 3: Install 2pcs 10Kohm Metal Film Resistor
Step 4: Install 1pcs 0.001uF 102 Ceramic Capacitor
Step 5: Install 3pcs 0.1uF 104 Ceramic Capacitor
Step 6: Install 1pcs SMD Micro USB 2Pin
Step 7: Cut 8Pin Male Pin to 2pcs 4Pin Male Pin
Note: the longer pin faces up.
Step 8: Install 1pc NE555 Board on 4Pin Male Pin
Step 9: Install 1pcs Bend Pin Socket
Step 10: Install 1pcs Straight Pin Socket
Step 11: Install 1pcs TO-92 ALJ2302 MOS-N
Note: the arc of ALJ2302 corresponds to the arc silk screen on the PCB.
Step 12: Install 1pcs 100uF Electrolytic Capacitor
There is a white ‘ + ’ on PCB silk screen printing where the positive(anode) can insert into.The longer lead is positive(anode)
Step 13: Install 1pcs 3Pin Male Pin
Step 14: Install 1pcs 50Kohm Potentiometer
Step 15: Install Bend Pin Socket on Battery Charging Module
Step 16: Install Battery Charging Module-P1
Step 17: Release Potentiometer Board by Scissors
Step 18: Identify LED Anode and Cathode Lead
Identify the positive(anode) and negative(cathode) lead of LED.The leads of the LED must be installed correctly, otherwise the LED cannot be turned on.Here are four methods as following:
1.According to the length of the LED lead to distinguish. The longer pin is positive(anode) lead. The shorter pin is negative(cathode) lead.
2.Identify the negative(cathode) of the LED is to look into the plastic case where one can see that the negative(cathode) is much thicker/bigger inside the plastic case than the anode lead.
3.Identify by edge of plastic case.The negative(cathode) lead of the LED should be the pin nearest the flat on the plastic case.
4.Test by 3V battery or multimeter.The pin is positive(anode) lead which has connect to the positive of 3V if LED can light up after connect 3V power supply.(LED should not be powered directly from the 3V for a short time:less then 0.5second)
5.It is positive(anode) where the white mark “ + ” pointing to on PCB.
Step 19: Install 24pcs 5mm 0.5W White LED
Step 20: Fix Red/Black Wire on LED Board
Red connect to “ LED+ ” pad and black connect to “ LED- ” pad.
Step 21: Insert Wire
Be careful not to push too fast.
Step 22: Adjust LED Lamp Panel
Pay attention to the direction of the lampshade.
Step 23: Fix Lamp Shade
Step 24: Connect PCB and Potentiometer Board
Step 25: Fix Main PCB on Bottom Plate
Step 26: Fix Wire on Hole
Step 27: Fix Lamp Post
Step 28: Fix 20cm Red/Black Wire at P4
Step 29: Connect 18650 Battery
Step 30: Fix Potentiometer Board
Step 31: Fix Case
Step 32: Install Knob Cap on Potentiometer
Step 33: Done Now!
If you have childs, you can also build this led lamp kit together with them together, and then light it up in their desktop! Will this be a nice choice to learn electronics knowledge from our daily used items?
Feel free to contact us if there is any question!
Besides this led lamp kits, there are also many other electronic kits for beginners or challenger, with detailed pdf documents from ICStation.com to help you learn and improve soldering skills!
Did you try any of icstation diy kits? Come and Share with us!
