Introduction: IJDMTOY 2011-2013 Chevy Silverado LED Light Bar Installation
Check out this iJDMTOY Chevy Silverado LED Light Bar for the 2011-2013 Chevy Silverado! It's perfect for those looking for an LED light bar and wanting to install it in a discreet area.
Step 1:
Use a 10mm socket to remove the 3 bolts behind the bumper opening.
Step 2:
Remove the pins by carefully holding the air flap.
Step 3:
Put the bracket through the bumper and then hand tighten the 3 bolts back together.
Step 4:
Install the light in the bracket through the bumper using the included bolts.
Step 5:
Ensure that the light and bracket are both centered and then tighten the 3 bolts holding the brackets.
Step 6:
Set the angle of the light bar that you want and then tighten the 2 bolts on either side. As you can see, this iJDMTOY Chevy Silverado LED Truck Light was very straight forward to install and you too can be rocking this on your Chevy Silverado too!
