Introduction: IJDMTOY LED Fog Lamp Kit for Ford F150 Install
The Ford F150 is a versatile truck and has many off roading capabilities. You don't want to use this truck and not have enough lighting to see through the night so that's why here at iJDMTOY we have created this iJDMTOY LED Fog Light Kit for the 2006 to 2014 Ford F150. Perfect for those looking to add some more lighting to their truck and simple to install so let's begin.
Step 1:
Take the small bolt and drop it down to the inner sides of the the pod lights. Take a small screw and insert it into the other side of the LED. Use a screwdriver to press down on the bolt so it doesn't slide around when you're screwing it tightly. Take the screwdriver and finish securing the nut and bolt, then repeat the process on the other side.
Step 2:
First, put the screw through the metal U Bracket. It maybe simpler to adjust the U bracket a little to get the screw in.
Step 3:
Grab the metal mounting bracket and then tighten it down with the included bolt.
Step 4:
Step 5:
As you can see, assembling this together is super simple and straight forward. This iJDMTOY Truck Light is perfect for those looking to add a super bright light to their Ford F-150. No modifications needed and looks absolutely great on your truck.
