Introduction: IKEA Matchspel Assembly Guide
Hello! This is a guide to help you assemble your IKEA Matchspel chair.
- IKEA Matchspel Chair (hex key is provided)
- Scissors
Step 1: Unbox the Parts
The box can be opened with regular scissors. Find a large space to put all of the components of the chair.
Step 2: Attach Wheel Casters
All of the wheel casters are identical. Once you open the bag, you can just press the wheel casters into the large five-spoked mount. Sitting on the chair will only compress the casters into the mount, and there will be no force on the casters trying to pull them out. Be sure to line up the casters very well into the mount, otherwise it will be difficult to push the casters in.
Step 3: Attach Gas Cylinder
The black cap on the gas cylinder can be thrown away. The gas cylinder just slides into the hole of the wheel mount, with the thinner section facing the bottom.
Step 4: Attach Headrest to Back Frame
The headrest slots into the hole of the frame on the back of the chair. There are two screw holes on the back frame, and the headrest is threaded. Do not tighten both screws fully until both screws are inserted.
Step 5: Attach Back Frame to Back of Chair
There are holes on the bottom of the back rest of the chair. The back frame attaches to this part. For me, the back rest had to be stretched a little bit to fit the back frame. After you screw in those holes, do not tighten the holes all the way. There are two more holes at the top of the back rest, which are used to attach to the back frame.
Step 6: Attach Levers Assembly
All of the levers to control the chair are in this one part, which is pretty heavy. It attaches onto the bottom of the chair with four screws. However, two screws are shorter, and are used on the side that is away from the protruding weight adjuster. The two longer button-head screws are used on the side closer to the weight adjusting knob.
Be sure to not tighten the screws fully until all four screws are inserted.
Step 7: Attach Bottom of Chair to Backrest
The backrest has an L-shaped section that fits into a slot on the bottom of the chair. It is easier to assemble the two while they are on their sides, because you can easily manipulate both without having to struggle with gravity. The three holes are difficult to align, but I recommend inserting a screw whenever a hole lines up, and eventually all 3 holes will line up. You can tighten the screws after that.
Step 8: Attach Chair to Wheel Mount
The two just slide together. I recommend doing this with the backrest and bottom of the chair on the ground, and inserting the wheel mount into the hole near the levers, as the wheel mount is much lighter. Once they are aligned, you can tip the chair upright, and push down to ensure the chair is attached properly.
Step 9: Adjust Headrest
The headrest is adjustable. Once you find a position that is comfortable, tighten the screw that the headrest pivots around.
Step 10: Enjoy!
I recommend ripping off the tag on the bottom of the chair, as it covers one of the levers. To clean up, it is easiest to use one of the larger bags to store the smaller bags.
I hope this article helped you assemble your IKEA Matchspel chair! The provided instructions are helpful, but this article is to provide some actual pictures and to hopefully clarify some steps.
