IOT Waterballoon Launcher
Intro: IOT Waterballoon Launcher
Its fun to play with waterballoons and shoot at people, but then what bad happens that the guy down there is able to see you throwing it on him and gets angry, which causes him to have a good talk with your parents complaining them about your mischeif.
Having this trouble with myself (as it has happened with me in past) I thought why not to make use of technology to overcome my problem , which was stopping me to have fun! So if you also want to have fun like me, lets start building it...
STEP 1: Materials
Hardware:-
. 2x Aluminium bars (about 1.5 m long)
. A cardboard box
. A cardboard tube
. ESP8266 module
. Breadboard/PCB
. Nut and bolts
. Tape
. metal /cardboard strip (according to length of water balloon, 5-6 cm approx.)
. Zip tags
. USB to TTL converter/FTDI module (for programming ESP8266)
. Servo motor
Software:-
*Arduino IDE link: https://www.arduino.cc/en/main/software
*Latest BLYNK library link: https://github.com/blynkkk/blynk-library *Blynk_v0.3.4.zip https://github.com/blynkkk/blynk-library *pySerial link: https://github.com/blynkkk/blynk-library
*ESP8266 blynk library:https://github.com/vshymanskyy/ITEADLIB_Arduino_W...
*Blynk app on iphone or android.
STEP 2: Connecting Esp866
Connect esp866 to ftdi as shown in the schematic above.Download and install Arduino IDE software. Once installed, run the software and on the top menu bar click File - Preferences and you'll see a field that says Additional Boards Manager URLS:. Copy and paste this into that field:
http://arduino.esp8266.com/stable/package_esp8266c... and Click OK
On the top menu bar click Tools - Board: - Boards Manager and scroll down to verify that the ESP8266 by ESP8266 Community is INSTALLED. If so, click close and once again go to Tools - Board: - Boards Manager, and you'll now see a bunch of ESP8266 type boards that you can program using the Arduino IDE.
STEP 3: Adding Blynk Library
Download the latest Blynk Release Library from GitHub to somewhere familiar like your desktop (it might download to your Downloads Folder). Right click on the file you just downloaded and select Extract All, (if Extract All is not available to you, download and use Winzip trial to Extract). Open the newly created folder and copy the contents to your Documents\Arduino\libraries folder. Its should look like the above pictures.
STEP 4: Change IDE Hardware Settings
Connect your USB to Serial adapter to your computer, the ESP-01 should be connected to it.
Download the attached sketch ".ino" file, then double click it and it should load into the Arduino IDE. In the IDE click Tools - Boards and choose Generic ESP8266 Module. Again click Tools - Port and choose the COM port of ESP-01 you just plugged into your computer. (Note you can unplug and re-plug the adapter to figure out which COM port it is) Once again click Tools - Upload Speed and choose either 115200 or 9600. You have to change a few things in the sketch code, the "Auth Token", the "ssid" and the "password" The next will show you where to get your "AUTH CODE"
STEP 5: Download the Blynk Android / IOS App
Get the Blynk App and your Auth Token
To start:
1. Download Blynk App: http://j.mp/blynk_Android or http://j.mp/blynk_Android
2. Create your account and name your new project."Auth Token" will be provided to you when you select new project.
3. Select esp8266 under devices label.
4. Touch the '+' icon and add a button. Then configure it by selecting virtual button 'V1'.
STEP 6: Final Connections
Connect the servo and esp8266 as per the connections shown above.
STEP 7: Mechanical Part
Take aluminium bars and drill holes on each end for bolts. You also need to drill holes on the ends of metal strips. Attach the strips on the end of the bars, joining the two bars with the help of nut and bolts.To the other end attach a long bolt vertically as shown.
2 Comments
DIY Hacks and How Tos 6 years ago
Clever way to launch a water balloon. Just be careful how high you release these from. If you drop them from too high, someone could get hurt.
SparshS 6 years ago
ya sure
