Introduction: IPhone Power Cord Protection With Shrink Tubing
This simple Instructable describes protecting the iPhone power cord with shrink tubing.
Step 1: What You Are Trying to Prevent
The iPhone is a significant investment but the power cord is surprisingly vulnerable to kinks and tears. To protect against this I applied a two inch length of shrink tubing. This serves to reinforce the collar.
Step 2: Slip on the Tubing and Apply Heat to Shrink It
I use a heat gun but you can use a soldering iron or even just use a lighter to shrink the tubing. The tubing shrinks into place and holds fast.
Step 3: The Finished Project
You can see the finished product here again. I've found this much more durable.
The other advantage is that my cords are color coded so I can quickly find the right cord for each device.
74 Comments
4 years ago
The end product looks very nice, but the intractable is not usable without the diameter and shrink ratio of the shrink tubing.
6 years ago
really useful tips! Thanks
6 years ago
What is this tubes?
Where can I find it ?
6 years ago
You may make it bulkier :) with some hot melt glue under the shinking tube.
https://www.instructables.com/id/Make-custom-cables-with-hot-glue-and-shrinking-tub/
Reply 6 years ago
I missed that image
6 years ago
I always add a spring from a ballpoint pen to stabilize the cable end. Makes it sturdy and stable. (even against cat bites ;) )
6 years ago
what gauge tubing are you using? My yellow from a color coded multi-pak is no where near the correct size.
6 years ago
Am ready..
6 years ago
Hyperlinks1. I don't think so. The duration of heat seems way too short.
6 years ago
This seems like a much better solution than my 3d printed one! I would love to try this, but do I have to worry about the heat gun damaging the charger?
6 years ago
I saw this the day after my girlfriend's power cord broke. Damn! I will buy some heatshrink tube today and make this.
Reply 6 years ago
I hope this works for you. Let me know.
6 years ago
Masterleo. Good tip. Thanks
6 years ago
Runswithwolves. Amazon stilocks it. But Harbor Freight and local home stores carry a lot
6 years ago
mabe a great shop you could add to the instructable :
https://www.sparkfun.com/products/9353
6 years ago
It was also my idea great work for the instructables !
I bought mine here :
6 years ago
WHERE DOES ONE FIND THE THREE MENTIONED PRODUCTS, PLEASE?
6 years ago
I'm fairly sure you can stretch heatshrink so it will fit over larger objects (like the usb plug) and it will still shrink down. Just be careful not to tear it.
Good 'ible :)
Reply 6 years ago
Good information. I'm going to try that to see what the limits are.
6 years ago
Thank you for sharing this. It is such a simple solution to something that has plagued me for years... Using materials that I already have in my shop. Thank you!
