IRON FLAIL.
Intro: IRON FLAIL.
Is there anything cooler , Stronger, baddest that Epic Game weapons? When you choose the weapon that helps you in the Quest,It should be able to handle just about anything life throws your way.
If you are a fierce warrior that slash hordes of orcs and other evil armies, don´t you think that would be awesome if you really handle those ammo in your hands?
Well I´m the kind of gamer that really get in the role.Since I begin to play Epic Role Video Games I was wondering to have some weapons in my wall that remains in my family for Aeons.
That would be an awesome piece of decoration for your cave.
Need no more words, time to battle.!!
Warning and disclaimer. This is a display piece, not intended to be used as a weapon, I bear no responsibility for any injuries sustained if the warning is ignored.Flails and many other "jointed" weapons (such as nunchaku) constitute prohibited weapons in Canada, and are illegal to possess without proper licensing.
I made this weapon to use only in self defense against ORCS, ZOMBIES, WEREFOLVES AND ANY EVIL CREATURES THAT INTEND TO HURT MYSELF AND MY BELOVED ONES.Its not made to killmyself or anybody else.Is just for fun and decorative puposes, so chill out and stop thinking those crazy things.
STEP 1: Stuff & Making
STUFF
Forged Manganese + Iron Ball.(2.5 kilograms)
Iron chain.40 cms.
Piece of wood.35 cms.
Arc welder.
Welding rods.
Clear Varnish.
The main part is the Iron ball. It's made of manganese and Iron and its from a Wet mill of a Cement plant.It weights 2.5 kilograms.
First I carved the wood handle. Then I made a C figure in iron and attached to the handle with an Iron rivet.Finnally I welded the 40 cms.chain to the Iron ball and paint in Black.
Iron chain.40 cms.
Arc welder.
Welding rods.
Clear Varnish.
STEP 2: Iron Mace Smash !!!.
Once is finished it´s time to have fun and smash some stuff.
Please comment, rate and Vote.
48 Comments
cchristopher2 9 years ago
Lachlan Van Vliet 9 years ago
just a tip,
you should attach the c figure to the handle so there isn't a gap and it's bolted to the top as well as the sides, just to make it more secure
Mr.Sanchez 9 years ago
Thank u so much. Indeed it's so hard to handle. I will fix that issue.
BLASTFEMI 10 years ago
Mr.Sanchez 10 years ago
charlesian2000 11 years ago
A fun wall hanger though.
jnunz 11 years ago
Mr.Sanchez 11 years ago
If the chain is as long as the stick or longer the weapons can't be controlled, the weapon controls the wielder. You've probably found this out if you swing your toy and try to stop it following through. One handed it's a carnival ride :-D
Lengthen the stick to a two handed pole, and you'll get a bit more control, and if you do this you will find that you can have a bit more fun too ;-)
CeltiKaos 11 years ago
Mrballeng 11 years ago
ggboom5 11 years ago
vincent7520 11 years ago
