Lampada Porta Candela/led O Porta Incenso
Intro: Lampada Porta Candela/led O Porta Incenso
Stampa e ritaglia il carta modello. Puo appoggiarlo su cartone o compensato o materiale alveolare e quindi ripassare con il cutter.
Print and cut out the paper template. You can place it on cardboard or plywood or honeycomb material and then wipe with a knife.
STEP 1: Taglio Dei Pezzi
Ritaglia i pezzi usando un cartone ondulato riciclato usando qualche vecchia scatola inutilizzata.
Cut out the pieces using recycled corrugated cardboard using some old box unused.
STEP 2: Pezzi Tagliati
Ora hai tagliato tutti i pezzi. Devi solo montarli.
Now you've cut all the pieces. You just have to mount them.
STEP 3: Lampada Finita
Ora monta i pezzi e la lampada รจ terminata. Utilizza una lampada led come lampadina oppure una semplice candela.
Now fit the pieces and the lamp is finished. Use LED as a light bulb or a simple candle.
STEP 4: Materiali
Utilizza diversi materiali per realizzare il modello. CARTONE oppure COMPENSATO oppure PP-ALVEOLARE.
Buon divertimento !!!
Uses different materials to build the model. Cardboard or plywood or polypropylene-honeycomb.
Have fun!
Have fun!
4 Comments
willoby 10 years ago
P.S. come hai elaborato questa struttura!
Daniele
omalaz 10 years ago
joseqtb 10 years ago
mh76dk 10 years ago
I also wonder if there are any language-guidelines for instructables, because it could turn into a right mess if everyone posts in their native language and there is no "language" section/filter.
Otherwise a welldone instructable - as far as I can see :-)
