Implement a Simple WASM Calculator in Rust Using Leptos, and With DumbCalculator
Intro: Implement a Simple WASM Calculator in Rust Using Leptos, and With DumbCalculator
With this post, I hope to show a way to implement a Web-based WASM calculator using Rust.
STEP 1: The Journey
Here I will assume program development tools like
- Of course, the Rust programming language itself.
- The popular VSCode program development editor / IDE, with the extension rust-analyzer
- Preferably the popular source control tool GIT.
- Leptos -- a Rust framework to develop WASM app in Rust
- DumbCalculator of rusty_dumb_tools -- a simple Rust component that acts like a simple physical calculator.
WASM development in Rust can be enabled with the Trunk tool. Indeed, Trunk is used here, and we install Trunk like
cargo install trunk
After installing Trunk, we will also need to add the Rust target wasm32-unknown-unknown, like
rustup target add wasm32-unknown-unknownKick-starting wasm_calculator
To get kick-started, create a new Rust project wasm_calculator like
cargo new wasm_calculator
Open the just created folder wasm_calculator with VSCode like
cd wasm_calculator
code .
In VSCode, open and edit Cargo.toml adding the necessary dependencies, like
[dependencies]
leptos = { version = "0.6.5", features = ["csr"] }
rusty_dumb_tools = "0.1.7"
Add the Trunk config file Trunk.toml with content like
[build]
target = "trunk.html"
Add trunk.html, which is sort of the template for our final output index.html
<!DOCTYPE html>
<html>
<head><meta charset="UTF-8"></head>
<body></body>
</html>
Note that without the above mentioned Trunk.toml config file, Trunk will in fact look for index.html as the template instead. (However, we would like to reserve index.html for other purposes, and hence would use trunk.html instead.)
Our WASM code will be "mounted" to <body> of this trunk.html, let's see it working
trunk serve --open
This will run the Trunk server serving the trunk.html merged with whatever WASM code in main.rs
The server will keep running, and hot update the page whenever trunk.html or main.rs get changed
Say, change the <body> of trunk.html to
<body><h3>— WASM Calculator —</h3></body>
See that the browser page is updated accordingly.
The Basis of wasm_calculatorThe initially generated main.rs is actually not WASM code to be "mounted" to <body>. To "mount" some simple WASM code (written in Rust), can change main.rs like
use leptos::*;
fn main() {
mount_to_body(move || {
view! {
<div style="color:red">Hello, World!</div>
Again, our modification will be hot-deployed, and we should see that
is "mounted" to <body>, after <h3>— WASM Calculator —</h3>
Here is some little insights from the above code:
- mount_to_body is the function provided by Leptos to "mount" WASM code (written in Rust) to <body>
- mount_to_body can accept a closure which accepts no argument and returns the result of calling the view! macro, which is of cause also provided by Leptos.
- Inside view!, we write "HTML" -- like <div style="color:red">Hello, World!</div> -- which even looks like plain HTML, is in fact "legal" Rust code to be pre-processed by the macro view!.
In fact, normally, we will be coding our WASM code, in an App() function, and "mount" it like
use leptos::*;
fn main() {
mount_to_body(move || view! { <App/> });
fn App() -> impl IntoView {
view! {
As mentioned above, things inside view! will be pre-processed to be transcribed to Rust code in compile time, hence, we should be able to include regular Rust code inside view! like
let color = "red";
let who = "World";
view! {
<div style={format!("color:{}", color)}>Hello, {who}!</div>
As shown, we can enclose regular Rust code inside {} as above {format!("color:{}", color)} and Hello, {who}!
We can even "nest" view! like
let color = "red";
let who = "World";
view! {
view! {
Why "nest" view!? Hopefully, it will become apparent in later sections.
Let's extract the styling of the <div> to live else-where. Indeed, we can put our CSS in trunk.html and use it in App() like
trunk.html
<!DOCTYPE html>
<style>
.test-class {
color: green;
</style>
main.rs
let who = "World";
view! {
view! {
<div class="test-class">Hello, {who}!</div>
Now, let's add two buttons to it to make it interactive.
Note that Leptos will generate HTML once only -- like the above App() will only be called once to generate initial HTML code -- any updates are triggered with "signals", and rendered with closures (more about this later).
Therefore, to make it interactive, not only we will need to add some interactive HTML elements, like <button>, we will also need to make use of "signals" as well.
First, let's add two <button>s, and be able to log to the browser's console when any of the button is clicked:
use leptos::*;
use leptos::logging::log;
use web_sys::MouseEvent;
let who = "World";
let on_clicked = |ev: MouseEvent| {
let value = event_target_value(&ev);
log!("* clicked value [{}]", value);
view! {
view! {
<button on:click=on_clicked value="1">I am 1</button>
<button on:click=on_clicked value="2">I am 2</button>
Notes:
- Two more dependencies
- The closure defined by on_clicked will be called when any one of the button is clicked
- Notice that the two <button>s are placed in the same level as the "nested" view!
- Each button is associated with a value (e.g. value="1"), and when a button is clicked, the associated value is retrieved and printed out to the browser's console
Now, let's make use of "signal" to trigger update of the <div> content
let (clicked_value, set_clicked_value) = create_signal(String::from(""));
let on_clicked = move |ev: MouseEvent| {
set_clicked_value.set(value);
view! {
move || view! {
<div class="test-class"> {
let value = clicked_value.get();
format!("Hello, [{}]!", value)
} </div>
Notes:
- The "signal" is created like
- such a "signal" is composed of a "getter" clicked_value and a "setter" set_clicked_value
- the type of the "signal" is String, and the "signal" is initialized to the empty String
- The "setter" set_clicked_value is called to set new value in the closure defined by on_click, which is called when any of the button is clicked
- Notice that the closure captures variables, like set_clicked_value, moved; and this is the requirement of using "signal"
- The "user" of the "signal" is the <div> created by the nested view!
move || view! {
} </div>
- Notice:
- the "nested" view is now a "moved" closure, since it is using the "signal" to get the new value set
- the value set is returned by calling clicked_value.get()
- by using the "signal", Leptos knows that the closure need be called again to update the content of the nested view! when the "signal" is updated
- Here is what will happen when a button is clicked
- the closure on_click gets called
- the "signal" gets updated when set_clicked_value is called
- the closure of the "nested" view! gets called when the "signal" is updated, which will update the <div> generated by the "nested" view!
Let's change the buttons to ones that simulate the key presses for 1 + 2 =
<button on:click=on_clicked value="1">1</button>
<button on:click=on_clicked value="+">+</button>
<button on:click=on_clicked value="2">2</button>
<button on:click=on_clicked value="=">=</button>
And also add DumbCalculator into the picture
use std::cell::RefCell;
use rusty_dumb_tools::calculator::*;
let calculator_ref = RefCell::new(DumbCalculator::new());
view! {
move || view! {
let mut calculator = calculator_ref.borrow_mut();
if !value.is_empty() {
calculator.push(value.as_str()).unwrap();
let result_value = calculator.get_display_sized(10);
format!("[{}]", result_value)
} </div>
Notes:
- An instance of DumbCalculator is created and stored in a RefCell, and assigned to calculator_ref; note that even calculator_ref is immutable, the instance of DumbCalculator can be retrieved mutable
- Note that since App() will only be called one, only a single instance of DumbCalculator will ever be created, unless the browser page is refreshed.
- The "nested" view! code for the <div> is changed to something like
} </div>
- The instance of DumbCalculator is "borrowed" mutable
- The button value, which is supposed to simulate calculator key press, is pushed to the DumbCalculator like
- What the calculator display should look like is rendered in the content of the <div>
format!("[{}]!", result_value)
Now, let's add two buttons for "AC" (all cancel) as well as "⬅" (undo)
view! {
move || view! {
if value == "ac" {
calculator.reset();
} else if value == "<" {
calculator.undo();
} else if !value.is_empty() {
} </div>
<div>
<button on:click=on_clicked value="ac">AC</button>
<button on:click=on_clicked value="<">{"⬅"}</button>
</div>
Notes:
- The two additional buttons are added below the 1 + 2 = buttons like
<div>
</div>
- Clicking of the two buttons are handled like
if value == "ac" {
calculator.reset();
calculator.undo();
We are getting closer and closer. Let's add to the code the capability of showing the history of the calculator.
For this, we will be using another history "signal".
let (history, set_history) = create_signal(String::from(""));
view! {
move || view! {
if value == "ac" {
calculator.reset();
calculator.undo();
let history = calculator.get_history_string(true);
match &history {
Some(hist) => set_history.set(hist.to_string()),
None => set_history.set("".to_string()),
} </div>
<div>
{move || view! {
<span> { history.get() } </span>
</div>
Notes:
- The history "signal" is added like
- The history if set after pushing value to the calculator
match &history {
- The updated history is displayed next to the "⬅" button
{move || view! {Finally
Finally, let's add all the whistles and bells and finish off our calculator ...
Simply ... please replace the corresponding file as listed here:
- trunk.html -- https://github.com/trevorwslee/wasm_calculator/blob/master/trunk.html
- main.rs -- https://github.com/trevorwslee/wasm_calculator/blob/master/src/main.rs
Or ... simply ... clone the GitHub repo https://github.com/trevorwslee/wasm_calculator
Manually Deploy to GitHub PagesNow that we have the final result WASM calculator, we may want to deployed it to GitHub Pages.
Assuming a GitHub account, say like mine -- trevorwslee, I can easily post some static pages to my GitHub Pages -- https://trevorwslee.github.io/
What I needed is a GitHub repository with the "same" name trevorwslee.github.io -- https://github.com/trevorwslee/trevorwslee.github.io
In order for GitHub Pages to host our WASM Calculator app
- With Trunk, build release version specifying the context to use in GitHub Pages, like mine
- The context is WASMCalculator
- Then the URL to the WASM app is https://trevorwslee.github.io/WASMCalculator/
- To build such release, run Trunk like
trunk build --release --public-url "WASMCalculator"
- After building the release with Trunk, the dist folder will contain the files
- index.html
- wasm_calculator-XXX.wasm
- wasm_calculator-XXX.js to be checked in to WASMCalculator folder of the GitHub Pages repository, like mine -- https://github.com/trevorwslee/trevorwslee.github.io/tree/main/WASMCalculator
- After a few moments, the WASM Calculator should be ready to try out -- https://trevorwslee.github.io/WASMCalculator/
