Industrial Style Slide Door
Introduction: Industrial Style Slide Door
About: Ews & qualified welder/metalworker since 1998
Hi
I found some plywood sheets from my workplace wood dumpster.
Those we're in good condition, so i decided to re-use them as a part of the "industrial style" slide door.
Other materials we're bought or found from a shop.
Video shows the process.
Material:
2" x 4" 8 meters.
Plywood 2 pcs. 8 x 800 x 1000mm
5 x 30mm flatbar 2000m to slide rail.
5 x 60mm flatbar 2 pcs. 250mm long for roller arms.
4 x 20mm flatbar 8 psc 100mm long for slide rail holder hooks.
Screws, nuts and bolts, washers.
"rollers" I used ones with 50mm diameter, with 8mm center hole. Those we're bought from the hw-store sailing section. Costed 5€ (dollars) each.
2mm mild steel sheet for the corners. 8 pieces 150mm x 150mm
Tools: (What i used)
Drill and drill bits. 8mm, 4mm
Circular saw
Miter saw
Angle grinder ( 1mm cut off wheel, 40 grit flap disk)
Chop saw
Step 1: Frame..
I started the making process with cutting the 2" x 4".
I wanted to make door with size 200cm x 90 cm, i cut the pieces 10cm longer, as a working allowance.
I used circular saw to make grooves to the 2" x 4", i made groove 25mm deep and 8mm wide. ( can be made with table saw too)
Plywood will be sunked to that groove.
Then i made miters, and cut the pieces to the right size.
Step 2: Continued...
Continued by cutting plywood to the right size.
Installed them inside the frame, and connected parts together with screws.
Applied layer of acrylic filler to the joints and knots.
Didn't use glue at all, because i want to get door looking "old". When there's no glue joints move and the filler cracks.
I think it looks neat after while. My intention is to apply some dark wax to the cracks after couple weeks, to get cracks more visible. (i'll update this instructable then)
Painted with matte white paint.
Step 3: Corner Brackets..
To the corner brackets i cut 8 pieces 150x 150x 2mm mild steel.
Drilled holes for screws with 4mm drill, and for the center one for the decoration with 32mm drill.
Then i cut the pieces to desired shape with angle grinder using 1mm thick cut off wheel.
Bend the parts with my diy bending brake.
You can see it here:
https://www.instructables.com/id/Sheet-Metal-Plast...
Attached the corner brackets with screws, and finished the door by sanding paint smooth and "worn".
Step 4: Hardware..
I made slide rail from 5 x 30mm flat bar. Lenght 2 meters.
I drilled 8 pieces of 6mm holes to it for the hooks that connects rail to the wall.
Roller arms are made from 5 x 60mm flat bar 2 pieces 250mm long. Two 8mm holes for connecting arms to the door. One for the roller.
8 hooks, Two 4mm holes for attaching hooks to the wall, one to connect it to slide rail.
I drilled holes for the longer pieces, i like its easier to handle workpieces that way, small pieces are difficult to clamp.
After drilling i cut pieces with chop saw.
Step 5: Bending..
Then i bend the hooks.
Simple "fishook" shape.
Roller arms are bend so that the roller comes to the center of the door, then door stays balanced and moves easily.
Made the arms by fit and shape method, without counting angles etc..
Step 6: Finished..
Rollers are attached to the arms with 8mm bolts, nylock nuts and washers.
After installing the rail to the wall, door is just lift to its place.
Woodworking Contest 2017
Be the First to Share
    • Plastic Contest
      Plastic Contest
    • The 1000th Contest
      The 1000th Contest
    • Battery Powered Contest
    40 Discussions
    Shiseiji
    Shiseiji
    3 years ago
    On my wayyyy too long list. Great job IMHO. About the rollers, here is someone who adapted skateboard wheels:
    https://www.instructables.com/id/Make-sliding-barn-doors-using-skateboard-wheels/
    sousap
    sousap
    3 years ago
    Congrats !!!
    but I have to say you went the hard way :-)
    but I know you've done it with and for pleasure
    you can buy this sliding door kits,the rail and a prefabricated door and just fit it :-) I've recently done two sliding doors with these kits and it was pretty straightforward.
    Regards from the Azores islands (Portugal)
    beyondcreative
    beyondcreative
    Reply 3 years ago
    Thanks sousap. Can you share a link of where you get the above mentioned kits? Thanks in advance!
    sousap
    sousap
    Reply 3 years ago
    this is a portuguêse brand APC
    I used the 4000 or 4500 or 5000 series, can't remembre now
    details here page 188
    thormj
    thormj
    Reply 3 years ago
    You can get them at Home Depot, or here's an Amazon link.
    http://amzn.to/2nqd7LJ
    Pricey for what they are, IMHO...
    katerlyn
    katerlyn
    Reply 3 years ago
    our local menards.com and probably homedepot.com have hanging door kits.
    IngenuityAtWork
    IngenuityAtWork
    Reply 3 years ago
    You can get the hardware by piece that's intended for barns and out-buildings, or as a kit for interior use. From what I've seen the interior kits are much more expensive, have more design constraints, and are less robust.
    IngenuityAtWork
    IngenuityAtWork
    Reply 3 years ago
    He started by finding a couple pieces of scrap ply and wanted to find a use for them. That's how a lot of my best projects start! With the steel, rollers, and 2x4's, he probably spent less than 20 dollars on this, maybe 1/3 of what just a roller/hanger kit costs.
    The other Finnish guy
    Reply 3 years ago
    You are absolutely right. I bought things with 20$, everything else i allready had.
    Reply 3 years ago
    There was no kind of rails i wanted, and making them was quick and easy task. I decided it was better option for me.
    rlievens
    rlievens
    Reply 3 years ago
    But this is Instructables! :D
    charlessenf-gm
    charlessenf-gm
    3 years ago
    Impressive metal working - the 'store bought' hardware for these doors is not cheep!
    Would suggest a router and a (correct size) router bit if you decide to do another - it looked cold out there! ;) Also, using a router to relieve the area where your corner braces were fastened would allow those bits to be set flush with the door surface.
    One suggestion - a valance - to cover the fancy iron work and keep the dust/dirt off the mechanism.
    Another thought - rout mortises to accept the vertical hardware bits and use Cap Nuts and matching bolts with heads recessed flush to the door surface on either side of the door.
    Reply 3 years ago
    Thank you. Winters are somewhat cold, but that makes summer feel better. :) Thanks for your tips. I have planned to buy decent router, haven't find good model or brand so far. I had one from the bosch, that supposed to be great but didn't last long. So i returned it.
    charlessenf-gm
    charlessenf-gm
    Reply 3 years ago
    I have 2 porter cable 690 routers,1 3/4 hp. Easily thirty years old - well, one of them is about ten years younger.
    I am NOT a 'pro' woodworker by any means, but have used one or both of them to build everything from raised panel kitchen cabinets to a fastener free deck railing.
    I use one in a home made table (actually built-in) to a bench) using the newer model fixed base that uses a flip to tighten lever as opposed to the older model that used a thumb bolt.
    I do not love the Plunge base at all. But, then, It is the only plunge-base I ever tried in my shop. I do not like the way the motor is secured into the plunge base.
    Cannot say any of the others I've looked at in the stores offer a better plunge base in this regard - but never got to take one home to see for myself.
    I am looking at a Trident model that allows for adjusting the bit height from above the table - maybe for Christmas as I hate spending $300 to get a third router! Also, look to https://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/webspec.html for accessories and bits and router tables !!
    votedemout
    votedemout
    3 years ago
    I made a similar door using plywood and hangers but rather than a rail I used a long piece of uni-strut channel. rollers ran true and were protected from dust, much as another fellow stated a valance would.
    ben.brummett
    ben.brummett
    3 years ago
    Nice job but last I looked America uses imperial units. So please stop using metric. It sux!
    jwzumwalt
    jwzumwalt
    Reply 3 years ago
    Congress passed the Metric Conversion Act of 1975 "to
    coordinate and plan the increasing use of the metric system in the
    United States". Metric is the official US measurment system. However,
    Detroit refused to comply even though they had to retool their assembly
    lines every 2-3 years.
    The United States is one of only three countries, as of 2016, with Myanmar (Burma) and Liberia,
    that have not adopted, or are not in the process of adopting, the
    metric system as their official system of weights and measures.
    IngenuityAtWork
    IngenuityAtWork
    Reply 3 years ago
    Last time I looked, the "www" that the web address for this page begins with means "world wide web."
    Instructables isn't just for Americans.
    244 Jake
    244 Jake
    Reply 3 years ago
    American has been going metric for a very long time. See below
    https://en.m.wikipedia.org/wiki/Metrication_in_the_United_States
    Many of us American's can spell the word, some of Us have both sets of hand tools.
    Our schools are S L O W as we gear down to slowest student in the classrooms.
    I'm over 60 years old, in my life time the schools has reinvented how to count to 10 three times ☹️
    244 Jake
    Reply 3 years ago
    :D Im from the metric side of the globe.
